*closed* RRRR - "Build it and they will come" Render Contest
Totte
The RRRR is back from a summer filled with Shakespearian insults, and this round will be a normal RRRR Rould. The theme is Build it and they will come.
RRRR stands for Random Runtime Roulette Renders, and it's a content that has been running for over five years and we invite anyone to enter. This is not the usual "make a very nice render contest" but more like "tell a really great story, often fun, with your render"!
We will not add any twists now, but the twist is, a twist, or several, might be added along the way. See it like a TV series or movie plot twist, suddenly something happens that turn things around, shake it up, put things in new lights, you now what I mean. So, suddenly, or not, a contest twist might, or might not, randomly or not, happen or not. That twist, if it happens, might or might not, add something fun to the rules.
TWiST #1 (2019-11-05)
Any pulls from now on, until further notice - you can replace one pulled item with a character used in a previous RRRR entry from a previous RRRR contest. You should link to the previous entry in you entry in the enrties only thread.
So now it is "xxxxx built.... "
How does it work?
Make your pull of 4 items, pull your LBs (Luck Bastards), the current lucky bastard standing is below, and make some great and fun images, it’s not harder than that.
Who can play?
Anyone can play!
How do you prepare yourself for play?
The rules are very simple, but first you need to have all your items in some kind of order in a text file, dumped from the itemized history into a text file or a spread sheet. Remove things like software, gift certs, and special plugins from the list.
Then you use a randomizer to randomly pick items from your list (your Runtime/My Library) for your start pull . You can use items from any store.
Randomizer that works well:
Random Org
Randomizer where you get all numbers in one draw: random
There are some situations where you allowed to redraw, these are:
- You picked something that doesn’t work, broken thing, only works in a version / software not used etc etc.
- You picked a software or add-on to a software or anything you should have filtered out from the list.
- You picked only huge environment props and will not be able to render a scene without crashing.
- You picked an item you already have been using in two RRRR renders in this content and that was picked randomly. Three is a curse - rule!
Lucky Bastard Rule!
If you have sticky lucky bastards, you pull one extra item for each LB you have, simple as that.
Explaination of Lucky Bastards.
Lucky Bastards, or LBs, are a form of handicap system which makes the contest a little more difficult for those who have won.
Current Lucky Bastard standing
Recalculated with everyone, including non-participants, dropping off as last contest didn't use them, only "two lucky bastards" here.
Player |
Current LBs |
Totte |
2 |
Luci45 |
2 |
A reminder about the LB thawing rules.
(1) You will never pull more than 7 LBs, even if you have 12, never pull more that 7, seven is the number you never pull more than.
(2) You always lose half of the new LBs at every thawing (between rounds), this is to prevent the LBs from being too sticky.
(3) You need to make at least one entry for thawing to be in place.
How to play?
You pull, you compose and you Render. You post your images and pulls in this thread, but the entry should be posted in the Entries only thread
Bundles
If you pull a bundle, use two three complete items from it, or more if you like, but you do not need to use all, but only picking a hairpin from V4 Complete Bundle is “too little”. Clarification: A bundle still counts as only one pulled item.
Poses, Expressions and textures/colors
If you pull a pose pack, an expression pack or a texture/color pack, you only need to use one of them, not all. For example if you pull 500 expressions for V4, use one, if you pull 128 colors for Frappe Hair, use one.
Accidenty breaking the TOS
If your entry is removed by the forum mods because it accidentally, not deliberate, broke the TOS, you do not have to redo that entry but can move on and make a new pull.
The rules of madness!
Now you have successfully and randomly picked your items, make a scene, you can add other items as well but the one you picked should be prominent or cleverly used. Render it, post it and make us all laugh! Remember though that the renders must follow the TOS of the forum. As we have a theme on the contest, the render should in some way touch that theme.
The contest categories!
There are two categories Best and Funniest. Every image will compete in both categories.
Contest duration!
It starts now at Sunday October 20 2019, and will go on until Sunday December 15 2019 at 23:59:59 local DAZ time.
Yes, we have prizes, thanks to our sponsors!
This months sponsors so far:
Totte (Code 66) is sponsoring with two items from his store
Luci45 has contributed with $25 DAZ GCs.
