Daz Install Manager (DIM) 1.2.0.6, Now Available!
245678
  • TotteTotte Posts: 14,698
    >> WARNING: /src/dzvalentinaobjectdatabase.cpp(38): DB Register Open error: Cannot establish VC_Connection with remote server.
    You have not updated to Postrges CMS it looks like as DIM  tries to connect to the Old defunct Valentina.
    I say: Download the DIM "outside" DIM, install it, and then install the rest from DIM as it looks like your DIM has problems updating to the new one.
    And sorry for not replying before, missed it.
  • Iamcaobin said:
    Iamcaobin said:
    Totte said:
    Iamcaobin said:
    Totte said:
    Iamcaobin said:
    I've got the newest version of 1.2.0.6 of Daz Install Manager on Mojave but it download failed everything, could not download anything, I changed the directory path.. because it 's custom for me, but could not download anything even all directory path and settings by default..
    Please help!!
    Do DIM have rights to write to those paths?
    Sorry I don't understand what's your mean..
    If you have told DIM to download to a certain directory and DIM is not allowed to write there (the user under which DIM is running dont have write access to the directory, problems can occur, but you can check that under the "cog" and show log. This will probably tell you why DIM fails downloading.
    An update for Install Manager has been detected. To downloaded and install the update, click the "Update" button.  Once the download is complete, Install Manager will close and the update will begin.  Install Manager will relaunch once the update is complete. To continue using Install Manager without downloading or installing the update, click the "Work Offline" button.
    the upper dialog box appears when I login DIM then show me Install Manager could not download the update from the DAZ 3D store after I click UPDATE..
    Then couldn't download anything from products show up, I cut a little piece of the log below, please help:
    Make sure the server address and port number are correct.
    Error connecting to CMS
    WARNING: Error while downloading to file "IM00050875_InstallManagerMac64.zip", error - 403 : Forbidden
    WARNING: Network Error while downloading to file "/var/folders/h7/hz213kr93s11041378mx3tz00000gn/T/DAZ3DInstallManager/IM00050875_InstallManagerMac64.zip.{734f0ca7-105c-8576-7339-50c80c03dd3b}.part": Operation canceled
    WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
    Current Account: caobin
    Product 16280-5:Genesis 2 - DMC has no tags
    Processed 65 products with 124 unique product downloads
    WARNING: Error while downloading to file "IM00013176-04_DAZStudio410Mac64bit.zip", error - 403 : Forbidden
    WARNING: Network Error while downloading to file "": Operation canceled
    WARNING: Error while downloading to file "IM00004222-03_Hexagon25Mac.zip", error - 403 : Forbidden
    WARNING: Error while downloading to file "IM00018869-04_PostgreSQLCMSMac64bit.zip", error - 403 : Forbidden
    It seems like server address and port number problems but where can I find them?
    Somebody please help me..
    Theer are a couple of possibilities which have been suggested:
    • Stale account cache - if you are intending to buy anything that woudl clear this, otherwise open a Sales Support ticket and they can get the cache flushed for you.
    • The temporary URL for the content delivery network has expired, which might happen if you left the update message on screen for a while before responding. Loging out and back in should resolve this by giving a fresh URL.
    You can also download the current stand-alone installer for mac and use that instead of letting DIM handle its update.
  • DAZ install manager cannot be run with elevated permissions...HERE WE GO AGAIN!
  • IamcaobinIamcaobin Posts: 98
    edited October 2018
    I've fresh installed new macOS Mojave so of course I've stand alone downloaded the DazInstallManager1.2.0.6 manually "outside" DazInstallManager and login to try to download my daz staff..
    What should I do now?
    Post edited by Iamcaobin on
  • Iamcaobin said:
    Iamcaobin said:
    Totte said:
    Iamcaobin said:
    Totte said:
    Please help!!
    What about the details of open the Sales Support ticket.. what should I tell about the stale account cache?
    I'll imstall Mojave on one of my spare machine to see what happens, looks like some kind of permissions error , like DIM isn't allowed to write to the directories, but I hopefully know more soon.
  • Iamcaobin said:
    Iamcaobin said:
    Iamcaobin said:
    Totte said:
    Iamcaobin said:
    Totte said:
    Please help!!
    I'd say something like:
    I have been told that my difficulty in downloading may be due to a "stale account cache", and that you can arrange for the cache to be refreshed. As I have, to the best of my knowledge, exhausted my local options i would be grateful if you would arrange for that cache refresh. Thank you.
    but probably with more typos
    It is right, it will not run with elevated privileges. If you are right-clicking on the short cut and choosing Run As Admiistrator then not doing so will stop the alert, if you are using an alias/shortcut then check its proeprties to make sure it is not set to run as administrator.
