MEC4D's celebration ( with freebies ) [commercial]
1…1718202223…84
  • SkirikiSkiriki Posts: 4,976
    MBusch said:
    Are you clicking in the new links or in the quoted ones?
    - Mec4D 80's Gymset G2FMetaData.zip
    - 80's Girls Want Just Have a Fun Outfit
    - 4th7 Dress G3F
    - 4th7 Dress G2F
    These links worked OK.
  • DoctorJellybeanDoctorJellybean Posts: 10,169
    - 4th7 Dress G3F
    - 4th7 Dress G2F
    Thank you! Yep, it were the quoted ones lol.
  • RAMWolffRAMWolff Posts: 10,393
    MBusch said:
    Here is the metadata for the G2F version of the 4Th Dress. In fact, below are the links for all freebies metadata as DIM installers. Just download and drop the files in your DIM's download folder to get them installed with DIM, or if you prefer extract the content manually and drop the files in your Content>Runtime>Support folder to import them using the Database Maintenance function in DS.
    Thanks to Scavenger for making them DIM installable,
    - 4th7 Dress G3F
    - 4th7 Dress G2F
    Thanks for creating this all in one post.. very helpful!
  • D.RobinsonD.Robinson Posts: 283
    Thanks again for the beautiful things you spoil us!
    Daniel
    P.S. I tried to attach the image but i kept getting an error saying it exceeds max file size for my PHP configuration...i have no idea what that means.
    http://www.daz3d.com/gallery/#images/76743/
  • ScavengerScavenger Posts: 2,677
    MEC4D said:
    Thank you Scavenger for the DIM and MBusch for the metadata ! xoxo
    All thanks go to you and MBusch.....people making things. I'm just putting your wonderful gifts into a nice box :)
  • MEC4DMEC4D Posts: 5,249
    It give me a good lough ! hahahaha
    they worked !
    - 4th7 Dress G3F
    - 4th7 Dress G2F
    very nice ! the image can't be bigger than 1MB and max 2000 pixel resolution for forums
    Daniel
    Great team work I guess ! thanks
  • SimonJMSimonJM Posts: 6,102
    Another freebie? You are too nice to use - but please don't let that stop you ...! :)
    edited July 2015
    No worries Simon , I will charge you by the next round (evil lough ) ha ha ha
    Post edited by MEC4D on
    I knew it! You ARE the wicked witch of the west! Hence why you have stayed so young-looking, lmao ;)
    I am the wicked witch from the east my dear ! in west temporary lol working on computer so many hours is like a botox, you don't move a facial muscles for hour it smooth out the wrinkles , funny but so true hehe other story about the butty it kinder square after a day in a chair lol j/k
    These are great, thanks! :)
  • DanaTADanaTA Posts: 13,413
    You aren't wicked! Unless it's, as they say in the Boston area, Wicked Cool! :-)
    Dana
  • nDelphinDelphi Posts: 1,980
    MEC4D said:
    Here some snap shots of the work in progress ..finally happy with the lower parts .. temporary textured with tiles
    that is all you go to see for now :) render in Iray with just HDRI .. 4 seconds ..lol
    A 4 second render for you is like an hour for the rest of us peons. LOL!
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,666
    https://youtu.be/MYypJCHZxZU
    iClone physX
    I had to delete the hem with the geometry editor in DAZ though as it uses UV mapped weighting for the Apex cloth.
    the hair worked nicely as dynamic but obviously drapes
    had to add 18+ as nipple pokethrough :red:
    Not really , if you use the right shaders everything is fast , it took 40 sec on CPU only , for one hour you really need a lot more than par of shoes and pants ;) but I tell you one wrong material and you in the waiting corner
    edited July 2015
    Yeah poke through ! I would use less dense soft cloth would be even better but anyway thanks for sharing Wendy
    I am rendering animation too with all my new freebies ..but with Iray
    Was a first attempt with the dress, a geometry shell to loosen it before export might be needed and more precise cloth weighting using the actual UV shapes instead of just a square falloff map, and better collision proxies, I just wanted to try it out and hair, I actually had a much better sim but stuffed up my save of the collision shapes so had to redo.
    No worries , it was nice to see it in movement anyway
    Can you explain to me what you mean by a wrong material? Or if you have explained already can you point me to the explanation? Thanks!
    edited July 2015
    How closer to physical material how faster it calculate technically mean if the material reflect more light as it absorb it slowdown the rendering time and that can be done easy by having the base color in the wrong values or textures that have too high brightness
    I recommend reading more about on the internet , it may be not so important in the first blink of an eye but it is
    iClone physX
    Blocked...age appropriate and all that. Oh, well. I have enough logins already. Maybe another time I'll get an account there.
    Dana
  • MBuschMBusch Posts: 547
    This is my experience too. Leave any surface with 3Delight shaders to be interpreted and converted by Iray can slowdown the render times. At the worst scenario is better apply the Iray Uber shader on all surfaces. The best of worlds is get all surfaces with correct values on all surfaces. One single surface with incorrect shader can rise the render time a lot.
    The worse scenario is living 3Delight shader when rendering with Iray , it will be converted but lost of a lot of rendering time
  • DikevDikev Posts: 10
    Happy birthday, a little late.
    Thank you for the file.
  • DarkSpartanDarkSpartan Posts: 1,096
    That might be what was killing my computer... A lot of the G2F skins don't have Iray mats, and I don't know how to make them... Yet.
    Each genesis have own Iray setup, just choice the character and click the Iray optimization you find it under Materials not mean The Uber Base
