The Things Which Could Be Worse Need Cats To Make Them Better Complaint Thread
My condolances.
Non-complaint #1: Yay, my car's windshield wipers are no longer insane. I went out for my normal Tuesday uptown chores and the wipers behaved themselves the whole trip.
Non-complaint #2: Yay, my SS deposit will be available tomorrow and I'll be rich, rich, rich again (mwa ha ha).
(For about an hour as I fritter it all away on bills, bills, bills.)
Non-complaint #3: Speaking of "earworms" (well, I was anyway), I was listening to the radio this afternoon and have discovered a candidate for one. Try this: https://www.youtube.com/watch?v=Tzc5ti-03PI It's 6 minutes of happy happy that you don't know the name of, by nobody you ever heard of, but is a piece that you have probably heard many times in your life somewhere. It's the Scherzo from Henry Litolff's "Concerto Symphonique No. 4 in D minor " (Scherzo has several meanings but in this case means a short piece extracted from a larger composition, often the 3rd movement of a 4 movement piece such as symphony or sonata. I, for one, never knew who wrote this and as of this moment do not yet have it in my extensive library but plan to remedy that situation almost immediately.
Henry Litolff: https://en.wikipedia.org/wiki/Henry_Litolff
I see what you mean, one of those little bits of music that you know but have never known the name of. Thank You for telling me the name. I shall probably remember it for oooh at least half an hour.
That's what turns the aluminum grey.
Has no effect on the stainless steel blades, though.
Your chef probably used carbon steel knives.
It's a scherzo in situ too. I have a recording of the whole thing, one of Hyperion's set of Romantic Piano Concertos (they also have 3 and 5 on another CD).
radio said Bob Seger on his final tour woes
the day the music died by by rock n roll
Most common vegetable oils (sunflower, safflower, sesame, corn, grape etc.) are drying or semi-drying oils, meaning that they oxidize, especially when heated, and create a hard layer which stick to the pan and can ruin even the best non-stick pans over time. Some oils like linseed and walnut oil dry very quickly and form a hard layer, that's why they're being used in oil paint.
https://en.wikipedia.org/wiki/Drying_oil
https://en.wikipedia.org/wiki/Semi-drying_oil
Use non-drying oils instead, like coconut oil, they don't cause this problem. Peanut and olive oil should work as well if you don't like the taste of coconut oil, but I haven't tried them over a long time. Plain butter should work as well. There are several other alternatives listed here: https://en.wikipedia.org/wiki/Non-drying_oil
I have used a sodium hydroxide (NaOH) solution (the main ingredient in most oil paint removers for wood) to remove the hardened oil from ceramic and stainless pans, but be careful with aluminum pans as it attacks aluminum very agressively, while creating hydrogen which may cause an explosion. So if there is just a tiny hole in the ceramic layer it may start eating up the pan if it's made of aluminum. It doesn't attack stainless steel and iron though, at least not the types I've tried. Stainless pans often have an aluminum layer at the bottom though, in that case don't drop the whole pan into a NaOH solution, which you otherwise can if it's 100% stainless steel or cast iron.
Actually they use drying oils to prepare cast iron pans before use to make them less sticky, by rubbing them with oil and then heating them up to a very high temperature, but that creates a different, much harder layer than if you just use the oil for frying. But in any case it can't compete at all with a good ceramic pan, when it comes to non-stick. Personally I don't trust other than pure ceramic pans for non-stick - if teflon is overheated it releases fumes which can cause "teflon flu" in humans, and even kill birds. Ceramic pans are also much more resistant to scratches and overheating.
Anyone having trouble logging in?
I tried to log in twice using my iPad’s password auto fill, but it was rejected... Then I tried three or four more times manually typing in the password and my email (correctly) and it kept rejecting it... when it finally accepted it, it took me to my account page where it had a little warning message “Account password required!”... uh... kinda late if someone is on my account page no?
Whatever... I’m sure it only happened to me.
I just a few minutes ago purchased both sets from Amazon. And upon closer examination of my library, I found that I do currently have the Litolff's Scherzo on a CD that also includes some Rachmaninoff and Addensell's "Warsaw Concerto". But now I'll have the complete Litolff work and also some other examples of his work. So much music, so little time. Groking classical music is a life long process with many thrills along the way.
