HeadShop OneClick Submitted to DAZ - Best in Class! (Commercial)
1789101113»
  • ImagoImago Posts: 5,686
    Someone managed to have the plugin working on non-default setups?
    It's sick to ask us to have standard folders!
    I can't install DAZ in my C: drive because it's a SSD and the softwares makes it work a lot, shortening its lifespan! Already changed one because of that...
  • d-j-od-j-o Posts: 345
    edited April 2018
    I just purchased headsot oneclick, how do you move the dots?    None lined up to the image, slightly off,  and for the profile I can't add dots to outline the face.  The screen doesn't look like anything in the pop up examples.  If I click on a dot, all it does is move the whole image around with the dots.
    Edit
    I shut it down and reloaded an image and tried again and editing the dots works until I try to rotate or zoom in.  Once I do that it no longer lets me edit the dots.
    I added a profile and was able to add the dots.   Again as soon as I zoomed, I could no longer edit the dots.
    Post edited by d-j-o on
  • I have things working and looking good until I go to export. It says it successfully exported, but then I get an error message
    "Headshop Directory "fs" could not be created because the selected figure does not have a valid runtime folder."
    I've tried Genesis 2 and 3. I've only used files as they install, so I haven't moved folders or anything.
  • evilded777evilded777 Posts: 2,483
    edited October 2018
    I'm going to say that this does not work with Connect installs ie if you have installed your models via Connect.  Nothing but issues.
    There should be a giant banner for things that don't work if you install via Connect.
    Returning.
    And how the hell do I uninstall it?
    Post edited by evilded777 on
    Plug-ins cannot be installed by Connect. I don't believe true shaders (not shader presets) can be either (and possibly scripts too).
  • carrie58carrie58 Posts: 4,098
    edited October 2018
    Returning.
    Just re install it manuelly and it will work ,as far as uninstalling .......find the uninstaller .....or manually go to the folders it is in and delete it ,you can find those by manually down loading the zip open it up and looking to see where the stuff is .
    Post edited by carrie58 on
    Did you ever get any advise to avoid this error?  I am getting that also ... tried on G3 and G8. My figures are installed via DAZ Connect.
  • info_b3470fa520info_b3470fa520 Posts: 901
    edited March 2019
    Advised customer:
    Steve,
    I would try two things:
    1. Pls. reset the Preferences to default as shown in the picture
    2. If that does not work, create a folder on C;Users/My Documents/My DAZ 3D Library/Runtime/People
    and copy Gen 3 or some other in that folder. Launch Studio by double clicking on Gen 3 Female DSON file.
    576 x 641 - 142K
    1109 x 410 - 97K
    Post edited by info_b3470fa520 on
  • TynkereTynkere Posts: 834
    edited March 2019
    Nevermind.
    Post edited by Tynkere on
  • i have tried the following:
    and still get Headshop Directory "fs" could not be created because the selected figure does not have a valid runtime folder."
    Headshop13 works with Genesis 3,but not Genesis 8. Help!
    P.s. I did add a runtime with genesis 8 male and genesis 8 female, still no success.
    Skype tech support call/screen share scheduled for Tuesday
  • Laslo was amazing in helping me with Headshop 13. I'm a happy customer!! Thanks again!
    smileyLaslo was amazing in helping me with Headshop 13. I'm a happy customer!! Thanks again!
  • Hey, I encountered a bug while using headshop 13 and I hope somebody can help. So I load Daz Studio, start Headshop, drop a Photo and let headshop do its thing. Then I immediatly press "Export", which seems to be successful.
    But then in DAZ Studio I get the following message and the transfer obviously did not work.
    I found the files created by Headshop in the folder
    C:\Users\Public\Documents\My DAZ 3D Library\Runtime\FaceShop\fs\SmoothedModelTextures
    In another comment I found someone suggested, that the DAZ Library is in the wrong folder, but the "correct" folder was not mentioned.
    Thanks for any tip.
  • Sorry, the pictures were removed after posting. The Error message is attached. It says: "HeadShop closed before it could create the necessary files".
    353 x 94 - 4K
  • Installation issue. We could skype/screen share and it works 100% of the time.
    Pls. invite me at skype, my skuype name is lasloves. I am in Europe right now, so dass kann schon passieren mit Zeit zonen.
    Gruesse,
    Laslo
