Carrara Challenge #65 - Turning Points - Stills, Comics, and Animations Accepted
1234689
  • ed3Ded3D Posts: 2,509
    edited January 2023
    Bunyip02 said:
    ed3D said:
    Diomede said:
    ed3D said:
    And   &  W.I.P.s
    Beautiful stream turning point.  yes
    ~  And Thanx  ,  but the stream ai'nt  really the  Turn Point  +
    First Contact or The Day the Earth Stood Still ? (I spot some UFOs)
    Yeah  ,  there is  ~   ( if  up-loads would catch on )  -  Thanx
    and a few days ago  _   in the Store there's  called   Retro-UFO     +  looks cool  +
    Post edited by ed3D on
  • RuudLRuudL Posts: 226
    edited January 2023
    Stezza said:
    .. what  I do is turn the highlights down from the default 25 to either 0 or 2 or 3 ... depend where I get the slider to.. that helps heaps and I untick GI because I fake it.. devil
    You don't have to use the slider to set a value. Just click the value next to the slider and a numerical input field appears. Now you can enter the value you want. This works with all sliders within Carrara.
    Post edited by RuudL on
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,257
    this yes
    texture tiling etc I type in crazy high values devil
  • StezzaStezza Posts: 8,800
    absolutely correct yes
     I just like to save on keystrokes... I have many saved up but I forget where I put them surprise
    It's fun isn't it Wendy punching in crazy amounts just to see what happens devil
  • Bunyip02Bunyip02 Posts: 9,271
    Next scene - animation WIP
  • DiomedeDiomede Posts: 15,393
    edited January 2023
    Yay.  Looking forward to your animation.  I will be entering an animation as well.  The category goes live with at least 2 entries.  Hopefully, Dart will be able to join in the animation fun.  Fingers crossed that another animator or few will join in who hasn't been able to for a while.  I put an announcement at Carrarators but I don't know if Dudu or anyone saw it.
    Post edited by Diomede on
    Would be great if Dart was able to enter.
    Got to work out how to have a Boomerang flying/spinning through the air !!!
    edited January 2023
    Boomerang Animation done, link now working
    https://vimeo.com/manage/videos/789262503
    Post edited by Bunyip02 on
    The forum is so frustrating.  sad
    Congrats!  Looking forward to enjoying it when the link goes live.
    Thanks !!! First part is a bit shaky but the end worked out how I wanted !
    edited January 2023
    World War 1 - Not only a turning point for history but many firsts as well.
    Tanks introduced to combat.
    Mechanisation of Armies
    Dawn of Air Power
    WIP
    Render
    2271 x 1038 - 765K
    1600 x 1200 - 2M
    WIP2 - Postwork Topaz Adjust, Crisp filter
    Final Image
    WWI.  The battlefield tank, the airplane, a motorized army; definitely a turning point in so many ways.  You are spot on, once again.  yes
    Update Challenge Status
    We are at about the point a normal challenge would be beginning.  The entry thread will close about a month from now (Feb 18th).  Plenty of time for people to get started on a brand new project.  Still images are welcome.  A page of comic panels is welcome.  A short animation is welcome.  Each participant can have up to 6 entries.
    Thanks !!!
    Model T - cars for the masses
    WIP
    Render
    edited February 2023
    And
    1920 x 1440 - 1M
    1920 x 1018 - 249K
    1913 x 1032 - 406K
    1920 x 1035 - 322K
    ed3D said:
    And
    Looking good !!!
    Bunyip02 said:
    ed3D said:
    And
    Looking good !!!
    and  Thanx  //
    edited January 2023
    Bunyip - Model T in the countryside - how fitting!  Well done.
    ed3D - look at that turning path where a stream probably used to be.  Great.  OK, I am just being annoying.  Great to see the ancient alien theorists in a turning point render!  Looks great.
    395 x 354 - 40K
    edited January 2023
    Ben Franklin Confirms Lightning is Electricity
    - the harnessing of electricity was a big turning point.  And attracting lightning was a turning point in potential monster movies - Frankenstein!
    Here is the raw render.  I used an upside down Carrara plant with no leaves to create the lightning.  I will try to clean it up for entry.
    Plants are from Dart's woodlands environment kit.
    1600 x 1200 - 1M
    edited January 2023
    Use Atmosphere Render From MultiPass to Substitute Sky
    I swapped out a generic lightning sky from the web for my original sky.  I will be rendering skies and lightning to use in my entry.  Considering Bryce for the sky.
    1600 x 1200 - 221K
    Thanks !!!
    edited January 2023
    Like the Lightning in this one better !!!
    If you want a sagging rope/string for the kite use Jungle Vines, comes with handy pose morphs as well ! https://www.daz3d.com/jungle-vines
    2276 x 1035 - 319K
  • UnifiedBrainUnifiedBrain Posts: 3,588
    Great concept and perspective, Diomede.
    Fenric's Ivy generator might work well for the lightning.
    There are plenty of Carrara options that will generate at least as good of sky.
    Thanks for the comments and suggestions, @Bunyip02 and @UnifiedBrain.  The original sky with the upside down tree was a Carrara realistic sky with some volumetric clouds added.  The nice thing about including some Multipasses in the render list is that it will be easy to swap out elements.  Here are some of the multipasses.
    1600 x 1200 - 507K
    1600 x 1200 - 118K
    1600 x 1200 - 75K
    1600 x 1200 - 827K
    _  And  then  ,  There is a stream  ,   And  did'nt  think  about  any kind of    Ancient Aliens    And   ,   Thanx
    edited January 2023
    And  some  W.I.P.
    1920 x 1035 - 322K
    1920 x 1014 - 228K
    1920 x 1080 - 874K
    My bad.  I thought the half dome looked like an alien UFO.  I will just stop.  All was meant to be positive.
    Great to see your WIP on how you put your scene together.  yes
    edited January 2023
    No  ,  not bad _  it is UFO ,   just  did'nt  think  of  any kind of    Ancient Aliens  deal-y   _   But  perhaps  it is  +   Homo Erectus M4  is the charecter
     _Thanx
