"There's Always Another Sale™" (Report sales issue here.)
134689100
  • Griffin AvidGriffin Avid Posts: 3,822
    edited July 2020
    Here.
    1319 x 896 - 175K
    1864 x 890 - 2M
    Post edited by Griffin Avid on
  • Cris PalominoCris Palomino Posts: 12,554
    Let's start here. I see three new items. I then see more than the two you would get for free. Are the other items also from that same selection?
    So I tried a cart. With three new and two from the selection, the two are free. I put in a third, and it spread out the amounts, none free. So, the recommendation is do the deal separate.
    808 x 734 - 77K
    Confirmed. Anything else from that list breaks the deal.
    I was able to add from the 60% off cat as well as the featured stores and it doesn't interfere with the free items from the one cat.
    Seems the "60% off for featured artists" when having any new item in the cart part of the "Take your medieval up a notch" sale isn't working any longer.
    And it's the same for the "50% off featured artists" when having any new item in the cart part of the Kayo sale.
    Reported
    Should be fixed.
    Should be fixed.
    Medieval seems ok now, but Kayo still isn't going from 40% to 50% with a new item it seems..
    Should be fixed.
    I added one from the featured stores in the Kayo sale and it went to 50%. You may have to do a ticket; could be a specific item problem.
    Should be fixed.
    I tried several items from several shops of that sale and none worked. And for a ticket I guess I first would have to buy something?!? Which isn't really what I would intend to do. I'd prefer to shop to work properly without having to use tickets devil
  • Charlie JudgeCharlie Judge Posts: 13,283
    Should be fixed.
    Are you using a PC+ itema as the trigger? The extra discount seems not work if you are using a PC+ item as your new item; but does work when a non PC+ item is used.
    1690 x 790 - 142K
    Should be fixed.
    Ah, yes... that seems to be the culprit.. which makes it more interesting, as "all new items" doesn't exclude PC+ items (except for these getting the addional 10% off of course, as THAT is stated in the small print).
    Should be fixed.
    Yes, usually when it states 'any new item' new PC+ oitems have worked. Now that we know the problem maybe Cris or some other mod can report the problem.
  • Pax AsteriaePax Asteriae Posts: 457
    edited July 2020
    In another case of The Amazing Vanishing Sale Items, dForce Operator Hair is listed as an option on the "Select Sci-Fi Items: Buy # Get # Free" list (smack in the middle of this screenshot), but when you try to open the page, there's a 404 error as it's apparently no longer in the store, making it a littttle hard to add to the cart. wink
    Scratch that, it's back now. O_o
    1448 x 525 - 150K
    1920 x 1009 - 145K
    Post edited by Pax Asteriae on
  • LeanaLeana Posts: 12,803
    It's still in the store and the link works for me. Might be one of those intermittent display bugs which don't affect everybody...
    You can add it to the cart directly from the carousel, btw, using the little cart button on the thumbnail.
    Yeah, it's back now, but it very definitely wasn't there before. I don't know why I try to understand the store software, it never works. frown
  • L'AdairL'Adair Posts: 9,479
    Whenever I get a 404 page for a product I'm fairly certain still exists, I try adding a "/" to the end of the url. That usually brings up the correct page. I have no idea why. Logic dictates that all urls should work without the "/" or all urls should require the "/" to work. This intermittent requirement puzzles me. But it's worth trying the next time a link in a sales promo leads to a 404 page.
  • SevrinSevrin Posts: 6,313
    edited July 2020
    Can anyone spot the differences between the promos for these items?  The video linked in the decription is always the same thing.  How does QA allow this?
    859 x 355 - 99K
    Post edited by Sevrin on
    This might be worth a trouble ticket to get an answer. Vol 2 has the same promos, too.
    Assuming each volume has different animations, (and they should,) seems like it would help to sell the product to create unique promo images for each product, using animations from the package they are representing.
    The "what's included" list is different, at least.
    edited July 2020
    Different, but not terribly enlightening.
  • XelloszXellosz Posts: 855
    Any info on the "We Miss you!" banner how long is it valid??? There is no expiration date on it.
  • mr clammr clam Posts: 707
    Anyone else having trouble with the banner discounts? I can't seem to get the $5 one to work
  • barbultbarbult Posts: 26,292
    edited July 2020
    It worked for me. Mine was FIVES-AROUND. It sounds like there might be different ones???
    Post edited by barbult on
    Spuggles Special Edition (inactive >> TEST CONTENT)
    Get a test server and don't play with the store :)
  • butterflyfishbutterflyfish Posts: 1,493
    I had the same one as Barbult, and mine worked.
    Have the same one as Barbult, too, and mine isn't working...
    edited July 2020
    Am I doing something wrong? I haven't used it yet and I only have one item in the cart.
    738 x 275 - 54K
    Post edited by mr clam on
    It works for me on that item. Since it seems to be a limited problem you may have to submit a ticket to CS.
