Novica & Forum Members Tips & Product Reviews Pt 13
11314161819100
  • FishtalesFishtales Posts: 6,233
    A few more Iray conversions.
    Tractor F9n
    2020-04-23 07:47:29.984 Total Rendering Time: 58.62 seconds
    Click on image for full size.
    Trailer
    2020-04-23 08:26:48.453 Total Rendering Time: 45.29 seconds
  • Robert FreiseRobert Freise Posts: 4,700
    Looks good
    I had forgotten that I had those
    Bring Home The Hay
    2020-04-24 22:09:27.638 Total Rendering Time: 1 minutes 32.90 seconds
  • NovicaNovica Posts: 23,925
    @fishtales  I like what you did, I hate those bales of hay though. They look like compact plywood to me. There's not a single straw out of place and no real hay straw lines (long straw sticks.) Just not the type of hay bales I'm used to seeing around the horses.
  • EtaminEtamin Posts: 129
    edited April 2020
    @fishtales That rather reminds me of our first tractor, a grey Massey Ferguson - not quite the right shape, but grey, old and rickety, just the same.
    Post edited by Etamin on
    Yeah this model's based off of the Ford F9n manufactured from 1940 - 1950
    The Massey Ferguson TE20 looks very similar
    https://en.wikipedia.org/wiki/Ferguson_TE20
    I know, I thought that too. It was the best I had though :)
    It reminded me of this only in a block :)
    https://www.roofinglines.co.uk/product/osb-3-oriented-strand-sterling-board-8-x-4-2-4m-x-1-2m-x-18mm?gclid=EAIaIQobChMImenGz4OD6QIViu3tCh2vuQFgEAQYAiABEgJ6D_D_BwE
    I used to gather up baled hay as a kid and then put it in the barn for storage over winter so I could feed our landlord's cows. It would cause me awful asthma but there is actually treatment for that now via allergy immunotherapy which I'm getting now for the next 3 years. That house we lived in was full of rats! I guess the house was build too close to the barn.laugh
    Regarding hay bales- anyone see any more than these?
    Harvest Hay Bales seems too sticky for me, some of the hay straws are too thick/stiff.
    Farm Gear doesn't have the stickies, but at least there's some straw lines in the bales.
    FG Barn looks good but it's from a distance so don't know  same with i13 Modern Barn
  • 3Ddreamer3Ddreamer Posts: 1,357
    edited April 2020
    Barn Yard - though they are like wooden blocks
    Horse Stable Props
    I think I have some free ones I picked up for this very reason, will check when I get on my Render laptop...
    Okay this isn't going to be allot of help unless someone can find the links but I have ones in folders called
    DNA Halloween, (freebie from RDNA, probably no longer available), Haybale, SquarePeg3D. All in Poser format
    While trying to find links I also came across
    https://sharecg.com/v/63814/browse/5/3D-Model/Hay-Bale
    https://www.cgtrader.com/3d-models/haybale
    https://www.turbosquid.com/Search/3D-Models/haybale
    Post edited by 3Ddreamer on
  • RGcincyRGcincy Posts: 2,864
    edited April 2020
    The best I found in my stuff: i13 Modern Barn Environment
    It's the hay bale detail
    800 x 640 - 272K
    Post edited by RGcincy on
  • gitika1gitika1 Posts: 948
    edited April 2020
    Backwoods Shooting Range for Genesis 3 and 8 Male(s) and Female(s)
     French Cowshed
    The selection of hay to use is unappealling.sad
    From back to front/left to right
    I13 - Oreste
    Pred - ArtCol
    Deepsea - Backwoods (DS)
    A ROG level of detail barn with props would be awesome!
    1054 x 896 - 2M
    Post edited by gitika1 on
    edited April 2020
    @3ddreamer  One of those on cgtrader looks pretty good- the $7 one. The 27.30 one is of course the best, but I'd rather do postwork than fork out $27 for a hay bale!
