virtual nickel 4 yor carrara thoughts: the next level
inflation smiley
2 tools on the toolbar i never used
eyedropper and break ik chain
no idea what these tools can do for my workflow
«13456712
    huhh aint that a kicker
    i loaded up g9f in ds, turned on the vick8 morph, exported an obj from her,
    imported her in with morph loader pro, created a brand new vicki8morph
    applied the new morph in carrara, the same exact thing happened to her toes   what the hey??
  • VyusurVyusur Posts: 2,235
    edited March 2018
    I recently checked some G8 morphs in Carrara and found out that for some reason Tanya's toes didn't distort.
    814 x 677 - 237K
    788 x 545 - 249K
    726 x 694 - 230K
    776 x 600 - 208K
    Post edited by Vyusur on
  • Bunyip02Bunyip02 Posts: 9,343
    I converted a number of G3F morphs to G8F, some were fine, some had minor distortion to the toes, and some had the same severe deformation that Victoria 8 & Alexandra 8 had.
    One of my items from Rendo also had a severe toe deformation with the body morph.
    Misty - hope you have some success with those toes !!!!!!
    tested Shangrila - her toes look good, but her elbows are horrendous >.<
    Aiko8 is out.  Oh luv of sweet Aiko heartheart
    i isolated the vert numbers on the lbigtoe_2,
    thinkin to make the corrective morphs mathematically instead of eyeballing it.
    edited March 2018
    Do you like the new Aiko 8?  I do, but not as Aiko. This is what I had to say about the new Aiko 8 in the griping thread.
    I agree with those saying the problem is the name.  I like the character on its own merits, but... the Aiko characters at Daz are a brand.  That brand has been targeted for stylized or toon needs (anime).  I can mix the character with other content to get closer (thank you for the samples, Diva), but the whole point is that the brand has conditioned me to expect to use Aiko morphs to tweak some photoreal character to make it look more toonish.
    So, I am getting the character, and I'm checking how to change the name of stuff listed in the smart content tabs.  I will change the name of Sakura 8 to Aiko 8, and will change the name of Aiko 8 to Teen Josie 8b.
    Post edited by Diomede on
    BTW - prices of thoughts are going up.  What gives?  surprise
    inflation
    stores here are charing 5 cents per plastic bag.  and i double bag groceries >.<
    Tanya's toes don't distort  That is good news.
    Unfortunately, Aiko 8's toes do distort.sad
    640 x 480 - 10K
    Really, I was surprised. But her knees are much worse than her toes in Carrara.
    1300 x 2052 - 2M
  • UnifiedBrainUnifiedBrain Posts: 3,588
    Aiko 8 should be called AINO 8 (Aiko in name only)  Good ideas for name changes.  Teen Josie 8b is sure more accurate.
    Aiko's 8 nose is much more accurate and subtle than Teen Josie's 8 nose.
    Okay whos got the toenail clippers ?
    edited March 2018
    think i've eliminated everything but the topology.
    is farfetched to think the uvs would have anything to do with it?
    when it's all thats left, look at the impossible, smiley Sherloch Holms said somethimg like that
    meanwhile, some choreography for your dance movesdevil
    Post edited by Mistara on
  • HeadwaxHeadwax Posts: 10,562
    Mistara said:
    inflation smiley
    you use the eydropper to pick a shader from one obj and drop it onto another
    only seems to work for simple less complex  shader lists ??
    head wax said:
    Mistara said:
    inflation smiley
    ty!
    there's no visual indications anything is happening oh well
    uvmapper found verts out of range on g8f, but a fresh uvmapper uvmap didn't fix anything.
    i loaded g8f in DS, resolution to base.  exported her as object1.
    slided up the v8 morph, exported her as another obj2.
    imported object1, converted prop to figure which added a  hip bone.
    morph loader pro imported obj2 as morph.
    saved as product.
    loaded it up in carrara, you'll never guess, lol, no toe distortion.
    what does this mean tho?
    It means you have more analytical acumen and perseverence than I do.
    But it sounds like it might be good news.  I hope.
    found something in the geometry section.
    Root, maps, and what ooks like a list of vert numbers.
    deleted as a test, all the toes went silly putty.
    woes, want the particles to stick and accumulate, not bounce
    screaming bee woman to man voice, isnt the results i was hoping for
    edited March 2018
    output tab has a checknox for  use premultiplied alpha
    doh
    have 4 lights parented to a target helper
    when i rotate target helper, lights dont rotate around the th crying
    parenting the lights to a plane not working to move the lights either  h'd scr'ch
    putting em in a group doesnt work
    the group hot point moves, but nothing else
    doh  was the lock child again
    when it icon glows, means its on
    lock child setting saves with the scene
    Play with the advanced settings. Increase the friction on collision and reduce the bounce factor. A friction of around 50 is a good starting point; if you go too high the objects kind of slowly leak through the collision object and sometimes start bouncing off it again.
    640 x 480 - 12K
    640 x 480 - 9K
    edited March 2018
    theres an ocon on the top for inset view
    oh, inset view is picture in picture,
     can set mini directors view camera
    theres a clouds thats not volumetric?
    can nudge size or magnitude be assigned to a hot key?
    loll  formula inserted a sombrero
    oh gawd, the newbest of problems, the production frame wire frame is outside the scope of my window, way out, cant get it back
    View > Zoom > Default Zoom and 2D Pan will fix that.
    TY!!
    experimenting with hdri and translucency,
    using a giant sphere primitive and the yosemite hdrs
    dont seem to work together, unless direction of normals are part of translucency
    needs to convert to vertex test
    ty smiley
    the ik terminator cubes on g3m's foot goes into the middle of hus feet, not under,
    lowering his hip doesnt bend at the knees, it flexes his feet >.<
    fun to see, but what i really need is for his knees to bend,
    dont know what i'm doing wrongcrying
    eek  ui isnt refreshing.   rara using under a gb of ram, cores at 0 usage.  tried raising priority to above normal
    havn even started animating him yet, just played with the hip nudge up n down
    1616 x 1027 - 151K
    i saved the file recently atleast.
    mebbe it'll be refreshed after a good nights sleep
    walk cycles an important part of my movie
