And also a bundle, where one of the items is already deleted from the daz3d store. Last chance to buy before daz stops taking your money:
https://www.daz3d.com/digitalpainters-shader-bundle
Edit also the G2 shader bundle includes a deleted Gianni 6 item. Last chance again.
And also a bundle, where one of the items is already deleted from the daz3d store. Last chance to buy before daz stops taking your money: https://www.daz3d.com/digitalpainters-shader-bundle Edit also the G2 shader bundle includes a deleted Gianni 6 item. Last chance again.
Broke but it works on FastGrab so grabbed something for $3
you can have a second go too
Your post awakened me from a fog. It works on Fastgrab, which equals about 88% off. In a rare coincidence, there were two items in Fastgrab on my wishlist. A no-brainer.
some cool race cars in the first stack up sale (sale items rotate quickly). If format matters to you, watch for cr2 version vs. 3DS version. The cr2 versions are the old legacy Poser format which should be fully compatible with Carrara.
I was looking at the https://www.daz3d.com/ancient-mystical-forest in fast grab, anyone know if this can work in Carrra? I am guessing not, but so many times I don't think something won't work and it does. :)
I don't know for sue because I don't have it. But the description says it relies on daz instancing (similar to Carrara replicators). Those instances won't be effective in Carrara. However, you might be able to use Carrara's relicators on the provided trees. etc. to get similar environments.
"And thanks to a special instancing feature, the viewport is just as fast and snappy as a scene with only 250k polygons (because that is what the computer actually sees)."
https://www.daz3d.com/dp-genesis-2-females-carrara-shaders-collection
in fastgrab
Thanks
yeah I grabbed the shaders though I own the set still in store as it got me the other one that isn't,
Gianni was tempting but since I own the other bundles I decided will just swap out maps for that one, the girls the other day got me 7 I didn't have
an aiko in the fg.
what eva happened to the corvas arm fixes. seeing them gone from the other store
Thanks.
We might need some money for tomorrow as something furry is rumoured and maybe after converting to blended weight it will work in Carrara with our fur
Some of Tango Alpha’s stuffs in Fastgrab
in the freebie board
there are books
lots of books
and they work in Carrara
And I was just thinking that you must have spent a lot of time making book piles in your last render. :)
Thanks for the tip!
https://www.daz3d.com/24-hour-super-stack-up-sale
Oh awsome, I was looking for something like this! Thanks Stezza!
the instancing part won't work so you will have to redo it with replicators.
Stezza beat me by a minute!