    Post edited by Novica on
    gitika1 said:
    Thanks for mentioning that one- that bale looks good!  (and for showing the others.)
    @Robert Friese thanks for that link - sent me down a rabbit hole of nostalgia :)
  • chris-2599934chris-2599934 Posts: 1,978
    edited April 2020
    A character study for a project I'm starting.
    The second woman from the left is FWSA Safa HD pretty much straight out of the box, wearing the 9 to 5 Dress Outfit with some minor tweaking. The other three are all Freja skins (Mikaela, Alfhild and Sara left-to-right) but their shapes and outfits are kitbashed together from innumerable products. I've had a lot of fun digging through my runtime mixing and matching items, it helps me understand why it takes my girlfriend so long to get ready sometimes!
    Poses are mostly from Stand Tall for Monique 7, which is great for general standing-around-not-posing-for-the-camera stuff. Lighting is from iRadiance Light Probes 4.
    1200 x 1200 - 246K
    Post edited by chris-2599934 on
  • memcneil70memcneil70 Posts: 6,106
    @chris-2599934
    They look great. And I can instantly tell what they do, based on clothes, which all look like they were designed to work as outfits, not kitbashed. Thanks for reminding me of that pose set, I found I have it. Need to make sure I have moved it up to Genesis 8 use now.
    Mary
    If you haven't used your PC+ coupon for the required $18 one, you can pick up the Luxury Limousine Bundle. It's $18.38 so take $6 off and it's 73% off at $12.38. If you don't use it on that, you may find something else. It's getting near the end of the month :)
  • Charlie JudgeCharlie Judge Posts: 13,629
    And if you have used it but still want something from the flash sale don't forget that the PLATINUM-PERKS coupon for an extra 20% off is still useable multiple times.
  • HylasHylas Posts: 5,333
    I don't think the i13 Modern Barn bale looks great up close.
    I personally like the one by SquarePeg3D: https://www.renderosity.com/mod/freestuff/bale-of-hay---100-free/79103&ca
    I think I'd like to see a lot of common fruit & nut trees modeled in the DAZ 3D Store. I know there is an apple orchard and I have it but that's actually the only such I've seen. OK, I know it isn't going to happen unless I learn to model well enough to make those myself. I mean who's looking for American persimmon or American paw paw trees for their DAZ renders anyway? I just spent $750 today on 22 new fruit & nut trees to add to my yard. I have 4 more fruit trees to go and then my yard is full. I'm so excited to be wrapping up the main plans for my mow-free yard of the future! smiley And you guys thought your DAZ 3D content libraries could get out of control! laugh
    Fruit & Nut trees products in the DAZ 3D Store? Have I missed them somehow?
    edited April 2020
    Did you all pick up the Soldat Outfit and textures?
    On both the front and the back of the jacket, the texture has what looks like the guy would have spilled something on his jacket and tried to wash it off.  Although, how he would have spilled it on the back of the jacket ...
    I made an inquiry and was told that those spots are in the promos as well, so it must be intentional. surprise I guess I am getting more nit picky the larger my library becomes.
    390 x 579 - 433K
    366 x 526 - 357K
    405 x 466 - 323K
    edited April 2020
    Yes, it makes a nice starting point, thanks for pointing it out.  It isn't good at all up close either though in the lighting I chose, and lighting can make a big difference.
    So compare these three.
    Default SquarePeg3D
    Plus 9 bales of SquarePeg3D Scaled / Layered On Top Each Other
    Closeup, 10 bales Scaled / Layered On Top Each Other, closeup.
    800 x 600 - 1M
    800 x 600 - 1021K
    800 x 600 - 1M
    edited April 2020
    A Better Bale of Hay
    See closeups/explanation in the above post.
    I'm going to be a real team player :)  and give you the settings for every single bale of the ten, so you don't have to take an hour and a half to figure them out. Then you can tweak from there. You can easily bring some of the bales in toward the middle to shorten the straws. I kept the strings hidden, those should only show on the top and bottom of the bale (which isn't seen.) If you rotate the bales, make SURE there are no strings on the side of the bale.
