Novica & Serene Night’s Renders, Tips, Tutorials & Product Reviews PART 2
Adding to Cart…
I am quite honored. I suggest you call your morph Titan. Since he is buff, strong and cool-looking. This is your exact head morph, minus the head size dial which I made zero instead of 4. The bod is just default M6 with bodybuilder added =-)
Titan it is then. The head shape kinda says "Marine" doesn't it?
It certainly does, which is just what I was looking for exactly. =-) You should make your own morphs and sell them. You have a good eye for such detail =-) I would've bought a head that looked like this! To me M6's head is so thin and narrow I can do not much with it. I can deal with one character like that, but every character with such narrow features- Kind of hard to do much with.
Titan's head is quite appealing and versatile and goes well with the larger sized more muscular bodies as well. =-)
EDIT:
For a comparison you can see Sarge in two versions here,
Version 1 is default M6 with bodybuilder added
Version 2 is using tjohn's titan settings for a wider faced older look.
Both Sarge's are using Sedor's gun poses reviewed earlier, and Sarge's yellow armor and red beret and his usual skin and scowl. =-)
One thing that really impresses me about gen 6 is the flexibility of the face. You can really add a lot of expression here which was impossible with genesis 1 series.
Today’s Review
Perseus Hair
http://www.daz3d.com/perseus-hair
By 3d Dream Mairy
Skins:
Bree (v5 base)
FW Danica http://www.daz3d.com/fw-danika
Bodies:
Danica
Gia
I’m always on the lookout for cool hair, especially short curly styles which have a nice soft quality to it, and don’t take forever to render and which you can use for both genders. I had overlooked Perseus hair before until the genesis hair sale, so color me happy. Perseus hair looks really very nice, has a number of morphs (including some really unique conical and handle-bar ones which might be useful for sci-fi or fantasy), and has a nice little diadem which you can add or remove to the hair or forehead as you see fit. As usual there are different styles included and different colors
The hair comes with 10 diadem textures, 10 colors, 27 style morphs. It works great on gen 2 female (seen here), and applies to men (although haven’t tried it yet). The only downside that I noticed was that on one of the unique hairstyles I noticed some texture/hair distortion on the scalp. This will probably not be a problem since the hairstyle wasn't one I intend to use. Otherwise, this hair fits and renders nicely.
Images 1-3 just different hair colors and styles. Image 4. Distance shot.
Mia For V6
Portia Hair 2
Casual Jeans and T-Shirt for Genesis and Genesis 2 Female(s)
Don't Just Stand There
DAZ Barn
Alisha For V4 And Genesis
http://www.daz3d.com/mia-for-v6
http://www.daz3d.com/portia-hair-2
http://www.daz3d.com/casual-jeans-and-t-shirt-for-genesis-2-female-s
http://www.daz3d.com/don-t-just-stand-there
http://www.daz3d.com/alisha-for-v4-and-genesis
I think Don't Just Stand There is a must have for Genesis 2. Even if you don't use the pose, there's bound to be a pose that is quite a good starting point for anything you do standing around. Mia's pose had no tweaks.
The outfit went on quite easily, the boots not so much but were easy to fix. I did an edit>add smoothing modifier and it told me I couldn't! So hmmmm. All I did was go to the boot, break it down in the Scene to get to the shin, and Y Scaled to make it taller and then scaled it with either X or Z slightly. Repeat with other boot. Voila, fixed. I've never had an item refused smoothing modification before, that was weird.
TURN OFF PARTS OF THE BARN THAT YOU DO NOT SEE- it really added to my render time. I was like, "DUH." That barn has a lot to it, and 95% of it wasn't visible. Remember to turn off what isn't in the aspect frame. That means for portraits, close the eyes over in Scene tab on the hip, shins, feet, thighs, etc- they aren't in the render!
Portia Hair will take a long time to render. It has a high shine option, which I used. The hair is beautiful!
DAZ Barn has wonderful textures- look at that wood!
Lights were Alisha V4 and Genesis. No additions- out of the box.
Doing a closeup of Mia and Portia Hair. It has taken 2 hours and is only at 21%. There is no scenery. It's definitely the hair. Shading rate is .30 and other hair renders a lot faster (but this hair, like I said, is very pretty.) Don't know if it's the high shine option that is adding time or not- and I am not doing a test render to find out, have other things to do. This will post hopefully later tonight, if it is still going, I am canceling the render.
"Model here is FW Danika skin with gia bod applied."
Hmm, what's with that white line next to her top lip, then the maroonish line parallel to that, outlining her top lip? Is the lighting doing that? In the first picture, it actually cuts through the two peaks of the lip and you can see it around the beginning of the bottom lip too. Kinda funky. The skin is beautiful, and so is your lighting- but that lip makes me curious as to what is causing that outline.
Mia has a nice skin and I like the barn as a backdrop. I'll be honest. Don't care for the breasts. Seem huge for such a dainty figure.
