virtual nickel 4 yor carrara thoughts: the next level
1…67891012»
  • BrianP21361BrianP21361 Posts: 817
    edited August 2019
    I don't have an issue using G8 clothes with Misty's preset. I convert the outfit to Blended Weights in Studio and save it as a scene. Then I load G8 from the Carrara contents tab and import the saved clothes from Carrara's import menu item.  I conform the clothing and i'm done. Morphs work also.
    1500 x 1125 - 306K
    440 x 724 - 101K
    Post edited by BrianP21361 on
  • DiomedeDiomede Posts: 15,464
    Thanks, BrianP21361.
    For some reason, my male G8 works fine for "fit to" and morphs, but my G8 female morphs are not projecting.  I'm going to try to uninstall an reinstall Misty's female character and see how it goes..
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,678
    The base one is fine for me but due to scaling and that toe issue some full body morphs are not so great, Mrs Chow for instance is unuseable, stuff that doesn’t change the scale like breast morphs, big bums etc work fine.
    If done properly morphs like Zevo’s growing up or toon figures, dwarves etc work fine too so it’s hit or miss.
    edited September 2019
    found where the content tab folder strings are stored.
    was giving me the dreaded dsf not found message.
    even tho i was removing the ds lib in carrara, it was leaving stuff in that file,
    i manually deleted the reference in the preferences.txt
    and was able to re add the dslib to content tab. solved the dsf message
    think it a difference between relative path and literal path, cuz i don't use
    the default file location and i don't have post ogre running
    849 x 535 - 70K
    Post edited by Mistara on
    edited November 2019
    queing the working music, more effective than caffeine.
    cant sit still to this workin tune
    i think the special effect on her voice is an aural exciter.  seeing a vintage amplex aural exciter, don't see a digital version
    Pretty sure there is a VST plugin that would do that
    naming probably cannot breach a trademark
    probably harmonics or something, PhilW might know, SciFiFunk certainly would
    so far i've trie reverb, echo, and an effect called canyon
    Well looking on YouTube its a sort of equaliser and harmonics booster
    edited October 2019
    edited October 2019
    Mystarra said:
    I would read into and look on YouTube to see what exactly it does and if the effect you want before buying anything as your software likely does it already just using other terms
    try boosting harmonics on base and or treble and equalisation
    https://forum.audacityteam.org/viewtopic.php?t=9445
    edited October 2019
    think this is the Hulk actor
    peppy
    yayy tutt
    edited October 2019
    sorry charlie cant be starkist,  if only charlie understood how lucky he is
    https://1208audio.com/downloads/reviber/
    maybe, is free needs email though
  • VyusurVyusur Posts: 2,235
    edited October 2019
    Brunette female in this video reminds me of some of Mousso's characters.https://www.youtube.com/watch?v=tT4d1LQy4es
    Post edited by Vyusur on
    need the vert numbers surrounding the polys in the g8f toe issue
    want to see if those verts are in the list of deltas in the morph
    it would mae more sense if those verts don't move at all, but its like tripling the values
    i still don't understand how they rigged a text primitive, can't even open it in the rigging tab.
    thinkin carrara must have some secret heirarchy editor like poser.  import a text file to set up the rigging.
    edited October 2019
    outro music so totally sci fi-ee
    more intros study
    hd its not lol
    what do you think of voice overs in intro explaining the show?
    like Xena and Highlander and Dune.
    LOTR did it too.
    Aquaman had a lott of exposition
    A good voice over can set the mood.
    Mad Max 2: the Road Warrior - narrator turns out to be the little boy.
    Conan 1 - narrator is the team member from Asia
    A bad voice over can distract from the story.
    i think in lotr, cate wasnt the first actor they picked for the voice over
     l love in deadpool he "breaks the 4th? wall"
    edited October 2019
    yup, that's me at the petting zoo
    i love their whiskies tee hee so cute noses
    some lively quackers in the mix
    https://www.youtube.com/watch?v=rU_hMOZM_HE&list=PLNeBIiAxlMWwLd3uBZIZZck6hGraiogJg
    edited October 2019
    luv the song
    have no idea what i looking at in the video.  random slide show  oh might be a fan project
    ugh theres dust specs and strings drifting around in both my eyes.   so difficult to get anything done.
    what could possibly go wrong with changing the bone hierarchy to start at the lower abdomen?
