Star Trek Builders Unite 7: The Continuing Mission
Adding to Cart…
I think that's a cookie issue. Does it to me too after a number of hours absense.
That is looking great, and i am glad those uniforms are working for you.
Speaking of uniforms... ;)
That is AWESOME art and design - I am greatly looking forward to more!
I need an opinion. Take a look at the renders below. Both of these models are supposed to be of the 1701-E bridge. Vanishing Point's does not have any 'Trek specific textures. Sketch-up's does. Vanishing Point's has the right command chairs. Sketch-up's does not- and in neither case do the chairs turn. Sketch-up has the right view screen, Vanishing Point does not.
If I could lift VP's chairs out and use them in Sketch-up's model, I would- but I don't have the skills or the program to do that.
Anyone have any suggestions?
Is VP's right for the First Contact version of the viewscreen? they did change it for Insurrection and Nemesis. As far as the chairs, can you just hide the parts of the set you don't want to use and keep the rest in Poser? It'd be the easiest way to do it without excising actual meshes I would think. It'd be a bit of a mess when you're trying to use it though with both loaded. If you want the chairs to turn though you're looking at editing mesh work.
If I remember right, I think Rudua did a model of the command chair from the "D". While it's not exact, with the right color texture, it could pass. I can take ths Sketch-up model into Sketch-up and delete those chairs. I could do the same with the Helm chairs in Sketch-up. VP's helm chairs are seperate pieces.
That would solve the chair problem, with those in the sketchup model you'd have the set the way you want it.
I'm starting to lean in that direction. I found the chair. It doesn't have the command control panels, but I can add those. I have to make new textures anyway, so I might as well make the panels, too.
Would be easier then having to retexture an entire bridge and ask Rduda to model a new viewscreen, I guess? ;)
That's what I'm going to do. I've gone in and deleted the sketch-up chairs and I'm re-adjusting the texture settings. Sketch-up always imports with the highlights set to 100. everything has to be reset to 0.1 to look right. Then I'll start on the chairs.
I'm pretty sure you'll get there, mads.
The command chairs will work. But VP build's all their bridges as "Characters"- the helm chairs won't seperate from the set. So I'm going to have to build them plus the command panels for the captain's chair.
Hi there's not much in the character work today. I got a couple of pictures working in the TMP era of my story but I have been working more on the sets and everything. I wanted to share these and show what I have been doing and some shots of the Khambatta herself (still fleshing out the details there too) Some of the pics are grainy I apologize for that. Again thanks goes out to Madison Bruffy for the TMP sets made available. Nvent 3d for the uniforms being used and Greywolf Starkiller for his Starship set.
sasuraibito it's all looking good. Glad the sets are working out for you.
Lookin' good, sasuraibito, but one thing: The registries on the underside of the saucer on the Khambatta should follow the curve of the hull. as they are now, they look like last minute add-ons rather than official ship's markings.
I have uploaded "Unit A" for the Enterprise E.
Forum post
Just downloaded it. Thanks.
Anyone have any suggestions short of taking a year off to learn a new modeling program? The yellow one is Ruda's from several years ago. The purple one is his with my add-ons and some scale adjustments.
The control panels I can make. It's the chair itself that's beyond me.
Not all that different from the one I made a few weeks back ( http://www.sharecg.com/v/80360/view/5/3D-Model/Simple-command-chair )
You want me to take a stab at it, Mads?
If you want to try, I'd appreciate it. I'll give the other chairs a try. See what I can do with them.
Found real good pics of the Captain's chair, Riker and Troi's chair too.
Thanks Mads, just what I needed, will see how close I can get for you. :)
Oh, Troi's chair comes without the panels and headrest...
Yes, it does- hers and Riker's are the same.
So only the old man gets a head rest and panels... ok, I get it... must be an age thing, lol. ;)
LOL
You're quite welcome :-)
I'm hoping to get to work with it this weekend.
