Adding to Cart…
Decimator for DAZ Studio I see that it cost $100.95..
Has it ever been free at some time?
No
No
But it was included with the paid for version of DAZ Studio 4 Pro, which is why the serial number format had to change for the free version (so that those of us who purchased DS4Pro can still use Decimator with our original serial numbers).
If you look in the surfaces tab the shader has a category SSS Material Type if you click on the little arrow you will get a drop down box the choices of chicken etc are there I haven't had a chance to play with this yet.
I would also like some presets for realistic skin.
The extra size of the installers is down to the installer code - small things like pose sets and shaders are more installer than anything else, so you really see the difference, while products with lots of textures are much closer in size proportionately.
The Servers should be back to normal with no more interruptions. Download speeds are likely to be a bit slower than normal due to traffic.
"But it (the Decimator) was included with the paid for version of DAZ Studio 4 Pro"
Hmm that's interesting. I wonder
are there more plugins that like that? (included before in the paid version but is not part of the current free version)
Thanks Scorpio, I had missed that one *blush* Now I just need to learn to use that one *goes to read the pdf again*
And thanks Richard, that explains that part. Must admit it had me a tad confused :)
If you manually download the dim version from the store Product Library and put it in the download folder for DIM then start up DIM, it should list it as Ready To Install. Click install and you should be setup.
Thanks so much! :-)
Looks good so far but wow, this is a serious resource hog. I'd say you should double the specified amount of RAM for smooth operation.
Well that didn't work. Must have had an update so the DIM is telling me it needs to be downloaded again but with the servers overloaded just downloading small packages is taking as long as downloading a package that's 100's of Mb's in size. No fun! :-S
If you are concerned you can export your user data before upgrading just to be safe. But, the install process should not hurt your meta-data.
I thought about that (and actually did export the user data just in case) but am always afraid that when the installer uninstalls the old CMS version and then reinstalls the new, the database with the old user data is somehow replaced. Apparently, that is not the case?
This is disturbing. The DS4.6 installer didn't ask me about where to install the new CMS, and now it's not running and I can't find where (or if) it did install. The old CMS has not been un-installed either, though it is clearly not running.
Can anybody remind me what is DS Default Content that comes along with base DS installer?
Do you mean it didn't ask where to install the CMS application, or the CMS database?
If database: During installation of DAZ Studio, when prompted, make sure you check "Customize DAZ Content Management Service Installation" so it asks you where to install the database.
Can I still opt out of installing CMS?
Okay, that explains why there isn't a new one. but not why it's not working (again.) But assuming that's the same issue I've been having with the CMS (where it breaks if there is too much data added at once. I'm pretty sure that's been reported somewhere), I have a work around for that.
If database: During installation of DAZ Studio, when prompted, make sure you check "Customize DAZ Content Management Service Installation" so it asks you where to install the database.That check box no longer exists if you already have CMS installed.
Greetings,
CMS (that is, Smart Content) hasn't been working for me since DIM came out, essentially. I've learned to work with the Content Library.
I haven't filed a bug because I've figured it's because of the complex setup I have, where the content is synchronized between two systems, but the CMS database isn't, so only whichever machine does the DIM install is the one that gets the metadata, and eventually CMS gives up, or something.
I always get:
When I nuke the databases, and re-imported all my metadata, it worked for about a day, until something (either the next time I installed content, or until the next time I restarted DAZ Studio, I don't know). I didn't figure this version would fix that.
-- Morgan
Everything installed fine for me, except autofit has the second drop box greyed out now, where it asks
Is this a change to autofit or has mine gone a bit wonky?
I do like the new yellow on black icon...catchy. :coolsmile:
Just utility scripts.
with the update of 3Delight does this mean our old shaders will need to wait for an update ?
could someone confirm if pwSurface 2 is working, please?
Can it be in another folder than main DS installation folder? Along with content, for example, on external drive?
So I just installed DAZ 4.6 but I am having a problem with the Starter Essentials. Everytime I try to install it fails. I tried uninstalling the previous version but the only option through DIM is Stater Essentials Update.
Any advice?
I wound up downloading it from my Product Library tab under My Account.
Yes, that's where I put it.
Thank you!
