Omni Shader Hair Thread
145791012
  • Lee MoonLee Moon Posts: 927
    edited March 2024
    A little more playing with the Revolution - Omni Hair Shader product.
    These were rendered on my PC with a 3060 (12GB VRAM) and then modestly adjusted in Photoshop Elements for color and contrast (as I do on all my renders.)
    I'm using my usual 3 ghost light setup with an HDRI environment map.
    I was going for a 1940-1950's vintage style portaiture with the hair style and b&w post-processed render.
    The hair is https://www.daz3d.com/dforce-hayden-hair-for-genesis-8
    Lee
    1855 x 2400 - 2M
    1855 x 2400 - 2M
    Post edited by Lee Moon on
  • chevybabe25chevybabe25 Posts: 1,334
    "I am trying to understand how textures works in the omnihair shader."
    Hair will pick up texture from the underlying mesh. So if you put the same exact texture on the scalp the hair is parented to, you can kind of see how the hairs "line up".  It also blends the hair from root to tip.  There are ratio and distance settings which set how far down the shaft  each color meets and how blurred it is.
    Patterns are possible, But with long hair, they will be much more difficult to distinguish.
    500 x 419 - 317K
    All of these images are amazing by the way!! Keep them coming :)
  • barbultbarbult Posts: 26,556
    edited March 2024
    Old man on his porch. I chose to leave his eyebrows dark after I recently met a man with white hair and dark brows. The Iden Beard and Nathaniel Hair have the Omni shader.
    2000 x 1500 - 2M
    Post edited by barbult on
    edited March 2024
    I tried the image map on the melanin. That's pretty interesting. I like what it did with the beard. I can't tell much on the hair.
    2000 x 1500 - 2M
  • paulawp (marahzen)paulawp (marahzen) Posts: 1,752
    edited March 2024
    Just to do something different - Here's an outdoor setting and lighting, with Brushed Blond on the Punky Tail hair.
    1300 x 1300 - 1M
    Post edited by paulawp (marahzen) on
    All of the examples you've posted look really good.
  • felisfelis Posts: 6,132
    edited March 2024
    Thank you.
    I had a tiling I hadn't noticed that messed it up.
    So a little further trial and error - way out of realism.
    Root to Tip ratios seems inverted to me, and the color ratio is sure not linear.
    1200 x 1200 - 1M
    1200 x 1200 - 1M
    Post edited by felis on
  • pcw5150pcw5150 Posts: 7
    In case it's helpful to anyone else, I had an error with missing files when loading the hair. I updated Daz Studio (went from 4.22.0.15 to 4.22.0.16) and the default resources file to the latest versions to solve the error.
    Quick and easy fix - and this shader is stunning! Here's the dForce Holo Hair with G9 Kara. It's going to be great fun testing this shader on other hair products!
    2500 x 2500 - 515K
    I tried to apply the OmniHair shader to Daz House Cat fur.
    But whatever I did, the shader remained as Blended Dual Lobe Hair.
    Any suggestions how to apply it, or a reason it can't be applied?
    Select the Daz House cat in the scene. Make sure the fur layer is selected. I don't own the house cat, but id assume the fur is parented to it.  Click on the parameters tab and set the viewport and render line tesselation to 0.  Click on the Surfaces tab. Select ALL of the surfaces. Apply the shader.
    Ah - I had the cat selected in the scene tab - not the parented fur.
    Thank you smiley
  • EboshijaanaEboshijaana Posts: 558
    So marking tests using melanin.
    Without melanin;
    With melanin;
    666 x 533 - 301K
    666 x 533 - 303K
    edited March 2024
    More hair
    1200 x 1200 - 3M
  • Oso3DOso3D Posts: 15,097
    Wow, excellent, Felis!
  • ShimrianShimrian Posts: 588
    felis said:
    More hair
    Wow, is that Daz Cat?
  • NinefoldNinefold Posts: 256
    It seems fitting that the fur on this cat looks so good.
    Yes!
    I wanted to see how it looked with the new shader. I was very positively surprised.
  • Chronopunk said:
    QQ for Chevybabe25 - this will work with your Fringe Benefits hair, won't it?
    It's only my favorite hair in my entire library. :)
    Yes, it does smiley. Thank you for mentioning it, I forgot about that hair.
    A quick and dirty example: on the left is Fringe's mats, on the right is Revolution's.
    1920 x 1080 - 2M
  • ArtiniArtini Posts: 10,595
    edited March 2024
    I have tested fur on https://www.daz3d.com/daz-house-cat-with-dforce-hair
    with Medium Auburn Intense preset from https://www.daz3d.com/revolution--omni-shader-presets-for-strand-based-hairs
    I guess, I need to use Omni Shader on the fur without any preset.
    1200 x 1200 - 226K
    Post edited by Artini on
    You can always match the model colour to the fur colour, too.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,573
    felis said:
    More hair
    oh now this is beautiful heart
    I did try Raynard
    Video
    only included DAZ Omni shader with ctl keep images
    edited March 2024
    Thank for the tips. https://www.daz3d.com/daz-house-cat-with-dforce-hair with Omni shader applied to the fur.
    1200 x 1200 - 330K
    Things to keep in mind for fur:
    If you are using maps, put them in the appropriate root/tip for hair color and hair dye.
    If you used a preset, make sure tiling is 1.
    Remember tessellation 0!
    Be sure to set melanin and  melanin redness to 0 (so they don't shift the actual fur map colors).
    If it looks decent, consider upgrading quality: for every half line start width, double hair count.
  • Matt_CastleMatt_Castle Posts: 3,094
    Again, maybe not the most robust demonstration of the hair, but I'm still going to have some more fun with my WH40K ratling with an outfit kitbash (no two parts here are from the same product - I list the exact components on the gallery page).
    Gallery Link
    I'm sorry, I don't understand the last sentence. Do you mean halving the line start width and then applying it to the hair count?
    Because 0.35 (the width I use) is not much hair.
    Without melanin;
    With melanin;
    I don't see much difference there. Both look pretty pale to me.
    barbult said:
    Without melanin;
    With melanin;
    Yep, because the melanin is only on the areas I wanted it to be. Look at the back, snout and tailtip.
    Eboshijaana said:
    barbult said:
    Without melanin;
    With melanin;
    Ah, I see.
    edited March 2024
    Ok, so here is my test of Dire Wolf for Daz Dog 8. I followed some of the earlier instructions and already set the melanin redness to 0 (before reading @Oso3D's post), but kept putting melanin higher since I wanted the blacks to come out darker (oops!). After adjusting it to 0 the whites and blacks are much better! The root and tip colours are using maps correctly after applying the OnmiHair shader so that's nice. It took a while to find how to apply the shaders, but maybe that was in an earlier post? I selected shaders in shader tab and presets (vs editor) and typed in OmniHair. Omni by itself didn't work for me. :(
    Wolf
    There are also lots of other shader settings that I only played with briefly, e.g. ratio and distance for blends, weight and all kinds of stuff.
    I also tweaked colours in my photo editor since the sky settings were too red for the morning sunrise. The snow needs work, but I just wanted to give a scene for my hair tests! :D
    Edit: Oh, I might have also changed hair clumpiness! Those were in there too.
    1490 x 1080 - 362K
    Post edited by Shimrian on
