Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
    • Creative Tools
    • AI Scene Enhancer
    • Generative Credits
    • Enterprise Tools
    • Synthetic Training Data
    • Physical AI
Download Studio
Notifications
Loading...
    • Categories
    • Recent Discussions
Updates - Daz to Blender
Daz_BryceDaz_Bryce Posts: 12
June 2021 edited June 2021 in Blender Discussion
Daz To Blender Version 2.3.7
General Updates
  • New export logic
    • Will check if node found is a character; if not it will export as environment/prop
    • Will also unparent and reparent grouped characters
  • Able to export Genesis and Genesis 2 figures as characters
    • Does not support Genesis 1 and 2 skinning method will automatically convert weights
  • Fixed offset
    • Some morphs will translate skeletons now it will take that account in fixing skeletons
  • Added figure data to DTU
  • Code refactor updates
  • Added several morph presets to simplify export process
  • Added a Refresh Button on dropdown to reload the dropdown menu if character is missing
Morph Updates
  • Fix the ErcMultiply execution in Blender to have it apply correctly
  • Added the option to disable morph links during export
    • Fixes multiple morphs on one controller
      • For example; Surprised morph for Genesis 8.1 is made of multiple morphs, now it will export them separately as the default option
  • Updates to driver additions to match better with Daz setup
  • Add a new function to bulk remove the morph prefix
    • Choose your asset in the dropdown, and then run
Rigify updates
  • Moved rigging to its own panel
  • Fixed error with face not following when morphs are on the import
  • Add an option to collect textures
    • This will include paths of all the external textures in the dtu
Bug fixes:
  • Fixed Python error Runtime error (change of figure size) during Iteration
  • Allows the bridge to skip over FBX error; in some cases the script will fix errors in the FBX importer
  • Fixed “TypeError” issue when importing a character with hand and leg JCMs to the Blender
Reminder: If your run into any issues, please reach out through GitHub at https://github.com/daz3d/DazToBlender/issues
Post edited by Daz Jack Tomalin on June 2021
  • Daz_BryceDaz_Bryce Posts: 12
    June 2021
    Daz To Blender Version 2.3.9
    Morph Updates
    • Created a controller that allows morphs that are being manipulated to also still be independently controlled (only for visible, non-hidden morphs)
    • By default, the morph prefix is removed, but an option exist if you would like to disable it
    Morph Optimizations
    • Deleted morphs that shouldn't have been included on the children objects (i.e. morphs that use a logic of checking if the figure has the bone, an alias, or the morph itself on the children object)
    • Deleted morphs that don't exist in Daz but still export
    General Updates
    • Multiply the 2nd Stage Drivers by zero (if first stage does not exist)
    • Solved an issue where some versions of 2.83 and 2.92 fail
    • Consolidated the settings under General Settings and renamed to Import Settings
    • Allow users to disable the viewport changes for the display settings
    • Optimizations made to check if bone is weighted before adding it as included mesh
    August 2021
    Daz to Blender Version 2.4.0
    Bugs Fixed:
    • Poses not working on Root Bone
    • Poses being applied correctly when multiple characters are being exported
    • Male facial rig broken when using Rigify
    • Dropdown added in Morph List allowing the control of morphs for multiple characters in one scene
    • Option to Refresh the Dropdown in the morph list to allow the reopening of blender scenes with the morphs still being available
    New Features / Additions:
    • Support for importing multiple figures with morph list work
    • Dropdown to choose between different figure's morphs
    • Option to customize Export Path for Blender, allowing you to move where blender exists
      • 1. Go to Import Settings
      • 2. Check use Custom Path
      • 3. Choose the folder that you wish to use
    • Allow Collect Textures to work relative to user's export (sharing of export files between computers)
    • Can now disable remove incompatible nodes during export
    • Can now disable morph optimization
    Updates to Support Figure Compatibility:
    • Changed the Figure export logic allowing more then just Genesis Characters to export in that method
      • This will allow export of any asset as a figure if the type is Actor/Character
    • Basic Support for DzLegacyFigure
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