EDIT The problem with the skin was a layering issue. Base skin was not DANICA but was Bree. Mystery solved. Reapplying Danica solved the issue in the headshots. Danica is much paler than Bree who has a goldener skin. When the makeup for Danica was applied it naturally had a paler outline..
I have corrected the two headshot renders.
You'd REALLY not like Mia if you saw the original :) I am rendering her at the moment so can't go in and give you the exact scale down, but the chest was the first thing that got shrunk! (Also very rounded, didn't seem that realistic to me. Like it didn't have any of the "natural" slider applied.
I switched off the Portia Hair, it was just taking way too long. Trying Pen Hair but will be a few hours (which is fine, I'm headed out.)
Glad you figured out the glowing lines :) The renders are beautiful!
thanks for the tip about turning off pars of the barn and body parts. I learned something new.
Edit: i fixed the quote. I'm not sure what happened to the left bracket in the last "quote" tag.
LOL. I had the same issue with Daphne. I understand that chest sizes come in all different sizes but when they get too big, I start wincing for the girl with her back pain. I wish there were some characters aside from the teens with some smaller natural breasts. Not intending to be controversial, since we all like different stuff, I just find the super large Décolletage to be a bit boilerplate.
EDIT:
I really like the cute gap between Danica's teeth. It adds character to her figure.
I forgot to mention, I like the Alisha lights. Those render well too Novica. =-)
Did anyone pick up Tertius?
http://www.daz3d.com/tertius
I am curious about how that water renders. Looks nice. Sets with good water can be a challenge to find.
if you want a render I can buy it right now. I'll post the render later after I finish some a 2D drawing.
Oh, that's very generous of you. But I don't want you to buy it unless you were already going to. Just was curious what people's impressions of the water was. =-)
the water takes a long time to render with shadows in Studio 3. I should've used Daz Studio 4 and the advanced spotlight. Opps.
The water is clear and it reflects the sky-dome and the tower.
edit: The water has little 2D waves and crests on it. You can see the white light shimmering on the water.
Mia For V6
Pen Hair For Genesis And V6
Aaron For Genesis Young Teen Justin
http://www.daz3d.com/pen-hair-for-genesis
http://www.daz3d.com/aaron-for-genesis-young-teen-justin
You're welcome Starionwolf :) The inside of the barn seemed quite nice (although I breezed through it.)
I used Mia again (same chest, lol) with the Pen Hair since I had already rendered that, just to test the timing. It was definitely the Portia Hair, as I was at 50% in half the time it took for Portia Hair. So this is Mia again, on top of the Victoria 6 HD.
The lighting: You'll like Aaron, but here's a tip, if he is at 0/0/0, this has a spotlight THAT I ADDED at the following coordinates:
XYZ translation: -46.74 / 182.36 / 58.51
XYZ rotation: -4.68 / -40.18 / 0.47
Color: Pure White 255's. Only 27%. (Depends on the skin mats of your character. She is VERY light skinned.
I think I turned the UE2 down to 50.2%, I don't think that was the original setting. I left the color the same.
Again, this is Mia out of the box so far as the face goes, no morphs. She was placed on the Victoria 6 HD model.
Pier View
Meet Me At Sundown
Easy Environments: Mountain Trail
Breaking Waves
http://www.daz3d.com/pier-view
http://www.daz3d.com/meet-me-at-sundown
http://www.daz3d.com/easy-environments-mountain-trail
http://www.daz3d.com/breaking-waves
Okay, this is to show you what the Easy Environments: Mountain Trail background and lights do WITHOUT TWEAKING. I am still trying to figure out what all these things do with the waves, so let's just say this is one set. Another thing I did (which I am trying to re-create) adds a bit more dark at the top of them. I will be adding Meet Me At Sundown to the render (I think) but wanted to get this seen as we were referencing water. The Mountain Trail lights have ELEVEN distant lights. Of course, the Pier needs more lights, but again, this is "out of the box." Everything near World Center, didn't move anything.
BTW- the pier and Meet Me At Sundown are both PC.
EDIT: Oops, forgot the waves. I put them in the title and the link.
BTW, that render, with a .40 shading rate and really good settings, only took about six minutes!
I like the water. Thanks for showing that!
Mountain trail looks good as a nautical backdrop. Never had much luck with breaking waves personally, but if anyone can make it work, you certainly will. I think where the product really shines is for distance work. The waves in the distance look pretty good.
There's two things that come with the waves and I had to take a break, am looking at each thing now. There's dark ribbons which go along the top of the waves so I'll play a bit and see what does what. :)
The Sub_D choice makes the caps a bit whiter, but I'm not seeing a softer option so far as "out of the box." I think I'll try out the Meet Me At Sundown with depth of field and see how that background looks. This will take awhile, aka tomorrow probably.
one thing I forgot to mention about Tertius is that you can load only the water, the base/ground and one building like I did. You can also load the walkway and each building individually. ok, i'm going to bed. Bye
Logan
Newport Outfit For Genesis 2 Males
Newport Outfit For Genesis 2 Males Textures
Pier View
Meet Me At Sundown
Breaking Waves
http://www.daz3d.com/logan
http://www.daz3d.com/newport-outfit-for-genesis-2-male-s
http://www.daz3d.com/newport-outfit-for-genesis-2-male-s-textures
So this is the Meet Me At The Pier and you get a BUNCH of goodies for a ridiculously low price. The bottle of wine says Marry Me, the engagement ring in a box which opens or closes- nice touch! I brightened the flame on the candle, and that would depend on your lighting. PC- pick this up for $1.00 today! You can have the curtains or not, they load separately.
