Adding to Cart…
ooo ty
a david5 caracter in there
pentonville prison n the fg
theres a small ca file, shader prolly
Flash sale 80% off on V4 and M4 items. Includes some Carrara items and shaders. For example https://www.daz3d.com/carrara-dynamic-hair-bundle
The flash sale https://www.daz3d.com/m4-v4-select-items
EDIT Now there is a 70% off flash sale on G1 and G2 too:
https://www.daz3d.com/booster-select-items
EDIT2 Example: https://www.daz3d.com/dp-genesis-2-females-carrara-shaders-collection
think the hair bundle might be the 1 has no haircaps, only works on V4?
Yes that is true - although as the V4 and M4 meshes have the same topography (if not shape), then these hairs will work on M4 as well (in fact any Generation 4 figure).
kewl! thanks
just saw these says for carrara https://www.daz3d.com/toon-generation-4
Kind of late to add, but most of Naomi's Carrara store is on sale as well.
Thanks, I got 14 items for about $2 apiece. I groaned at the 47 pages, since I've been thru that back catalog dozens of times and have most of what I might use in a short animation. But I found a bunch, mostly from RDNA which seems to be slowly seeping into the catalog ...
DAZ is going crazy with sales. 50% off Carrarav places. i.e. Howie, Phil...
Found out a convenient way to sort the recent sales. This was in the commons.
Click on one of the sales, such as Genesis 2 figure 70% sale to get the list of PAs. Click on a PA to get just that PA's list of sale featured items. In the store page list of PAs (upper left), you wil see the number (1). That is the PA you have currently selected. Open that drop down list and uncheck that PA. Now, all of the items that qualify for that sale will be listed, and only items that qualify, n matter who created them. I'm also told that if you are a PC member that the discount that you get on Daz Originals will stack with the sale. So,you could check the Daz Original seller and see only the items that get both discounts.
Some new freebies today. New to me at least.
OK, this may not set your world on fire, but it definitely got my attention.
I'm a big petipet fan. In Fastgrab today, there are two specific petipet products, Aircraft White Needle and Aircraft Needle Texture Pack.
Seeing these products today is noteable, because back in 2016, I started a thread about PC+ products. In that thread, Dart posted his renders of Aircraft White Needle. However, it turned out that the model had been pulled by Daz, and was no longer available.
Aircraft White Needle is back!
TangoAlpha's entire store is on sale as part of the Jazz new releases. No new release purschase required to get base discount.
70% off, includes Carrara version.
https://www.daz3d.com/habsburgic-castle
Another one 70% off, includes Carrara version:
https://www.daz3d.com/old-manor
The Party Avenue set (same vendor) also has Carrara shaders listed. I am sure it is based on a Gaudi-designed building in Barcelona.
Three products for Carrara -- Real Fur for the Millenium Dog, Cat and Big Cat -- are 70% off in Fastgrab today.
Very good, thanks.