RRRR is looking for more sponsors, so if you're a PA or just a happy person, please consider sponsoring, and sponsors can play for keeps remember.
More to know?
I will edit this when new info on sponsors arrive.
Do you want to sponsor the RRRR?
Please chip in, sponsors can play, they are even encouraged to play! Sponsors also can vote.
Maximum number of entries?
I think for this round
List of some previous RRRR Contests
In the PC Members Only forum:
RRRR Summer Edition ( 13 June 2012 - 15 July 2012) http://www.daz3d.com/forums/discussion/2065/
Winners Thread: http://www.daz3d.com/forums/discussion/5053/
RRRR “Back to Reality / My Summer Memory (15 August 2012 - 23 September 2012) http://www.daz3d.com/forums/discussion/5759/
Winners Thread: http://www.daz3d.com/forums/discussion/9315/
In The Commons: RRRR Commons Premiere (9 October 2012 - 18 November 2012) http://www.daz3d.com/forums/discussion/9325/
Winners Thread: http://www.daz3d.com/forums/discussion/12867/
RRRR “Sayings” Contest (6 December 2012 - 31 December 2012) http://www.daz3d.com/forums/discussion/12867/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/12877/
Winners Thread: http://www.daz3d.com/forums/discussion/15094/
RRRR Contest (18 January 2013 - 24 February 2013) http://www.daz3d.com/forums/discussion/15285/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/15307/
Winners Thread: http://www.daz3d.com/forums/discussion/17908/
RRRR “April Fool” Contest (with “Mini” Contests) (21 March 2013 - 21 April 2013) http://www.daz3d.com/forums/discussion/19109/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/19108/
Winners Thread: http://www.daz3d.com/forums/discussion/21780/
RRRR Summer Contest (23 May 2013 - 4 August 2013) http://www.daz3d.com/forums/discussion/21780/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/22664/
Winners Thread: http://www.daz3d.com/forums/discussion/27864/
RRRR “Chain” Render Contest (15 September 2013 - 13 October 2013) https://www.daz3d.com/forums/discussion/29000/closed-rrrr-chain-render-contest/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/28997/
Winners Thread: http://www.daz3d.com/forums/discussion/31526/
RRRR “Chain” Render Contest - Round II (1 November 2013 - 1 December 2013) http://www.daz3d.com/forums/discussion/31615/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/31760/
Winners Thread: http://www.daz3d.com/forums/discussion/33417/
RRRR “Story” Contest (4 December 2013 - 12 January 2014) http://www.daz3d.com/forums/discussion/33479/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/33478/
Thread: http://www.daz3d.com/forums/discussion/36407/
RRRR - One day in XXXs life Render Contest: 13 February 2014 - 16 Mars 2014) http://www.daz3d.com/forums/discussion/37042/
Entries only thread: http://www.daz3d.com/forums/discussion/37041/
Winners thread: http://www.daz3d.com/forums/discussion/39504/
RRRR Classic (19 May 2014 - 22 June 2014) http://www.daz3d.com/forums/discussion/41451/
Entries only/Winners; http://www.daz3d.com/forums/discussion/9325/
RRRR Freak Accindents (15 July 2014 - 10 August 2014) http://www.daz3d.com/forums/discussion/43832/
Entries only/Winners: http://www.daz3d.com/forums/discussion/43830/
RRRR Back to renders ( 25 Aug 2014 - 28 September 2014) http://www.daz3d.com/forums/discussion/45619/
Entries only/Winners: http://www.daz3d.com/forums/discussion/45617/
RRRR Things to do before you die ( 13 October 2014 - November 9 2014) http://www.daz3d.com/forums/discussion/47518/
Entries only/Winners: http://www.daz3d.com/forums/discussion/47517/
RRRR Unleashed (3 December 2014 - 11 January 2015) http://www.daz3d.com/forums/discussion/49497/
Entries only/Winners: http://www.daz3d.com/forums/discussion/49496/
RRRR Not on the screen ( 29 January 2015 - 1 March 2015) http://www.daz3d.com/forums/discussion/52007/
Entries only: http://www.daz3d.com/forums/discussion/52006/
Voting & winners: http://www.daz3d.com/forums/discussion/53400/
RRRR Just Random (25 March 2015 - 3 May 2015) http://www.daz3d.com/forums/discussion/54371/
Entries only thread and Winners: http://www.daz3d.com/forums/discussion/54370/
RRRR Unlikely Occupations (20 Jun 2015 - 2 August 2015 ) http://www.daz3d.com/forums/discussion/56841/contest-rrrr-unlikely-occupations-with-prizes
Entries only thread:http://www.daz3d.com/forums/discussion/56835/
Winners thread:http://www.daz3d.com/forums/discussion/61494/rrrr-unlikely-occupations-winners-announced
RRRR Stupid is as stupid does (September 1 2015 - October 4 2015) http://www.daz3d.com/forums/discussion/61970/rrrr-stupid-is-as-stupid-does-render-contest-closed/