This is with the Mountain Trail lights, no adjustments. Just wanted to see how it did out of the box.
Table
Table Cloth
Daisies with Vase
Single Daisy
Daisies for Hair (L and R)
Wine Bottle
Wine Tray
Wine Glass
Ring Box
Ring Box Open
Silverware (Spoon, Fork, Knife)
Gourmet Bread
Bread Plate
Bread Knife
Chair
Candlestick
Curtains
Dinner Plate
The second one, rendering now, is the exact same scene but testing the Ruins of Angkor Wat light set. It's showing on sale at 50% off for me right now. I showcased it previously, love that set! This render will again be "out of the box."
Will post the render here when it is done, you'll have to watch for it if you're subscribed to the thread as it won't show up in an email notice. Will probably be an hour.
EDIT: Way too dark on Angkor Wat lights. So not shown. Lighting hitting at wrong places, so that would be a no-go on this setup.
nice render. Ruins of Angkor Wat is on sale because it is part of the Black November sale today. http://www.daz3d.com/sales-promotions#black_november
Vehicles, environments and buildings/sets are on sale.
One thing to watch for- the sale doesn't have things logically grouped together. As I bought the city stuff during Stonemason's sale, I needed vehicles and the combo was not located anywhere near the other two items, which are not located near each other either!
If you want a ton of pickup truck options, both dirty and clean, and then burnt up- this will get you all that. All 50% off. It's the only thing I'm buying in the sale.
EDIT: Look closely at the thumbnails and see the wide variety of commercial vehicles you get- even Border Patrol! It also has stuff for the horse trailer!
http://www.daz3d.com/back-catalog-vehicles/diamond-in-the-rough-combo
http://www.daz3d.com/back-catalog-vehicles/on-the-job-for-pick-em-up-truck
I like the romantic render. I like renders that tell stories, and a romantic story is wonderful..
The new 50% off sale is delish. Lots of great environments going cheap right now. Now, where is my $5.00 off coupon? =-)
Is there a coupon valid right now?
http://www.daz3d.com/warhead - do you have this one? It's 65%.
I lied, I am also getting
http://www.daz3d.com/back-catalog-vehicles/traffikar
http://www.daz3d.com/back-catalog-vehicles/traffikop-bundle
http://www.daz3d.com/back-catalog-vehicles/airsled
even though I should bookmark and wait for a 60 to 70% sale, I think the vendors need some support and at these prices, they are more than reasonable enough to buy. Plus, you never know when vendors are going to leave, and I have yet to have a single regret when any of them have done that. :) (Aka, I have everything of Lisa's, everything of Ken's, etc.) So folks might want to keep that in mind when wishlisting stuff that is 50% if it isn't a budgeting reason. If a better price comes along in 30 days, you can always get the difference. Hate this being at the end of the month, paychecks aren't available and funds run low. My mom always gives me my Christmas money early to have for Black November. :) Smart 86 year old gal!
EDIT: I ended up putting the first stuff (the previous post, the pickup trucks) on wishlist and going for the traffikar since I have a lot of futuristic stuff. Plus it all came to over $56 and I'm not doing that, would blow my budget. I did get the Warhead one, see the thumbnails. Looks cute underwater too!
I don't have any of those sets. They look good, particularly the car with the police texture. That would be useful.
I've noted that I tend to like those enclosed vehicles for distance work, and I like to use the scooter style products a lot.
This is one I've been eyeing: Skyjet http://www.daz3d.com/skyjet looks interesting.
I'm also interested in the old fashioned police car I've seen in the store. They don't make 'em like that anymore.
Sadly, I just purchased HD Michael 6 and Easy environments the Rock, so I'm sort of holding off on buying stuff until they offer a coupon or a discounted gift card.
I'm with you (see edit on previous post) as I'm budgeting too. :) I don't recall seeing that AntFarm product before, the AirSled. What a cutie!
CAUTION: AH-9200X - Fast Attack Aircraft does NOT mention it is for Cararra, but it is. I asked on another thread. If it ever says NA for compatible software, always open up the What's Included and see the file extensions. If it is .CA it is Carrara. So you Carrara users:
http://www.daz3d.com/ah9200x-fast-attack-aircraft
That's a cool looking aircraft. Too bad it is for Carrara users. Although my wallet is relieved. Warhead is a good price, and I don't recall seeing the antfarm product either. He/She makes awesome stuff. Usually a lot of nice detail there.
Rendering m6 High DEF now. It is quite slow.
