Aiko 8
1…5791011
  • On my slow laptopand Ihave to get going, so very unfinished render...50% Salem,50% Sakura with iris size maxed out and eyes made larger.(Still no Aiko.)
    I played with that as well. Hated what it did to the pupils though. Looked like they were being hi beamed on the highway.
  • 3Diva3Diva Posts: 12,058
    On my slow laptop and I have to get going, so very unfinished render...50% Salem, 50% Sakura with iris size maxed out and eyes made larger. (Still no Aiko.)
    Try J Cade's "Sakura Use Default Eyes" morph - it's pretty much a "must have" for mixing Sakura in with other characters and helps the eyes fill out the sockets a bit more. :)
    I think I saw a pupils larger morph somewhere... Not sure if it Daz's or a PA's. That's something pretty easy to fix in post though.
  • ermullensermullens Posts: 93
    any one notice in the third promo of Giada right above each eyebrow there seems to be what appears to be a guitar pick shape either i got a dirt spot on my tv
    Havos said:
    ermullens said:
    Riza without the needed addon
    Cybersox said:
    Oh yes, that's definitely a must have. :)  To confirm, that's with A8 but without A7 to A8, right?
    yes only thing i changed was reduced the breast size and widened her lips a bit not a fan of the puckered look
    Without the add-on, but I assume you included Aiko 8?
    yes, i started not to even buy it with the wrong requirement listed, but yes it has Aiko 8, any one notice in the third promo of Giada right above each eyebrow there seems to be what appears to be a guitar pick shape either i got a dirt spot on my tv or something is off about her face map
  • On my slow laptop and I have to get going, so very unfinished render...50% Salem, 50% Sakura with iris size maxed out and eyes made larger. (Still no Aiko.)
    I actually downloaded it but still trying to figure it out.  Is it being used with 3dOutklaw's Sakura eyes or normal eyes?
  • Mr BowenMr Bowen Posts: 404
    There are so many different types of Anime faces, though. If they made her with the generic anime face, then that would step all over Sakura. That isn't a put down to Sakura. She has the typical anime look. Aiko seems to have moved to other styles, but still of an anime quality. Here are some anime faces as reference.
    4162 x 2135 - 3M
  • Cybersox said:
    Thanks for the clarification; so there are ways to retro-fit the new Aiko; it is just a lot of work :)
    What about previous Aiko characters? Same as for clothes and hair? I see few of the A7 and A6 characters that would look nice with the new A8 body and outfit.
    Not easily, no.  There is a way to manually transfer morphs from G3F to G8f, but it's not simple and you would have to first transfer or purchase the basic shapes of the previous figures as well.  But, as I said above, the majority of the Genesis 1-3 skins can probably be used if you have the right UV set add-ons.
    I see, so it is not as simple as transferring the morphs from clothes. I was wondering if it was worth to get some of the previous A7 and A6 figures skins, but at this point is not really worth it. Thanks!
    edited March 2018
    It doesn't have anything to do with 3dOutlaw's product. :) It's a stand alone morph that J Cade made for the community. :) If you downloaded it and added it to your Library you can find the morph under the Shaping Tab >> Eyes >> "Sakura Use Default Eyes".
    It's pretty much a must have for using any of Sakura 8's shape on any other character (if you're not also using Sakura 8's geographed eyes). I'm really glad that J Cade made it and shared it with us! It's been a huge help anytime I want to dial in some of Sakura's morph to another figure.
    Post edited by 3Diva on
    Looked for it. Use Eyes Pupils dilate and it fixes it.
  • edited March 2018
    Ok think I extracted it wrong then. I put it in My Library in the Documents file instead
    EDIT.
    Ok fixed that.  I keep forgetting to not put all my 3rd party addons in a separate folder when I get them on here. Thanks for the heads up.
    Post edited by noshobawolf_f994bf986d on
  • HavosHavos Posts: 5,705
    Llynara said:
    Havos said:
    One more question Llynara, if you do not mind. Is Aiko 7 a full morph on its own, or is it just a morph of the Aiko 8 morph, and will not work on its own?
    The way I saw your dial controls, I thought it might be the latter, but according to the product page, Aiko 7 for Aiko 8, relies on owning Aiko 8. Does dialling in Aiko 7 alone, create the identical morph to what you see on Genesis 3's Aiko 7?
    Yes, I dialed in Aiko 7 and the dial for Aiko 8 was not dialed in at all. I could try uninstalling Aiko 8 and see if the Aiko 7 morph still works. I suspect it does.
    ok, thanks, odd that the product says that it requires Aiko 8
  • ArtiniArtini Posts: 10,935
    edited March 2018
    Aiko8, VYK Rose Human and Aiko 7 for Genesis 8 Female
    960 x 1080 - 190K
    Post edited by Artini on
  • JazzyBearJazzyBear Posts: 805
    I was rather pleased that for an adult character, she really did not have too much going to the skimpwear. I can use a lot of these to kitbash some fun outfits. With the massive discounts, most of the add-ons were about $3 or so.
  • LlynaraLlynara Posts: 4,772
    edited March 2018
    I had some fun with character mixing Salem. She's very pretty.
    The Sakura one probably needs the Sakura eyes or the add on that was made to replace the eyes. The sockets are a little funky. (Click and zoom in for huge pic with more detail.)