Entries thread: http://www.daz3d.com/forums/discussion/61969/rrrr-stupid-is-as-stupid-does-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/64971/rrrr-stupid-is-as-stupid-does-winners-announced
RRRR Murphy's Law (November 15 2015 - Sunday January 10 2016) http://www.daz3d.com/forums/discussion/66026/rrrr-murphy-s-law-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/66025/rrrr-murphy-s-law-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/70820/rrrr-murphy-winners-announced
RRRR The sequel ( February 11 2016 to Sunday March 20 2016) http://www.daz3d.com/forums/discussion/71563/rrrr-the-sequel-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/71562/rrrr-the-sequel-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/78321/rrrr-sequels-winners-announced
RRRR Story ( April 8 2016 to Sunday May 15 2016) http://www.daz3d.com/forums/discussion/78671/closed-rrrr-story-render-contest/p1
Entries Thread: http://www.daz3d.com/forums/discussion/78666/rrrr-story-contest-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/92406/rrrr-story-winners-announced
RRRR Twisted Lyrics (June 7 2016 to July 31 2016) http://www.daz3d.com/forums/discussion/92481/rrrr-twisted-lyrics-contest
Entries Thread: http://www.daz3d.com/forums/discussion/92471/rrrr-twisted-lyrics-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/108966/rrrr-twisted-lyrics-winners-announced
RRRR What does it mean (September 11 2016 to October 30 2016) http://www.daz3d.com/forums/discussion/112771/rrrr-what-does-it-mean-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/112766/rrrr-what-does-it-mean-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/127361/rrrr-what-does-it-mean-winners-announced
RRRR Alternative Holidays Render Contest (November 17 2016 to January 15 2017) http://www.daz3d.com/forums/discussion/127526/closed-rrrr-alternative-holidays-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/127521/rrrr-alternate-holidays-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/147326/rrrr-alternative-holidays-winners-announced
RRRR - It could be true - 5th anniversary contest (February 20 -2017 to Sunday April 2 2017): https://www.daz3d.com/forums/discussion/149891/rrrr-it-could-be-true-5th-anniversary-contest
Entries Thread: https://www.daz3d.com/forums/discussion/149886/rrrr-it-could-be-true-entries-only-thread
Winners Thread: https://www.daz3d.com/forums/discussion/167426/rrrr-it-could-be-true-winners-announced
RRRR A long time ago or Far far away Contest (June 22 2017 to Sunday August 20 2017): https://www.daz3d.com/forums/discussion/178416/closed-rrrr-a-long-time-ago-or-far-far-away-contest
Entries: https://www.daz3d.com/forums/discussion/178406/rrrr-a-long-time-ago-or-far-far-away-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/197491/rrrr-a-long-time-ago-or-far-far-away-content-winners
RRRR They're ba..ack ( September 16 2017 to Sunday October 29 2017) https://www.daz3d.com/forums/discussion/198056/rrrr-the-re-ba-ack-render-contest
Entries: https://www.daz3d.com/forums/discussion/198051/rrrr-they-re-baa-ack-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/214026/rrrr-they-re-ba-ack-winners-announced
RRRR - What can go wrong? (Monday November 27 2017 to Sunday January 14 2018) https://www.daz3d.com/forums/discussion/214591/rrrr-what-can-go-wrong-render-contest
Entries: https://www.daz3d.com/forums/discussion/214586/rrrr-what-can-go-wrong-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/232941/rrrr-what-can-go-wrong-winners-announced
RRRR Judged by the cover ( Saturday February 17 2018 to Sunday April 1st 2018) https://www.daz3d.com/forums/discussion/233496/closed-rrrr-judged-by-the-cover-render-contest
Entries: https://www.daz3d.com/forums/discussion/233491/rrrr-judged-by-the-cover-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/249461/rrrr-judged-by-the-cover-winners
RRRR - Error 404 Not Found! (Sunday May 6 2018 to Sunday July 22 2018) https://www.daz3d.com/forums/discussion/251026/rrrr-error-404-not-found-render-contest
Entries: https://www.daz3d.com/forums/discussion/251021/rrrr-error-404-not-found-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/277091/rrrr-404-not-found-winners
RRRR RRRR Muddled Maxims ( Sunday September 16, 2018 to Sunday November 18 ) https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest/
Entries: https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest
Winners: https://www.daz3d.com/forums/discussion/302491/rrrr-muddled-maxims-winners-announced
Awesome! RRRR with twists!
