Show Us Your Bryce Renders Part 11
11516182021100
  • adbcadbc Posts: 3,115
    Horo : Fantastic abstract.
  • HoroHoro Posts: 11,658
    Thank you Kerya, mermaid and adbc.
  • HansmarHansmar Posts: 3,209
    Horo: wonderful abstract!
    edited February 2020
    I created a terrain from the DTE, but modified it in the terrain editor. Had to use quite a high resolution to get it a bit smooth. Used a HDRI enhanced sky by Horo and David Brinnen.
    I call it 'Left in the desert', because some people left some equipment to rust or erode.
    1754 x 875 - 1M
    Post edited by Hansmar on
    Hansmar - very well done. Terrains made in the DTE can be up to 4096 but they are still only 8-bit. You did an excellent job smoothing out the steps, lighting also helps.
    Hansmar : Excellent image.
    4 terrains all the same basic image, each terrain modified in the TE, all have the same material. Just a desert scene.
    940 x 450 - 104K
    Post edited by adbc on
  • mermaid010mermaid010 Posts: 6,245
    Hansmar - well done, beautiful desert landscape.
    Adbc - your desert scene is beautiful too, love the texture.
    A Still using a Hdri from the Golden Lighting set and Wings 3D objects.
    700 x 525 - 95K
    Post edited by mermaid010 on
    adbc - this desert scene with the buildings looks superb. Great idea, well done.
    mermaid - very nicely done still, good lighting.
    mermaid, Horo : thank you.
    mermaid : very beautiful image, awesome colours.
    Thanks Horo and Adbc
    Horo, adbc, Mermaid010: Thanks for your kind remarks.
    adbc: your terrains look very interesting with the mixture of terrain and buildinglike items.
    Mermaid010: Very nice lighting indeed. And nice difference in texture , though I prefer the shiny one.
    Hansmar : thank you.
    Thanks Hansmar
    edited March 2020
    I experimented with photographs from cloudy skies to create terrains. A bit labour intensive but interesting terrains can result. Here double stacked, the sky is a combination of Cumulus and HDRI clouds.
    Sunlit Crags
    1200 x 660 - 137K
    Post edited by Horo on
  • Electro-ElvisElectro-Elvis Posts: 948
    edited March 2020
    This image is called "Seduction and Contempt"
    It was made with Genesis 1 character "Addison". Light comes from an IBL and 3 sphere lights. Rendered with TA 64 rpp with Maximum Ray Depth 4 and a second blob render of the glass with 12.
    619 x 825 - 421K
    Post edited by Electro-Elvis on
    Electro-Elvis - this looks great, excellent and great use of DOF.
    Horo: very interesting terrain. I assume you will describe the process somewhere?
    Electro-Elvis: Very beautiful render.
  • SlepalexSlepalex Posts: 911
    I understand that the render in Bryce is not inferior to many advanced renderings. And the ways to illuminate the scene are sometimes superior to those in other programs. The only drawback is the time.
    Horo : The used method gives a very nice result. Excellent image.
    Electro-Elvis : very nice render, the expression on her face says it all.
    edited March 2020
    Hansmar - thank you.
    The process is simple. You need some graphics program, I used Photoshop but just tried it with the free GIMP 10. Load your coloured cloudy sky (or any other suitable) photo and cut it so that only the part you want remains. Change Mode to 16-bit per channel and then to Grayscale. Look at the Levels diagram and if there is no data at left (0 black) or at right (255 white) you may adjust to get the range stretched. If you want to remove gamma, you move the centre value from 1.00 to 0.4545 to get the image data linear. Resize this image to e.g. 4096 x 4096 and apply a Gaussian blur filter with a radius of about 2.5. Now downsize to 2048 x 2048 and save - you can downsize again to 1024 x 1024.
    The cloud photos I found in my originals were made with the old DX camera at 3000 x 2000 pixels, no need going over 2048; therefore: double size, Gaussian blur and then down scaling.
    Sometimes the terrain looks better with gamma 2.2 than without (I kept both versions and put them in the Objects library).
    adbc - thank you
    Simple? For you probably, but I fear I will need to read it multiple times. Nevertheless, I might give it a try!
    Horo - beautiful,  interesting terrain. Thanks for the Know-how info smiley
    Electro-Elvis- A superb render.
    edited March 2020
    Hansmar - writing it up makes it more complicated than it actually is.
    mermaid - thank you.
    Another example of clouds as terrains. I may bore you with more. I made 10 in 4 variants: 1024 and 2048, with and without gamma.
    White Cliffs
    1200 x 780 - 180K
    Horo : Beautiful image, very interesting method, not boring at all.
    Another beautiful landscape render Horo
    edited March 2020
    adbc and mermaid - thank you.
    Slepalex - two very beautiful landscapes with flowery foregrounds.
    Another example of clouds as terrains. Two terrains and one overlain by another three partly transparent ones with the flowers.
    Stony Hills
    1200 x 795 - 347K
    Wow Horo, another superb render, are the transparent flower layers from the Vegetation set?
    Slepalex : two outstanding images.
    Horo : Excellent render.
