I can't believe it's been so long since I've had a chance to get in here. Lots of great renders. I like the one with the car and the rear view mirror. That was cool. I think my favorite is the one with the tiger and the monkeys. That one is way cool.
After a discussion on Spotlights needing 0000000000's of lumens to work right I set up a scene using one spotlight at 1500 lumens and then it grew into a Genesis 3 Male with cigarette and lit match, the light from the match is Emissive. The background is The Streets of the Wild West.
2017-10-06 19:42:07.828 Total Rendering Time: 16 minutes 52.9 seconds
Click on image for full size.
2017-10-06 20:06:42.096 Total Rendering Time: 19 minutes 49.62 seconds
I continued experimenting with light and render times. Looking at the render times it looks like it is the bright areas that slow the render times and not the lack of light in the images. Only my observations of course but it happens too often in images for it not to be that which is causing it.
Stopped this after it sat at 97% for approx 2 hours.
Third Point Light copied from the other lights and moved into the next building on the right. The disc is visible through the window making it look very bright but I left it to see how much of a difference it would make to the render. There was a significant difference in render time.
Changed the time from midnight December 21st to 07:30 am so that there was some ambient light and put a LinearPointLight at 5500 lumens Sphere Geometry Height (Diameter) 200 into the building behind the character. Everything else is unchanged. with the extra light the render time has increased by at least an hour.
All of your renders are great as usual. I particularly like the cigarette lighting in the night ones. Amazing how clear your character is despite the fact that the renders are dark.
Used another of my own images in these. It is a scan from a photograph so the colours aren't perfect. I used the free Ruined Cottage to see if I could get it to match in with the image which is used as an Environment/Background. I also used Old Chap, George Hair and Moustache and the Backpack from Nomad for Genesis. The camera is set to the Exif data from the the camera and the co-ordinates for the place by using Iray GeoLocator.
Thank you @Knittingmommy
Looks really good!
@Sven Dullah
Thank you for looking in and the comment. Much appreciated.
1) 2017-10-08 14:49:47.126 Total Rendering Time: 4 hours 35 minutes 13.30 seconds
2) 2017-10-08 09:12:32.285 Total Rendering Time: 1 hours 38 minutes 47.58 seconds
Moved light in last window as it was too bright. Doing that dropped the render time by quite a bit.
3) 2017-10-08 18:26:58.782 Total Rendering Time: 2 hours 30 minutes 13.47 seconds
4) 2017-10-08 20:35:00.673 Total Rendering Time: 1 hours 50 minutes 54.14 seconds
Switched off the Point Lights. This dropped the render time by 30 minutes.
Before I move on, one final render.
2017-10-08 23:52:29.931 Total Rendering Time: 1 hours 47 minutes 41.11 seconds
@Worlds_Edge
Thank you. Only one spot and the rest is down to the camera settings in Tone Mapping.
I've fallen behind a bit with posting.
A few space themed ones.
This is ISS and the Shuttle, both DAZ models.
2017-10-11 17:15:43.325 Total Rendering Time: 1 hours 4 minutes 16.66 seconds
2017-10-11 23:12:06.859 Total Rendering Time: 3 hours 2.50 seconds
2017-10-12 10:14:43.920 Total Rendering Time: 2 hours 11 minutes 37.2 seconds
A Native American one.
2017-10-18 00:20:12.386 Total Rendering Time: 11 hours 53 minutes 44.58 seconds
This became a "Bob Ross", "Let's call this finished."
Stopped at 65% completed.
2017-10-18 18:28:41.244 Total Rendering Time: 1 days 3 hours 33 minutes 48.46 seconds
Lillith V4
Halloween, sort of.
The Crow Queen
2017-10-21 17:51:00.918 Total Rendering Time: 41 minutes 49.66 seconds
2017-10-21 18:35:23.458 Total Rendering Time: 39 minutes 22.30 seconds
The Old Crone Crow Queen
2017-10-23 18:36:31.118 Total Rendering Time: 2 hours 32 minutes 51.55 seconds
Really like these, the crows really work well.
Thank you.
The Witches Lair
2017-10-25 04:36:47.947 Total Rendering Time: 10 hours 28 minutes 58.75 seconds
The spider totally freaked me out for a minute lol. She looks like she is really mad at him for spreading his spiderweb's all over her lair.
Messing about with DOF again.
2017-11-03 18:57:42.755 Total Rendering Time: 2 hours 41 minutes 31.81 secon
Spotlight Settings
Ray Length = 4.00
Spread Angle = 12.20
Beam Exponent = 1.00
Light Geometry = Rectangle
Height = 3.00
Width = 3.00
Luminous Flux = 5500
Temperature = 7500
Camera Settings
Focal Distance = 924.02
F/stop = 4.41
2017-11-03 15:28:33.654 Total Rendering Time: 7 hours 2 minutes 24.39 seconds
Camera Settings
Focal Length = 176.30
Focal Distance = 494.13
F/stop = 22
Predator
2017-11-04 01:46:46.042 Total Rendering Time: 3 hours 39 minutes 55.23 seconds
Camera Settings
Focal Length = 91.44
F/Stop = 9.22
I got around to doing a render of Lucas 8 and thought it might be of interest.
2017-11-08 00:43:35.620 Total Rendering Time: 3 hours 49 minutes 19.68 seconds
Lucas 8
George Hair and Beard
Time Rogue Outfit
HDRI lighting
I thought George would make a good miller.
Windmill Hill
2017-11-09 18:50:35.376 Total Rendering Time: 1 hours 25 minutes 11.48 seconds
I thought the beard on Lucas 8 was sitting out from the right cheek but I did a close-up and it looks fine.
Lucas 8
That beard looks really good. And George fits quite nicey into that scene.
@IceDragonArt
He does fit the profile and he could quite easily be an Inn Keeper too.
2017-11-09 23:25:09.154 Total Rendering Time: 1 hours 28 minutes 4.74 seconds
Changed the lighting and some Tone Mapping settings.
2017-11-10 20:39:36.424 Total Rendering Time: 3 hours 1.82 seconds
Very cool images, well done mate!!
Thanks for looking.
A little late but I only just thought of it.
2017-11-14 00:02:02.324 Total Rendering Time: 1 hours 56 minutes 34.15 seconds
Among the Fallen.