    If you do mix Salem and Karyssa 8,  be prepared for some crazy eyelashes. I had to dial them back. Here they are out loose in the wild!
    1500 x 1941 - 3M
    3460 x 3883 - 1M
    Post edited by Llynara on
  • Panzer EmeraldPanzer Emerald Posts: 727
    edited March 2018
    She definitely reminds me of a modern day Square-Enix (Japanese side of things) character, like she could fit in with the FF13 or FF15 world. Which may or may not be a good thing, depending on your view of the nu!Squenix style. I personally prefer it over the uncanny valley bug-eyed monstrosity that's Sakura 8, but YMMV.
    That said... I'm not 100% sure about her yet. She's one of the better looking Genesis 8 characters next to Monique 7, but considering she's a toon, I'm not sure she should count.
    ETA: And I agree with @JazzyBear: nice to see hardly any impractical skimpwear, but credit where credit is due: there's seemingly been a gradual shift away from it over the last couple female Pro Bundles, which I for one, welcome. I'd almost purchase the Aiko 8 pro bundle on that fact alone.
    Post edited by Panzer Emerald on
  • JOdelJOdel Posts: 6,322
    edited March 2018
    The close up? Yeah it almost looks like there is an outline of where a pair of horns are supposed to go (a bit close together, but still...) Could just be a minor screwup in the promo, though. No idea whether it's actually in the texture. It's quite symetrical.
    ETA: Opened the file up in Photoshop. Don't see anything there. So whatever is causing it, doesn't seem to be in the texture itself.
    Post edited by JOdel on
    Here's Aiko and some of her characters. These are "out of the box" with no adjustments. Left to right is Aiko 8, Rose, Riza, and Salem:
  • NoahLGP said:
    Aiko 8 reminds me Final Fantasy XIII
    I'm a fan of FF characters  so is ok with me
  • I know this sounds a little crazy, but I'm wondering if there's a psychological reason many of us are addicted. I have lucid dreams, where I can control my dreams with my mind and create worlds of beauty just by focusing my thoughts and creating 3D art or even working in Photoshop is a bit like that. You can create your own worlds and escape from the horror or negativity that may be going on in the "real" world that you have no control over...
    well when I went fully blind from cataracts one of the things I kept thinking about was daz and all the ideas I had for various render projects when I got my eyesight back it kept me going
  • was just wondering wioth the Riza saying needing the Aiko 7 for Aiko 8 to use some Aiko 7 morphs it got me to thinking and with the section related content for Aiko 8 mostly 7 characters/add ons and some early Aiko whether this product allows to transfer other Aiko 7 morphs/characters to Aiko 8
    I doubt that product allows one "to transfer other Aiko 7 morphs to Aiko 8". From the descriptions it sounds like it's just the Aiko 7 shape morph.
    I don't have the product and the above render I did with Riza is without that product, so I think she looks ok without it. I might pick the product up anyway, as I really like the Aiko 7 shape. :)
  • KharmaKharma Posts: 3,214
    edited March 2018
    I have the Aiko 8 pro bundle in my cart plus 5 items for the additional 30 % discount, and Vini for the bonus. The price was 52.00 and change but when I went to check out the cart price suddenly jumped to 77.69.  Does anyone else have items waiting in their cart and noticed a sudden price increase?  I don't see any updates in the sales pages so I am sure the offers from an hour ago are still in effect. I haven't changed anything in my cart just refreshed the page and wow...20.00 price increase???
    This is what my cart contained
    1406 x 1003 - 147K
    Post edited by Kharma on
    They switch over stuff at this hour for the new daily sale - so prices always go wonky at this hour. Buying at this hour is always a risky thing - given how much the prices are fluxuating right now due to them changing stuff around for the new daily sale.
    @Divamakeup thanks for the info. I'm not usually shopping at this time of night, so I guess I will wait a bit and see if the prices go back down otherwise I will probably rethink my purchases that I was wanting.
  • tj_1ca9500btj_1ca9500b Posts: 2,057
    Well, for those wanting a more Asian Aiko, we have AQ Yumi for Aiko 8 now...
    She's cute!
  • Cris PalominoCris Palomino Posts: 13,010
    Yes, try re-logging or try later as I'm showing the correct discounts.
    thanks again for the info, I waited and then refreshed and the discount prices returned so i went ahead and checked out.
  • HorusRaHorusRa Posts: 1,665
    edited March 2019
    Post edited by HorusRa on
    I think I ended up paying more for Aiko 5 stuff than I did for the A8 pro bundle in this sale.  I probably could have waited on a better deal on the A5 pro bundle, but I already had about half of that bundle through individual purchases.  I ended up going the starter bundle route for A5 (netting four items I didn't already have) since the starter bundle wasn't that much more than just Aiko 5...  And Aiko 5 is the only Aiko between 3 and 7 that wasn't part of my collection yet...
    I wishlisted the other stuff in theA5 pro bundle that I don't already have, on the theory that I'll see a better discount down the road, seeing that those items are from the Genesis 1 era...
    With discounts, and with part of the coupon I used, A8 pro came in at $27.76 for me... I ended up buying a LOT of A8 addons, just because... Salem is pretty cute, and of course I grabbed Yumi too...
    Waiting an extra day payed off for me, seeing that I didn't grab Edward 8 pro.  Extra 10% off if you own or buy A8 pro today.
    Well, I'm off to take A8 and Yumi for a spin in Daz!
    edited February 2019
