World Map Creator Programs...?
Hey all!
So I just got into spatial scenes in DAZ/Blender, and I was wondering if there are any World Map Creator program out there?  I honestly don't know what to search for, and the searches I have done just give me "how to" guides.  I've tried a few, and it's a very fine art in creating world maps (height maps, layering, etc) just don't have the talent/patience to do them.  I'm looking for real world style (not fantasy) program that has the ability ot generate random contients, rivers, oceans, mountain range, etc.  Hopefully, I'm not asking for the moon (pun intended?).
Thanks for any suggestions you guys offer!
  • ArtiniArtini Posts: 11,009
    edited August 2019
    Good, that you have such expectations for Daz Studio. So far there is not such thing, I am aware of.
    Please take a look at:
    https://www.daz3d.com/terradome-3-iray
    https://www.daz3d.com/ultrascatterpro
    Also Carrara and Bryce available in Daz shop here, has such possibilities.
    https://www.daz3d.com/carrara-8-5-pro
    https://www.daz3d.com/bryce-7-pro
    Please note, that Bryce is a 32-bit program.
    Post edited by Artini on
  • ChatjdChatjd Posts: 152
    INFINITO also might work for what you are looking for as it is a plug-in for DS that creates terrains:
    https://www.daz3d.com/infinito-1-0
    edited August 2019
    As noted above Bryce and Carrara can both do this, including adding plants and skies.
    If you are looking for a full world, I use Fractal Terrains from ProFantasy and it generates pretty good random world maps although they don't take into account some real world things like winds and tides. With a little work you could probably get both semi-realistic color and something you could use as a displacement map in Blender out of it by customizing the colors, but it would take some trial and error.
    Googling for "random 3d terrain map generator" I found a Photoshop plugin called 3D Map Generator" that looks like it might do what you want in combination with Blender/Bryce/Carrara, but I didn't dig too deep and don't have the plugin myself so I can't promise anything.
    Post edited by MarkIsSleepy on
  • ChangelingChickChangelingChick Posts: 3,453
    edited August 2019
    Other World Mapper is the one I've been using lately and there's even a tutorial for it in the store-- How to Create Fantasy Maps (this is a great tutorial).
    It doesn't generate world's for you though. There's also Fractal Mapper which does indeed generate a world for you. You can also get the Fractal World Explorer with it as a free addon. I tend to generate worlds in Mapper, then use the base image as a background in Other World Mapper to create a map over it.
    Edit: The tutorial is fantasy, but the programs can be used for various genres.
    Post edited by ChangelingChick on
  • Oso3DOso3D Posts: 15,127
    The big issue you run into is textures. I’ve used s bunch of methods to generate terrain, then struggle with issues with close to long shots.
  • Doc AcmeDoc Acme Posts: 1,153
    Might be a bit of overkill, but at least take a look at World Creator: https://www.world-creator.com
    edited August 2019
    Hey all!
    I have just read again, what the question is and it is apparently real world style (not fantasy) program, that has ability to generate random continents, rivers, oceans...
    How real it should be, that is the question.
    The most real assets come from the photogrammetry, but I have not seen any program that could generate that (yet).
    edited August 2019
    Are you looking for programs generating worlds at the planetary level?
    If so, I have just rendered in Daz Studio iray, kind of the moon together with https://www.daz3d.com/arachnid-class-transport
    I know, that you are not asking for the moon, but just in case, if you change your mind...
    I created the moon in Grand Designer (from Steam) and exported it from there as .OBJ
    In Daz Studio I have imported it and assigned 8K maps generated by Grand Designer.
    or maybe more glossy
    1920 x 1080 - 237K
    1920 x 1080 - 293K
    That's one moist moon. laugh
    edited August 2019
    Thanks.
    The other example from Grand Designer - the coastline, rendered in Daz Studio.
    1920 x 1080 - 343K
    edited August 2019
    Another example from Grand Designer - the glowing meteor - that brave Sydney 8 are about to explore.
    Rendered in Daz Studio iray.
    1080 x 1080 - 184K
  • Write IdeaWrite Idea Posts: 496
    Thank you everyone for the rapid replies!
    Looking over all the suggestions, Fractal Terrain 3 is definately what I'm looking for.  A program that can quickly generate a flat world map that I can slap on a spherical object.  Add an atmosphere, clouds, etc and good to go for a render!  I bought the program, and it's gonna take some fiddling around with to get what I'm looking for, but it's a great starting point.
    Below is what I quickly generated from FT3 and next to it is what I want I'm hoping to make (image source: https://www.daz3d.com/blue-planet-orbital-view).  Of course I have to add bump maps, height maps, atmosphere, clouds, etc.
    Thank you @Artini, @Chatjd, @ARTOFMARK3D, @ChangelingChick, @Oso3D, and @Doc Acme!
    1400 x 700 - 127K
    900 x 449 - 654K
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,794
    edited August 2019
    If you are exporting static obj etc something like Epic Games free for now Twinmotion is also quite good for quick terrains and lots of content including animated 3D people, cars and animals, I have plonked many bits of DAZ architecture into it and quickly built up a scene.
    Video
    Video
    That's beautiful:)
    edited August 2019
    My first two spatial pictures using Blender and Fractal Terrain 3.  Fractal Terrain did EXACTLY what I wanted it to.  Click of a button, created a world map, edited it some, and popped in into Blender...bang!
    Thanks to everyone for helping make these pictures possible!  Been wanting to do something like this for a long time.
    Post edited by Write Idea on
  • My first two spatial pictures using Blender and Fractal Terrain 3.  Fractal Terrain did EXACTLY what I wanted it to.  Click of a button, created a world map, edited it some, and popped in into Blender...bang!
    That's brilliant.
  • If you are exporting static obj etc something like Epic Games free for now Twinmotion is also quite good for quick terrains and lots of content including animated 3D people, cars and animals, I have plonked many bits of DAZ architecture into it and quickly built up a scene.
    You have much too nonchalant an attitude for what you just posted :) That is absolutely beautiful!
    Congrats, that looks very, very nice.