Note: The "Warsaw Concerto" was one of the few longish piano pieces I could play completely. Very much fun. https://www.youtube.com/watch?v=Eg0QEpXYmUw
it logged me out
I get logged out sometimes a lot.
...I often have this "earworm" kicking around in my head.
I do not want to wake up yet.
Hmmm..., seems like it would need a lot of space to wiggle in.
or...
Hmmm..., does your head lean to one side and your eyes vibrate when the bass notes play?
or...
Hmmm..., that takes a lot of air. Do you have to breathe harder while it's playing?
Complaint: Big snow commin' my way!
I did some of my Tuesday uptown chores (prescriptions, groceries, gasoline, lunch, etc.) yesterday but skipped laundry figuring that I'd go on Saturday but the news this morning is that big storm coming here (south of Buffalo) this afternoon. That means I'd have to dig my car out on Saturday and I HATE digging my car out. So, I guess I'll bundle up (it's 20F out there) and go this morning while it's not yet snowing and the roads are clear. I hate wasting gasoline (my budget limits me to 1 tank a month except when I splurge for a mini-adventure). If I get that done then I can be a hermit over the weekend, drink hot chocolate, and watch the snowplows go by for at least a week before thinking about digging (ugh) my car out again.
Ooh, ooh, I just realized that if I do laundry this morning I can get to the uptown grocery store where they have those wonderful freshly made on-site donuts that I like so well. Mmmm, hot chocolate AND donuts while watching snowplows go by.
Issue the hair I want for a G8M character I want in a scene I think needs a hair that I can only find for G8F. I am having difficulty getting autofit to work on this hair.
Non-complaint: Wheee..., snow has started, car is parked, laundry is done, pantry is stocked, refrigerator is full, donuts are on hand, hot chocolate is brewing, house is warm, new shows on NetFlix. Chillin' and waiting for snowplows to go by.
...none of the above.
Just that this particular work sticks with me more than others.
snowin here too!!
...occasional showers and some sun breaks here but chilly. Been 8° - 10° below the seasonal norm for this time of year.
Got a bit of a headache. I was supposed to get off at 2:30 but got off around 2;45 which normally is not a big deal before when I took taxis home, but now I have to be ready when they pull up. Of course I have not seen them and it is raining. WiFi strength is not great it seems right here too.
...The Taxis In Spain Never Show Up When It Rains Complaint Thread.
The not really important complaints complaint thread.
You throw peanut under the bus complaint thread
you lie complaint thread
you are confusing complaint thread
The Non-Shazaming capt marvel Complaint Thread
The Galling Gall Bladder Complaint Thread
The Nostril Glow Complaint Thread
The 404 Complaint Thread
The Signing me Out Complaint Thread
The Can't Post Animated Gif Complaint Thread
The I forgot my mouse and I want to play on the laptop complaint thread
The I think I lost my red cup complaint thread
The my computer turned itself off and I lost the scene I was working on complaint thread
Trying to see if I can use Cinema4D, but I am not sure if I can without a mouse. There is a noncommerical usage clause on it so I can afford it.
Complaint: Not sure if I should be relieved or disappointed.
The "big snow" predicted by one forecaster never showed up here. In fact, there was a couple hours of flakes resulting in perhaps 1 and a half to 2 inches accumulation then it started to rain and today the weather has been in the 40sF all day. Ground is nearly bare again.
Not sure if this a complaint or not, but I need to use some of the money I get this weekend for my Adobe subscription. I guess the complaint is that I need to use Photoshop more but hopefully I can do that with this G8M (and maybe also a G8F companion) project.
Complaint is that the Starbucks at the mall I worked at is now closed. Well today was their last day. I am going to miss them, but that might help me save money I think.
Another complaint, I asked a question via a support ticket last night but I was too vague so it did not get answered correctly. Now I submitted a response with a better explination of what I meant. Oops I forgot to post this post. I am too distracted because I am doing too much at one time.
..sounds like what happened here in Portland a couple weeks ago when they were predicting another "snowpocalypse" here.
Now the local weather service is calling fo 8" - 12" on Monday. We'll see how that pans out. I think they just do this to help the local grocery chains out by getting everyone to go into panic buy mode.
