Un-Biased Reneder Thread - Post Your Renders!! (Reality/Lux, Luxus/Lux, Octane Render, and others?)
1…2021232526…35
  • DustRiderDustRider Posts: 2,913
    Bobvan said:
    My R4/ lux renders man 4.1 is taking along time still have  not really delved into iray since I like the results with R 4 *nudity* http://fav.me/d9128l0
    The first one has a real sixties feel to it wink
    edited August 2015
    Here is another one done in Iray. Nothing special, I was just doing so test renders with the new character from Emma and Jordy (EJ Valeria).
    edited August 2015
    I did this one with Carrara using the Octane Render plugin. It's lit with 2 mesh lights and a low intensity HDRI.
  • kyoto kidkyoto kid Posts: 42,455
    ..while I don't use Octane, I like the skin tones better,
  • JVRendererJVRenderer Posts: 664
    edited August 2015
    Gnobbits
    Octane,,,
  • PhilWPhilW Posts: 5,162
    Here's one of my recent ones, rendered in Octane Render for Carrara, the hair is my Sidelong Hair product, which uses Carrara's dynamic hair, all rendered in Octane with new shaders I have been working on.
    1000 x 1300 - 253K
    Your hair is looking really good Phil. Looking forward to your shaders!
    Gnobbits
    Octane,,,
    Great render! Did you do this with the DS plugin?
    While I like Iray a lot, and it is more convenient to use than Octane, I find Octane a bit easier to get shaders looking the way I want. Of course I have a lot more experience with Octane, so that no doubt influences my comfort level a lot. Octane also seems to render faster and doesn't require as much from my system. During renders in GPU only mode, Iray continuously uses 10-25% of my CPU, where Octane uses virtually none of my CPU, and the temps on my laptop are generally about 3-5 degrees cooler when using Octane, which is a big plus for my laptop (and much quiter).
    edited August 2015
    ...yeah, Lux also rendered at lower core temps than Iray.  The only rub, it has to do so for hours and hours if not day (though that is supposed to change when Reality4.1 and Lux 1.5 are released).
    Not sure though if that is in part due to the fact the Studio application and scene needs to remain open during the process..
    Post edited by kyoto kid on
    Thanks.
    Eventhought I have the DS Plugin, this particular render was done with the Poser Plugin. I'm starting to learn Iray at the moment...I'll be posting some Iray stuff in a couple of months. Yeah, I'm a slow...
    I still prefer Octane over Lux or Iray.  I have two GTX760s with 4 gb each, so I'm spoiled
  • BobvanBobvan Posts: 2,653
    Killer stuff guys more R 4.1 stuff
    1600 x 851 - 2M
    1600 x 851 - 1M
    1600 x 851 - 1M
    Bobvan - nice lighting and I like that there is a story sequence.
  • erik leemanerik leeman Posts: 262
    edited August 2015
    ForbiddenWhispers' Old Street UnderPass rendered through the Octane for DAZ Studio plugin
    Cheers!
    1920 x 1200 - 604K
    Post edited by erik leeman on
    Erik - Great, I really like that one! Great detail and lighting (and this would be a difficult environment to light well with traditional lighting).
    Thanks Phil!
    ....looks great very "Matrix" like.
    Thanks Phil yes it is a replica of the land of the giants outfit # 2 that Deanna Lund wore on the original show in the late 60's
  • DarkSpartanDarkSpartan Posts: 1,096
    Here's a new someone to go with Stefan's new set... Yes, I'm evil and used Iray, because the others cost. I'm going to start working on her skin texztures again now that I've got the rest sorted out.
    This isn't the best-ever render, but Autofollow for this particular shirt doesn't seem to like the new shape.
    960 x 1248 - 999K
  • Tried to make Lady Gaga. Rendered in Iray
    1920 x 1080 - 1M
    edited August 2015
    Joy
    Joy!
    ..ahh! Scared me as the image was so large.
    Small suggestion.  When uploading an image from a URL you can change the size if it is large. Next to the preview box there are two fields that are labelled "width" and "height".  They are constrained (linked together) so you only have to enter the width value to resize the image to fit on the page.. I found that 750 pixels wide fits perfectly within the margins (they said 800 but that also spills over the right margin), .Viewers can still click on the image to see it in full size.
    edited August 2015
    Tram, rendered in Octane Render for DAZ Studio.
    Lots of Stonemason's stuff (of course) : )
    Cheers!
    1920 x 1200 - 355K
    edited August 2015
    He's tired, he feels old and dirty, like his clothes. These 'High Maintenance' G3 females wear him out.
    For how long will he manage to hang on to his job, this G2 Man?
    LOL!
    edit: new version (Octane Render for DAZ Studio).
    1920 x 1200 - 377K
  • larsmidnattlarsmidnatt Posts: 4,511
    edited August 2015
    Octane Render. Not a technical demonstration, just a cute demon girl :)
    And another redhead (Helena) cause I may use an unbiased rendering solution, I have a bit of a bias regarding hair colors. *chuckles*
    LOL!
    looks good
    Joy!
    great expression!
    730 x 1095 - 169K
    774 x 1032 - 224K
    Post edited by larsmidnatt on
  • Oso3DOso3D Posts: 15,125
    Erik: Amazing render.
    And I recognize that coat with the glitch when subd. ;)
  • Erik: Amazing render.
    No! no! no!, it's old and worn! Don't tell him his subdees have been glitched too, he's depressed enough as it is!
    Thanks William : )
    Thanks William : )
    have you tried one of the other sub-d alogrithims? Sometimes it minimizes the issue, sometime not so much.
    Not yet, I only noticed it when the render was running for quite some time already, and (this one and only time ever) I actually liked the effect.
    I'll look into it later, can't have that sort of defect if I want to use it another time.
  • LpProjectLpProject Posts: 41
    edited August 2015
    Used Daz Studio 4.8 Pro, Maxwell Render Plugin for Daz Studio (under development) and Maxwell Render.
    Scene NWX Section 18, without postwork
    Offsite Commercial Link Removed
    1500 x 1125 - 2M
    Post edited by fixmypcmike on
