I'm going to describe a feature Poser has, does DAZ have something equivalent?
Testing6790Testing6790 Posts: 1,091
Say I have a figure in one of the various crouching poses that comes with most mainstream figures (M3/4/5), and I want to make them do the same crouch, but higher. To do this with poser, I just enable IK on the legs and y-translate the hip. Done. I cannot seem to figure out how to do this with DAZ. IK doesn't really change anything (frankly, I don't even know what IK in DS does), and the "lock" options do not actually lock the objects in space.
Does DS have some kind of similar process?
  • fixmypcmikefixmypcmike Posts: 19,709
    Select the Active Pose tool.
    Select each foot and press the space bar to pin it in place.
    Now move the hip.
  • jerhamjerham Posts: 155
    edited August 2012
    Yes, Daz as a similar function.
    How i do it:
    - Select the foot in the viewport
    - Click on the "pin" and check "translation" in the menu
    - If you move the hip the foot will stay (until you move it to far then the foot will point at the its original location)
    Maybe this is also a solution for your issue.
    EDIT: Sorry forgot to mention this menu only shows when you have the universal tool selected in in the tools menu (use it by default).
    460 x 278 - 35K
    Post edited by jerham on
  • Testing6790Testing6790 Posts: 1,091
    edited August 2012
    Thank you! Works like a charm.
    Post edited by Testing6790 on
