Carrara Sale Email Message Alert thread
1697072747577
  • 3drendero3drendero Posts: 2,029
    New freebies, includes a big Carrara shader set!
    edited October 2022
    Check your email inbox, you may have recieved a G9 promo mail with a 20$ coupon for one item of some G1-G3 items. Also 10$ off G9 that seems to work in Carrara.
    Post edited by 3drendero on
  • BagboyBagboy Posts: 173
    3drendero said:
    Check your email inbox, Say you may have recieved a G9 promo mail with a 20$ coupon for one item of some G1-G3 items. Also 10$ off G9 that seems to work in Carrara.
    Say what??!  G9 works in Carrara? surprise
    Okay!  I see all the threads now.  Turn my back for a couple of days and the whole world changes!cheeky
  • ed3Ded3D Posts: 2,525
    And which is this set  ?  _   .You mean DP Anime Bundle  in  the Freebies  ,  then  _   .alrite then ,  Thanx
    Yeah, that is the one, two G2 shaders and a hair: https://www.daz3d.com/dp-anime-bundle
  • UnifiedBrainUnifiedBrain Posts: 3,588
    Thanks 3drendero, for the notification!  It didn't show up in the freebies for me, even when I deselected the Hide Items I Own button.  But the link worked fine.
    Is the Daz+ sale now over?  Underwhelming compared to past events.
  • DiomedeDiomede Posts: 15,398
    Yes the Daz+ sale ended just before release of Genesis 9.
    edited October 2022
    Flash sale 90% off V4 items until 2359 MDT. Check your wishlist or grab the skimpiest stuff at 90% off, for example: https://www.daz3d.com/the-clawbikini https://www.daz3d.com/dragon-priestess-for-v4 /Edit, 10 Carrara items are listed: https://www.daz3d.com/hundreds-of-item-savings
  • rk66rk66 Posts: 449
    edited October 2022
    Currently in the Freebies - DP Anime Bundle for Carrara
    Sorry, I see now double post
    Post edited by rk66 on
    Freebie with code today, 1 of 10000 items, choose wisely.
    Great freebie, worth the double post...
    One more freebie with a new code today only.
    Black Friday is on, about 500 items for 3.99 for all and 50% of annual DAZ+.
    There is a big BF sale of the GPU rendering plugin for Carrara. May not support the latest GPUs.
    There are daily Christmas freebies in the main Shop page, keep checking them until 24th. Mixed quality, today there is a G9 clothing item, probably the first G9 freebie from DAZ so far.
    Bennu the Asteroid, today's holiday freebie, is by Fluidos creator and now Daz PA Alvin Bemar.  The asteroid comes with a Carrara preset, including Carrara specific shaders.  Thank you, Alberto!
    https://www.daz3d.com/bennu-the-asteroid
    edited December 2022
    I am having trouble installing the Carrara version of Bennu the Asteroid through DIM.  Getting an error that it needs the location of a program before it can install.  I am assuming it needs to know where Carrara is, but I have that designated in my advanced menu for DIM.  I have double checked that I have the correct installation path for Carrara, but the DIM menu won't accept when I manually try to put path in.  Could it be looking for a program other than Carrara?  Note, I did have a recent drive failure so uninstalled and reinstalled Carrara to a new drive.  My DIM installation for Carrara items is directed to the new location.
    Is this just me?  If so, I will do a manual install.  If it is more general I will submit a ticket.
    759 x 587 - 48K
    767 x 708 - 57K
    Post edited by Diomede on
  • Bunyip02Bunyip02 Posts: 9,285
    I have a custom setup for my Carrara files so I do manual installations of my content. Sorry can't confirm if it's working or not !!!
    Looks like a nice model !
  • StezzaStezza Posts: 8,837
    Daz must of removed the Ca file as I can't get it... neither in DiM or in my account downloads no
    Bummer.  I missed my opportunity to manually download the Carrara files.  Later in the day, I was able to install Bennu Asteroid through DIM, but the file list does not include the Carrara files.  So then I went and looked at the listing in my product library.  There is a spot for Carrara download, but no link to download it.  sad
    1507 x 445 - 70K
    1582 x 763 - 179K
  • damn I never downloaded
  • DartanbeckDartanbeck Posts: 21,988
    You should file a ticket
    yep... I did yes
    Post edited by Dartanbeck on
    Stezza said:
    yep... I did yes
    Me too
    DAZ + members can get this cool Sci-Fi Underground Tunnel, by Mely3D for free, which is really cool!
    Membership is starting to get exciting again with Mely3D freebies coming into it!
    Bennu the Asteroid is Awesome! Thanks Alvin!!!
    Fixed!!! :)
    not quite... mine doesn't install via DiM .. had to manually install it.
    yes.. my DiM is setup correctly yes
    1174 x 856 - 53K
    Post edited by Stezza on