    The settings will be as follows- the X, Y, Z translations/  the X, Y, Z rotations/  SCALE, then  X, Y, Z Scale. An X means don't bother it. In other words, these go straight down the line in your Parameters Tab. I'll identify Scale for you so you know you're where you should be.
    4.81   15.94   -1.54  /  x  x  x  /  (91.5 Scale)  x  x  x
    28.19   47.05   -3.04  84.93   x  -0.20  /  (58.6 Scale)  x  x  x
    0.60   14.91   0.030  /  0.20  x  x  x  /  ( x Scale)  x  x  x
    -23.06   52.05  -5.19  82.60  -0.97  x  /  ( Scale 56.2)  x  x  x
    -76.08   48.72   5.16   -7.41   -2.71   -94.27  /  (x Scale)  40   127.1   93.3
    40.44   50.88   -11.07  -1.77   x   -87.12   (x Scale)   31.1  44.7   56.4
    23.12   43.82   -2.36  x   82.15   -81.28   /  (74.5 Scale)  62.7  x   x
    0.60   18.48   -9.02  /   x   x   x   /  (x Scale)  93.3   90   79.5
    -0.21   29.55   24.09  x   x  x  /  (x Scale)   x   73.4   16.7
    11.68   -4.33   4.02  x  x  x  /  (x Scale)  81.3  x   x
     BTW, you will need to scale your men up to 150.8% (or so, depending on the man)  for a hale bale to be the correct proportion to real people. The bale is WAY too big.  Even doing that, I scaled the bale down to 84.6 % and the Z (width)  was WAY too wide, so I put it at 88.4%.)
    Newbies- TIP:  you select your bales in Scene then go up to Create> Group and create a group. Then you drag all the bales under the first bale, so whatever you do to it, you do to all of them That's how I was able to Scale everything down to 84.6 and 88.4 percents.  Then when you move the bale, all the ones embedded it in will move, too.  And when you're creating a group, you can still select each one and fiddle with them, they remain individual props.
    Compare this hay bale with the ones in the background. I think those look like squares with patterns just printed on them. No hay bale in my experience, no matter how compressed, is completely lacking sticky hay straws.
    655 x 900 - 1M
    edited April 2020
    Intentional or not, those look worse than just "wear."  It isn't being nit-picky, that should be OPTIONAL as a material, not the default.
    edited April 2020
    What was the best deal you folks got on Alana? With the 30% promo  BETTER-30  you can get 30% off instead of that extra 20% that was in the purple banner.  Then going into stores that are 60% off, that makes it a really nice price. (Keep all these 10 items or less. Do the 4 Alana Add Ons to drop the price, then that 30%.)   So is this the best deal?
  • firewardenfirewarden Posts: 1,488
    This is what I paid on the day that she was released. Wish the coupon didn't exclude rebuying items for less...
    Alawa 8 Pro Bundle - $37.03
    Alt Alawa 8 - $7.43
    Yve for Alawa 8 - $5.20
    Alawa 8 HD Add-On - $10.97
    Retrospace Personal Quarters Scene Kit -  $5.48
    Rescue Equipment -  $0.05
    Fire Truck - $0.08
    BEAR-290 Heavy Combat Set - $0.05
    Emergency Hospital - $0.09
    Sci-fi Control Panels - $0.06
    Total: $71.91
    You're getting a better deal. Happy for you!  Luckily for me, there is always another sale. ;)
    edited April 2020
    https://www.daz3d.com/beautiful-nature-trees now in fast grab has a lemon tree. Also a lemon tree here:  https://www.daz3d.com/the-private-garden  I feel almost positive that I once purchased a small orange tree but now I can't find it in the store.
    Post edited by Wonderland on
    But with a limit of 10 items you miss out on the Daz O freebies...
    It must feel like being in the middle of a war zone under those thunder storms.
    http://en.blitzortung.org/live_lightning_maps.php?map=30
