Adding to Cart…
Hi. You determine the converted Path. Only way it can ever overwrite is if you set it the same.
Got it. Thanks for clarifying.
Hello,
I tried to download the update but it keep on saying 1.5 instead of 1.6. Could you please help me with this problem? Thank you
Hi. How are you downloading it?
First manual but then automatic through Daz Manager. I got "Genesis 3 to Genesis 8 Pose" 1.6 to work but "Genesis 8 to Genesis 3 Pose Converter" still says 1.5. And it doesn't convert the Genesis 8 pose to Genesis 3 at all. Please help Thank you
UPDATE: Okay I'm so stupid and I'm very sorry. I could of sworn I put it the right folder but for some odd reason Daz3d Studio set the pose in my old hard in my computer instead of putting it in my external hard drive. I finally got it to work and the poses work perfectly. Thank you so much for this awesome product and sorry again.
Product has been updated. Some pose sets gave an error code when trying to apply after conversion.
Conversion Scripts now handle invalid (badly written) files that DS would struggle with. Scripts now converts pose sets that contain custom code that previously could not be converted.
G3 to 8 updated to version 1.7
G8 to 3 updated to version 1.6
Zev0 said:
Does this mean I have to re-convert my poses ? I have done the update to the utility.
I just bought this to finally bring all my G3 stuff into the G8 world. It seems to be working fine. I just select the G8F/Poses folder and it finds all the subdirectories and files therein - great. And works through that list when I press the button
EXCEPT
Sometimes vendors put things in the Poses folder that aren't poses. Maybe a camera, maybe a prop, stuff that the pose converter won't be able to deal with. When it hits such a file, the converter just hangs there indefinitely, meaning I have to cancel, clear down the process and start again manually removing the files that have already been converted and the one the converter choked on.
It would be much better if the converter just rejected a file it couldn't convert and moved on to the next one.
ADDED: I've found that sometimes it DOES recognise that a file cannot be converted. But in those cases it pops up a dialog to say it can't convert that file, and waits for you to click OK. Better than hanging, but still not good if you want to pick a stack of directories and leave Daz to get on with converting them overnight.
This doesn't seem to be working. The corrector does but not the converter. When I open up the conversion dialogue and the navigate to the poses I want to convert, the files remain gray and are not selectable. If I try to convert the entire directory, the .duf files populate the window but when I try to do the conversion. nothing happens. I've started it, gone away to do some other stuff, come back hours later and the progress bar remains at zero percent. I've tried uninstalling and reinstalling using Install Manager. I've checked that the files have been installed, and they've all been installed to the proper path.
I can't remember if I've ever used the conversion option before successfully, preferring instead to use the corrector, but there are a number of gen 3 poses that I used regularly with gen 8 and wanted to make them work seamlessly without have to do an extra step.
I've taken a bunch of screen shots showing this process and issue but for some reason, the Daz user forums file attachment option doesn't seem to be working. Images don't upload.
I know this is an old thread, but I have a question about converting poses that were converted from G2 to G3 with your Genesis 2 to Genesis 3 Pose Converter. Is it neccessary to use the forearm locker that comes with that product?
Hi. It is an unlocker, not a locker. Most of G2 poses on the forearm exceed the limits that G3 can do so in order for G3 to match the pose better the forearm limits on the figure need to be unlocked.
I seem to be having an issue with this pose converter. When I run the script. I select my desired pose output directory, select the input director and hit convert. I get a message pop up saying " Error During COnversion. Files must be in a mapped directory to convert properly! Any Files Remaining in the List were not converted."
It doesn't convert any poses at all. Both the output and input directories are subfolders of parent folders listed in the content directory manager in the preferences of studio. Reopening Daz doesn't seem to help, and I've got a blank scene. The Daz log file doesn't say anything useful either. Just says :2023-10-20 17:49:12.723 [DEBUG] :: Error with E:/Daz/Applications/Data/DAZ 3D/My DAZ 3D Library/People/Genesis 3 Female/Poses/Amazon Queen for Olympia 7/Amazon Queen Action 01.duf
Using version 1.7
Does not seem to work on any of these: https://www.daz3d.com/atrilliongames - does not even show the contents of the directory.
Those are all native Genesis 8 poses. Not Genesis 3.
For the other side of the product, converting Gen 8 to 3. The product support icon directs to this thread as well.
For some reason that vendor saved the pose files as scripts (.dse) and not the standard .duf pose format.
oBasePath at line 430 appears to be returning null?
Converting 2 Poses to M:/DAZ-Backup/PoseConversions/Gen3-To-Gen8
2024-07-01 13:37:44.781 [DEBUG] :: sRelativePath = /Presets/Poses/posesGen3/pp0155k-gen3.duf
2024-07-01 13:37:44.781 [DEBUG] :: ======================================================================================
2024-07-01 13:37:44.781 [DEBUG] :: Relative Source Filepath = Presets/Poses/posesGen3/pp0155k-gen3.duf
2024-07-01 13:37:44.784 [DEBUG] :: Asset found in Product "LOCAL USER"
2024-07-01 13:37:53.250 [DEBUG] :: - /Default/Saved Files/Preset/Pose
2024-07-01 13:37:53.254 [DEBUG] :: Compressed
2024-07-01 13:37:53.254 [DEBUG] :: C:/Users/bjc/AppData/Roaming/DAZ 3D/Studio4/temp/d1497
Converting pp0155k-gen3
2024-07-01 13:39:41.030 [WARNING] :: Script Error: Line 430
2024-07-01 13:39:41.030 [WARNING] :: TypeError: Result of expression 'oBasePath' [null] is not an object.
2024-07-01 13:39:41.030 [WARNING] :: Stack Trace:
I took a stab at the cause and parented the figure to "none" (parent in place), so it would be able to find itself relative to the origin, but it still offered me this error. I'm not saving expressions/head poses because my experience has been that they simply don't work at all for anything.
I copied the scene files to the same disk as the pose files and output. No joy.
Any clues? I suspect there's something funky with the directory choices, but I can't see where to choose 'em differently.
I'll have a look through the script, but if I can run into this, others may too.
Thanks
I am using Pose Converter 1.7 Gen 3 to Gen 8. Or more accurately, I'm trying to. I don't know what I am doing wrong but when I go to select either individual files or directories for conversion, the only files that show up are the .png thumbnails. I am not able to see any of the .duf pose files themselves. The files that load into the conversion window I guess are not pose files, the first time I attempted to do it the progress bar did not move at all after fifteen minutes of telling me the files were converting. So I just closed it. I have a couple of your other products that work brilliantly, so I am assuming I am doing something wrong. Any help would be appreciated. Thanks JT
I have the same problem with Pose Builder for G3 & G8. Pose converter works fine for me. I wonder if it's something with our respective computers?
