The Missed It By That Much to Get a Bacon Steak Sandwich Complaint Thread
1…3435373940…100
  • LeatherGryphonLeatherGryphon Posts: 12,511
    I do not feel like eating anything so I am going to brush my little teeth and go to bed.
    Be sure to brush the big ones too.
  • TJohnTJohn Posts: 11,448
    edited July 2015
    Cool choices in text though. ©
    Post edited by TJohn on
  • ps1borgps1borg Posts: 12,776
    My last post on another compy was in the text input box on this one, if that makes sense laugh
  • DanaTADanaTA Posts: 13,413
    edited July 2015
    Well, the email notices don't work right.  The link is cut off and turns into plain text.  If you click or copy and paste the link, it goes to a different topic and post, or it goes to an error page.  Once again, not fully tested before being released on us.  indecision
    Dana
    Post edited by DanaTA on
    edited July 2015
    Hmmm...working OK for me so far in Thunderbird.
    Tjohn said:
    Hmmm...working OK for me so far.
    You click on the link in the email and it works for you?  How?  Did you look at my attachment?  The link stops and the next line has part of what was supposed to be the link, but it's not an active part of the link anymore.  I looked and every one I've gotten the link has been malformed like that.  I copied the whole thing and pasted it and that worked.  But not everyone would think of that.  A lot would just click the link.  The last one went to a totally different thread.  The one before that gave an error, topic not found.
    Dana
  • zombietaggerungzombietaggerung Posts: 3,953
    the. new. forum. no
  • kyoto kidkyoto kid Posts: 42,455
    Tjohn said:
    Forumus Interuptus. Not my favorite thing. sad no
    ETA: Sigh. Resigned to getting used to it. frown
    ...your Avatar speaks volumes. wink
    Dana
    Did you see my attachment? My email prog isn't cutting the link name in half like yours is, I don't know why. frown
    edited July 2015
    ...aside from the ones I got while I was asleep (which all give me the error that the page could not be found) haven't received any more email bots for any of the threads I'm subscribed to.  As I understand from the FAQ, there is some kind of limitation in the sfotware in which the link will take you to the first post of the thread requiring manual navigation to the actual post the email is reminding you about. A real bugger in long and fast moving threads or if you have been away for a while.
    ...and FF Spell Check no longer works (real pain for someone like myself so expect a lot of typos)
    ...and my flutterbys don't show up in my sig even though they do in Edit Profile.
    Yeah...
    ...Meh¹º
    Post edited by kyoto kid on
    ABC with the checkmark under it, choose SCAYT (spell check as you type).
    ...thanks.
    ..and it even has a "proper" English dictionary.that works.  yesyes
    Tjohn said:
    Dana
    Hmm...me either.  I might turn off notices and just bookmark the ones I follow.  It seems checking My Bookmarks shows if there are new messages, and clicking on the thread name takes me to the first new message that I haven't seen yet.  Works for me.
    Dana
    Update: the email links seem to be proper now.  They must have fixed it.  I am not the only one who was having that problem.  Still, a dozen emails for a dozen posts in the same topic is a bit overkill.  indecision
    Dana
    IIRC, the same thing (a notification for each post) happened with the last Forum change.
    edited July 2015
    ...still not getting any here Checked spam box as well.  Also cannot find where to set subscriptions back up.
  • fixmypcmikefixmypcmike Posts: 19,731
    At the far right of the title bar for the thread, it's a faint star
    ...on another note,  got another blue screen on the workstation tonight.
    When I first started up earlier this evening, for some reason neither the mouse or keyboard did anything.  Had to do a hard reset after which there was some message about a mouse driver update being loaded. Restrted and everything seemed fin until the BSOD.
    Noted down the number (just the one after the "Stop" statement is needed correct - 0x00000024?), and went to the site on blue screen messages which noted it had to do with something called the NTFS_FILE_SYSTEM.  After that I was totally lost as to what this all meant andwhat needed to be done (not really good at this sort of stuff) IT mentioned both disk corruption and non paged pool memory.  The latter seemed ot have more to do with Macs than PCs.  As to disk corruption it mentioned about SCSI and IDE drivers, however my drives are all SATA III.  I checked the event viewer as was mentioned but I'll be damned if I could understand what any of it meant.
    Well, I got rid of that pathetic avatar...since we seem to have no choice but to have something.  I can no longer be the invisible man.   wink
    Dana
    edited July 2015
    Check your hard drive and RAM
    Post edited by fixmypcmike on
    edited July 2015
    KK, shut down, open your case, carefully pull out the RAM modules, one at a time, and reseat them.  See if that helps.  If your computer has been running hot and you've turned it off, then turned it on later and it gets hot again and you then turn it off, the heating and cooling and heating and cooling tends to cause movement and sometimes intermittent connections.  You could do the same for your video card while you're at it.  Card slots are especially prone to this.  The card will tend to "walk" out of the socket.  It's due to the components expanding and shrinking with the heating and cooling.
    Dana
    edited July 2015
    ...OK....with what utility?
    Utility?  Um...your fingers, a philips head screwdriver or nutdriver (depends on what the cards are held down with).  You are using a box, right?  Not a laptop?  If this is happening to a laptop...take it to a shop.  I wouldn't know what to do with a laptop.
    Dana
    edited July 2015
    ...I wouldn't know what else to look for as I just did a full "clean up" and connection check a short while ago after the last BSOD event. The memory is fine as Computer/Details shows the full 12GB present. If any modules were loose it would show only 6GB as the memory configuration is tri channel. Again the drives are SATA III so they don't use separate cards like the old IDE ones did (and all the SATA connect ions are tight).
    The article did mention running CHDSK.  I may try that tomorrow as it's late, I'm tired, and rather frustrated right now.
    ..and I want the flutterbiys in my sig to show.
  • atticanneatticanne Posts: 3,009
    hmmmm strange
    Well, now I don't know which effing post I was replying to.
    Seems like Tjohn has turned into an old goat.  Did you have a birthday and we missed it?no to this new forum.
    Where are my little green boxes?
    I had more posts when I went to bed.  Got up and I've been marked down to 2600.  Posted once and my total went to 2599.  It may be a long time before I post again.
  • SkirikiSkiriki Posts: 4,976
    edited July 2015
    Hurrr durrr. Morning! Forumpocalypse is still ongoing, I see, and my mailbox sploded while I slept. Yay! Anyway, not to be completely negative, I will give some time to hammer out the problems, not like I've been here every day every hour, so... Someone mentioned a word filter? Let's give it some classical tests...
    Assassin ?
    Pornainen ? (This, btw, is an actual city in Finland, and when some idiots in school put in a filtering software, it got double-whammed on account of "porn" and "nainen", latter which means "woman" in Finnish, and there you go, idiot software vanished a whole city.)
    But perhaps this is more of a Scunthrope thing? (another filtering software trap).
    Edit: Oh wow, passed.
    Post edited by Skiriki on
  • SpyroRueSpyroRue Posts: 5,020
    Assassin ?
    I wonder if Ubisoft forums had issues with the key word "Assassin" in the early days, That would be funny! "Official Announcement: Ubisoft launches the next ********** Creed! WooT!"
    Dana
    If you really don't want an avatar, how about a large white or light grey square instead? smiley
    atticanne said:
    hmmmm strange
    Next month, the 27th. I'll be 62 and starting SS. frown