I will contribute $25 to the prize pot.
I thought the RRRR crowd would like something like that, half the fun is coming up with weird ways of running the contest!
Pull #1
#5177 Ruined Subway Tunnel #22501
#6291 The Nameless Place #12575
#2298 Fitzwilliam for Regency for M4 #10110
#5487 Shadow Warrior Textures #14584
LB1: #5366 Sci-Fi Scout for Genesis 3 Female(s) #22353
LB2: #1570 Desert Dancer Outfit for Genesis 2 Female(s) #20449
Random numbers generated Oct 20 2019 at 19:12:20 by psychicscience.org
Free educational resources for parapsychology and psychical research.
Alright!
Pull #01
Rock Star Poses g3m
Fleur De Lys for Lirio v4
GIS Orion
Moonshines Drive In Movie Theater
I see someone building a mooshine burner.... and sure will they come
Pull #1
CP - Winter Circlet
Ensk Station Props
Light It Up
Peplum Dress and Blossom Shoes for Genesis 2 Female(s)
Maui Days Outfit for Genesis 3 Female(s) (LB)
Carnival Carousel Poses (LB)
Yikes, four of them are freebies!
"I see someone building a mooshine burner.... and sure will they come"
I may have to throw in free pizza for the grand opening.....
This theme seems like it is going to be loads of fun!
Will be back later with my pull!
Gopherus #01
Rock Star Poses g3m
GIS Orion
In the Land of the Cyclops…
Arak built it! A huge 3D Imax drive-in. With the aid of 3D glasses the images pop off the screen. Amazing! He knew an audience would come to experience the wonders of 3D. Unfortunately he built it on the planet of the Cyclops. In the land of the blind, the Cyclops are king. In the land of the Cyclops, 3D somehow lacks the impact that it has everywhere else.
Haha - superb!!! So much effort by Arak and so little gained.
Thanks Totte. If only he had done a marketing survey he would have built it in the land of the beholders. Then he could have cleaned up charging $5 for each pair of 3D glasses. But he would have had to build a 360° screen.
Pull#02
Sky Lords Axis
Forest Spirit poses expressions g8f
Sport Car Meteor 1947
3d Bison
I think that the bison might have been one of the first models i got at DAZ.... back when buffalo bill cody was still a buffalo hunter for the railroad.... LOL
LOL, Gopherus! Unlike Arak, Max and Mary were savy business folk.
tag:luci45 #1
Max and Mary's Merry Mars Fashion Boutique
They built it, knowing that the nasty Martian climate was no match for the ladies' need to shop.
Used:
CP - Winter Circlet
Ensk Station Props
Light It Up
Also Used:
Music and Jewelry Boxes
Clothing Boutique
Hobby Clothes
Nomad
Cthulhiana texture
HFS Fantasy Shapes for Genesis 3 Female(s)
Mars 360
Mars Explorers for Genesis 2 Male(s)
LoREZ 14 MU Worker Female
Short Mohawk Hair for Genesis 3 and 8 Male(s)
Hood Huntress Collection for Genesis 3 Female(s)
Rough Rider
@luci45 #1 Excellent! Not to mention the video games downstairs for the teens and television and soft chairs for the men.... what better place to hang out while the inclimate weather is... well inclimate!
