Ultratree system questions
1235»
  • golem841golem841 Posts: 181
    I don't know where to post, so I try here :
    I'm going to buy any update for this outstanding and simple to use ultra tree script
    More trees from Northern Europe, please !
    I have 2 other requests :
    - is it possible to add a roots option?
    - I would love to be able to determine the height of the beginning of branches on the trunk
    Thank you for this outstanding product.
    I just lack a simple terrain generator and I could dump Eon/Vue !
  • RandomRandom Posts: 224
    edited May 2021
    I tried saving an UltraTree tree as a support asset prop, resulted in tree without leaves. Any way to do this? -- edit: Works as a scene subset, however, but better if it could be saved as a prop.
    Also, would love to have the ability to scale the lower trunk wider like an old growth tree.
    Post edited by Random on
    I've never had any problem with anything saved as a scene subset. If you want to use it outside of DS tho, there will be a problem ;).
  • AHArtAHArt Posts: 202
    edited May 2021
    I have had problems saving scene subsets and them working on seperate PC's (with all the product files available)
    Post edited by AHArt on
    When you are saving as support asset, you are in effect creating a new product. Many have botched their content libraries by doing that, ending up with multitude of conflicting files.
    Scene subset is whatever you want it to be.
    Scene subset is the way to go then. Thanks all.
  • thedoctorthedoctor Posts: 201
    Hello all.
    When I run the UltraTreeCreator script the dialog opens but no trees appear for me to select. (see below):
     I've tried uninstalling and re-installing several times to no avail. Any thoughts?
    749 x 609 - 44K
  • barbultbarbult Posts: 26,414
    thedoctor said:
    Hello all.
    Did you install with Daz Connect? Lots of script-type products don't work if installed by Daz Connect. Try installing with DIM (Daz Install Manager).
    edited June 2021
    barbult said:
    thedoctor said:
    Hello all.
    Indeed, I did install via Connect. That was the problem. I wish Daz would either fix this or remove these items from Connect. I like the convenience of automatic updates via Connect, but I'll probably go back to DIM for everything.
    Post edited by thedoctor on