  • Grumble.  I just manually downloaded the install manager for my new Mojave (which I generally love.)  It appears Auntie Apple has decided to protect us a little more from our bad selves.  I used to be able to temporarily open my security settings to install apps from any source. But now the Security preferences panel gives you the choice of app store only, or app store + trusted devs.  There is no Option C.   Thanks, Apple. I don't know what I'd do without you. Oh, wait...yes I do:  treat my Mac like it was my business what I put on it.
  • lordmaul30lordmaul30 Posts: 18
    edited October 2018
    No, i'm not right-clicking and  running as admin nor is run as admin.  checked. I checked all that with the previous version as well. Not working. I can't make purchases.
    Post edited by DAZ_ann0314 on
    Waiting for your respond of this.. and grateful for your try!!
    Baah, I got two spare machine, one is away and one is here, and the one here was too old (is a 2009 and not 2012 MacPro so Mojave wouldn't install), and the other is away on holiday ;-)
    So I need to get that one back before I can try.
    If this is Windows do you have UAC turned off? I seem to recall that causing issues, though I thought there was a fix/workaround in place now.
    edited October 2018
    Nope. Tried that. What's the workaround/fix?
  • Well, I'm not sure what you mean by "tried that" - I was saying havinbg UAC off may be an issue, so make suer it's on. And I meant i thought, if it was the UAC issue, that a fix had been incorporated in the new DIM.
    edited October 2018
    UAC is turned off. I tried turning it on to no avail. DIM is not working.
    edited October 2018
    I really appreciate for that!!
    I've opened this request on Daz 3D Help Center but only got reply as Will you please try this again and let us know if the update installs correctly for you? So.. I just hopelessness with Help Center..
    It seems like only me with this Couldn't Download Anything of updated Install Manager..sad
    OK, I don't know what could be happenbing there then - possibly some relic of UAC off. Please open a Techncial Support ticket to report a possible bug, if you haven't.
  • kyoto kidkyoto kid Posts: 41,854
    ..OK as this is a thread about the DIM.
    I just recently had an HDD failure that wiped out my runtimes and libraries.  I've disconnected the failed D: drive (where all my content resided) and am awaiting arrival of a replacement. Will the DIM "reset" itself so I can DL and reinstall everything again or do I have to go to the installed tab and "uninstall" all the content first?
  • DoctorJellybeanDoctorJellybean Posts: 9,626
    edited October 2018
    If the various manifest files created by IM were on the failed drive, then nothing will show as installed. If not, then yes, "uninstall" the content.
    Post edited by DoctorJellybean on
  • WonderlandWonderland Posts: 7,133
    DIM is now taking about a half hour to start up and is very buggy with the blue circle and not responding message when I change search key words...
  • stitchstitch Posts: 10
    • Downloads speeds are now displayed in bits per second instead of bytes per second
      • This now reflects the unit of measure used by the telecommunications industry (i.e., your internet service provider)
    Please add an option to switch back to bytes. Files aren't measured in bits, but bytes. Bits are used by ISPs for historical reasons in speed listings, but data caps are usually expressed in GB or TB, not Gb and Tb.
    Some things that could be slowing you down
    What "real-time protection" (e.g., anti-virus/anti-malware) do you have running to slow it down? Are you running low on drive space? Do you have background processes consuming cycles? Are you using external drives for any of the archive paths?
    Yeah, using Norton Utilities and an external hard drive but it seems a lot slower to start up and buggier than the previous version. Could it be all my products? I have a ton and keep acquiring more...
    edited October 2018
    I got 11k+ products and the DIM storage and envelope files on a remote disk (on a 12 year old machine), but DIM takes ony 1 minute to get ready, but a slow disk (like USB faling down to USB1 would take forever.
    Post edited by Totte on
    ...interesting I also have Norton along with Sophos running and the DIM (previous version) would load within a minute or two after starting it.
    edited October 2018
    Iamcaobin said:
    Totte said:
    Iamcaobin said:
    Totte said:
    Please help!!
  • Iamcaobin said:
    Iamcaobin said:
    Totte said:
    Iamcaobin said:
    Totte said:
    Please help!!
    I've attached some screenshots of reference for my CAN'T DOWNLOAD STAFF issue.. because even Daz3DTechSupport wouldn't help me..sad
  • NorthOf45NorthOf45 Posts: 5,692
    It appears that DIM is trying to use the old Valentina database, as Totte pointed out. I don't know if installing DIM installs PostgreSQLCMS automatically, so you might have to download and install it manually. Not sure if that's enough to start, or if Daz Studio needs to be installed manually, too. (It's been too long to remember, last new computer was a year ago).
    the big problem is, I've already downloaded and installed DIM manually.. it has been downloaded and installed manually and stand alone already, on my new fresh macOS Mojave system.. all system is fresh new install, there is no data from Migration Assistant at all..