Thanks, Gopherus. Maybe Arak should build a 3D theater on Mars. I love the Cyclopses' expressions and the one-eyed robot.
Pull #2
Sci-fi Hanger A
Historical Masonry DAZ Studio Shaders Vol 1
Pretty in Punk
Dinokonda
Pronghorn Antelope (LB)
Pink Ink (LB)
@Luci45: Fabolous idea and render, and we all know ladies fashion never goes out of fashion so to speak.
Thanks, Totte! It's nice to have RRRR going again.
Tag: Totte#01
Also used:
Eva7 + Chace Hair
P3DA Tom + BWC 80s Punk + Shadow Warrior
M4 + Jepes Leo Madoc + Regency M4 + Cesar hair + Beard M4
IG Iray Mei Lin + Buzzed Hair
Have A Seat
LorezMales
LorenztoLorez
Heart of the matter (Swing)
Music Man Electric Guitar
Music Man Poses
Scripts:
RSSY 3Delight to Iray
Emission Profile Master
Circus Circularis
Circus Director Luigi Gnocci Fetticuni, decided that instead of bringing his circus to the people, the people should come to him. He purchased some decommissioned underground tunnels with tracks and build a circus ride experience never seen before.
@Totte #1 What a concept! A parade that stands in place while the audience marches down the street... Like the day after the rose parade where all the floats are parked on a lot and the people mill around them. excellent!
Pull #2
#1146 Colors for Edit Female Hair #21621
#6531 Trendy Accessories #20237
#1294 Creature Creator for Genesis 2 Male(s) #19397
#7021 WildMane HairStyle #8367
LB #1: #248 Alpha Team Outfit for Genesis 8 Male(s) #58099
LB #2: #6166 The BorderLine #16265
Random numbers generated Oct 27 2019 at 19:46:22 by psychicscience.org
First time in a really long time I pull a new item (< 6 months old anyway). the Alpha Team Outfit, I haven't used it yet even.
That's awesome, Totte! And with Bad Boy Tom with your BWC hair no less, and many Lorenzos too.
You spotted that - hawkeye Luci!
it does look good on him!
tag: luci45 #2
Master Builders
Oroboro Corp's Master Wormhole Builders Annalee and Xerxes Starshine pose for a promo of the newly opened Diogenes Gate.
used:
Sci-fi Hanger A
Pretty in Punk
Dinokonda
Pink Ink (LB)
Also used:
Unshaven Beard for Genesis
Royal Punk tophat
Tuxedo for Genesis 2 Male(s)
Sparkle Shaders for Iray
Anodized - Custom Shader and Preset Suite for Iray
Spaceship Antares
Sci-fi Cargo Ship
Marcoor FG C4
Starship Astra
Ron's Space Brushes
Tornado of the Four Elements
Base Camp Vol.1
M3D Men 2 for David 5
Genevieve 7
Lucinda Hair for Genesis 3 and 8 Female(s)
@Luci45 #2 ooooh! shiney oroboro! clever use of antelope.... makes me think of that movie.. the worlds greatest showman... with hugh jackman nice one!
Thanks, Gopherus. It was a weird pull and I just went with the first weird thing that popped into my head. I liked the Hugh Jackman Barnum(?) movie and I usually don't like musicals. Good music and great colors!
Pull #3
Dream Home: Great Room Furniture -- London
Pastel Goth Outfit for Genesis 8 Female(s)
2007 AM Limo
Blue-Headed Parrot (both varieties)
Dark Fantasy Add-Ons for Genesis 3 Male(s) (LB)
Classic Pole Arms (LB)
@Luci45: Very cool usage and very good render!
TWIST!
Now that is quite the TWIST!
Oh, no! Then Big Ronnie will surely return...
Why is that a oh no? I would say oh yes!
O-Kaaay! (He has financial backers now.)
