Show Us Your Iray Renders
Adding to Cart…
You mean ATI, I assume, Spooky? I think you realise that your Radeon users aren't going to be happy?
Grey, nice, candy red stormtrooper. ;)
Iray is an Nvidia product, DAZ 3D has only provided the user interface to Iray via DAZ Studio. If Nvidia adds OpenCL support, then Radeon cards would be supported.
Oh great, so we're back to the dark ages until Nvidia decides to play nice... just lovely.
Thanks Daz and Nvidia - this is a great achievement.
My first render in Iray of http://www.daz3d.com/car-mark
Rendering Time: 42 minutes 25 seconds
Checked in settings both CPU and GPU.
CPU: i7-3770K @ 3.5 GHz, 32 GB RAM
GPU: GeForce GTX670 2GB VRAM
I've got an ATI card but don't feel slighted or put out. I feel more miffed by the Reality for DS that I bought that was such a mess on release - I'm beginning to wonder if it was pushed out of the door before this was released.
I think a lot of people are looking at this the wrong way. It is really a win/win. DS still has the 3Delight render engine, which has been improved if I understand correctly. IN ADDITION, there is the option for Iray renders, which can take advantage of GPU rendering with an NVIDIA graphics card. But, even without GPU rendering, iray will work just fine from your cpu. Even on my anemic computer, I've already done some great unbiased renders, and the speed seems about the same as 3delight. No one is losing anything with this update, and most people are gaining a great deal.
I've been rendering a couple of new Karate girl movies the last month
and this is 2 test shots from the same scene I have been working on in daz 4.7
I used the firstbattalion 10 rooms & 3 halls model with the included lights with it in the first render which i did in daz 4.7
the second render is the same scene using the daz 4.8 with the firstbattalion light set removed and the Iray light presents as a test.
I think it came out pretty good for not knowing what I was doing ..lol a little brighter than the original
I do have to say though this would have been a little easier if i had some basic information on where everything was and how it works..lol so it was more a less a trial and error on this test render.
the top scene took 1 minute 48 seconds rendered in daz4..7
the daz4.8 bottom render took 48 seconds rendered in daz 4.8 with iray light presets
so far so good, :)
Best viewed full size 1920 x1080
I know Wes, but if I had known this in advance I would have opted for a different graphics card in my completely new computer. I think that is what pisses me off the most, since I just got this Hexcore 3.5Ghz AMD with 16Gb of ram and a Radeon R9 graphics card.
Very nice!!
Kat
Very nice! You did well. :)
If you want to try a new trick, you can turn down the Iray light illumination and try turning the surfaces of those ceiling lights into Emitters. :)
Select surface and hold CTRL and apply the Emitter shader (in your Iray content pack)
Then play with the Luminance value til you are happy.
That will give you a different lighting look to try. :)
Kat
I knew that much, Spooky. ;)
I just wish we would have had some heads up on this, since I just recently bought a new PC with a Radeon graphics card. I would have opted for a different graphics card had I (or we) known this in advance. Buying a new graphics card for a completely new unit is out of the question.
Yes! It is an added option for us. Nothing is taken away. It makes use of the CUDA cores in Nvidia cards. It is all about CUDA processing and that is proprietary to Nvidia. DAZ has provided us a fantastic avenue to take advantage of this leading graphics technology. So, yes, it is an ouch for those without Nvidia cards but this is common in computing. Think of Windows, Apple, Linux, Android or Chrome and on and on... you get to make choices and every one of those choices has some limiting factors. It's just computers.
OK I believe you :cheese:
On the other hand, you can't blame NVIDIA for developing a renderer based on the CUDA engine of their graphic cards. Nothing is stopping AMD to do the same with their cards.
I think (based on reviews and benchmarks) that Intel i7 + Nvidia 9xx is the best way to go if you build a new PC.
Peter.
My first two horrible test renders, two Crashes. Don't know if that's my gtx 750 drivers or not.
Nice glass presets, could get something without much tweaking but crashed in the middle
I find the integration inside studio rather good
From a few pictures I found on the web iRay is very capable. Got to read some docs
I just wish we would have had some heads up on this, since I just recently bought a new PC with a Radeon graphics card. I would have opted for a different graphics card had I (or we) known this in advance. Buying a new graphics card for a completely new unit is out of the question.For the last several months, anytime someone posted a "what specs do I want for a new computer" thread, I have always stated get an NVIDIA card with at least 4GB of VRam.
Nothing more that could have been done.
Ah, I see. So, just really bad timing, I can see how that would upset you.
This is not common in computing, this is all about the almighty dollar and trying to corner a market.
I worked in IT for well over 14 years and companies trying to eradicate their rivals is bad for business.
Wes, very bad timing indeed.
Spooky, I used to build these for a living. I'm not about to check every thread made by someone asking what good specs are, when I can build them blindfolded. (entire networks in fact)
Kat
Thanks Kat. for this info :)
Thankfully, I'm poised to get a new machine in the next week or so, so I guess I'll make darn sure I get a NVIDIA card.
Which is annoying, because I'm just now finding out Dell has removed the cool online customization they had 5+ years ago. Anyone know how easy it is to change that kind of thing by calling them/dealing with sales?
(And before anyone suggests it, I am not going to build it myself. I have no experience, and I can't afford the time and money for failing or breaking things outright. I have a lot of friends who always so 'build it yourself! You save so much money!' and then I look at sites with motherboards and whatnot and I'm a cat looking at calculus going MEOW WUT)
Is Iray working well for older machines?
My currect specs:
Intel i7-2600, 3.4 GHz (8 CPUs), 8 GB RAM, Win 8.1 pro 64 bit
GeForce GTX 555, 4 GB memory
I'm nervous about going to a cutting edge beta version that might be a little beyond me...
Thanks for the info. Don't be sorry if that is a Nvidia bug. It means that there is a chance that it will be corrected at least. And I'm more pleased than unhappy right now
Those specs should be fine, the only thing you may want to consider is adding ram. No need to buy a higher spec unit when the current suffices.
Lots of playing around and learning to do. Instead of trying to convert maps based on the spec/gloss model, I just exported some physically based ones, plugged them in and worked from that.
Greetings,
Oh!That's my problem then. I submitted a bug report; I'd used the Scene Builder to build a trivial scene to test with (actually I had been testing UE2 vs. AoA Ambient just a day or so ago, so this was perfect timing!) and the scene I used (secret somethingorother) has ivy on the wall behind her!
I'll try a different scene, 'cause I was getting sad that it froze every time I tried to render, on both my Windows and Mac boxes with CPU-only rendering... Makes me feel better that it's a known bug, and one that I can work around.
Does this mean that some hairs will be...problematic also?
-- Morgan
Your grapic card will have the greatest impact. If I look at the specs, a GTX555 has 288 CUDA cores and only 1Gb.
Something like the newest GTX970 has 1664 CUDA cores and 4 Gb (while consuming slighly less power than your GTX555).
The CUDA cores are directly linked to performance, the more cores, the faster your render.
Peter.
My computer makes your computer look state of the art. My Iray renders are slightly longer than they would have been in 3delight with UE2.
Legs...
http://youtu.be/eUDcTLaWJuo
street of asian rendered in 4.8 using the Iray using just my graphic card. not 3d light.
I over clocked my nivida cards by 20% and added a light blue distant light to try to make it appear a early morning scene
I got these weird mesh lines through out the render
over not bad it took 1 minute and 54 seconds to render totally off my GPU
if i can get rend of the mesh lines this will be a heck of lot faster for animation
best viewed full size 1920 by 1080
