Non-photorealistic Renders (NPR)
16869717374100
  • tkdrobert said:
    What do you guys think. Do the added trees and scrub help convey the sense of scale I'm attempting?
    BTW: This is an unretouched render. The only thing I did in Photoshop was add the gray fill for the sky.
    I think this does do a better job scale wise.
    Thanks! I think so, too, but I don't like the trees in the foreground. They just don't match the more-abstract style of the rest of the piece. So I removed the closer trees. I added another plant near the base, and will add some trees or something in the foreground to give it scale. I'm also working on the final shading for the image. Will post something new shortly.
  • I'm struggling with an issue of scale. I can't decide if the skull and rocks in this image interfere with the sense of scale i'm attempting. The spire in the middle is supposed to be huge -- but I'm thinking it needs something else in the image to help set the scale. Any thoughts or suggestions? And, BTW, this is an almost-unretouched render, so please excuse how sloppy it is.The lighting isn't even final on it, and I need to add some texture and fix a lot of things.
    Also, this is the first page of my comic story. It's the establishing shot. Dialogue will be coming out of the top of the mountain and there will be a cave visible up there.
    Just removing the images to try to save space, since it's on the same page I think it'll be easy to keep track of (I hope).
    If I'm reading the image right, is the skull about human-head sized, and near the front of the frame, with the tower in the distance? If that's the case, I think the small rocks near the skull help with the scale, but removing the rocks near the tower helps make it look much larger than the surrouding area. Maybe if there were a tone/texture starting in the middle ground to make it clear there is a dune/cliff/hill or some other "edge" near the frame that we are looking out past? I think that would help with the perspective. I think it's clearly reading as "big", but making it look further away would make it massive if that's the intent.
    Thanks VERY much. I think you're right about the rocks (although I did finally pull the skull... at least for now). I might add some rocks to the foreground and -- as you said -- use texture to convey the distance. This is supposed to be an imposing crag with a dragon's cave on top. I'll post an updated image shortly (and maybe the skull will come back, alnog with a few rocks). Great comment about the rocks near the crag, by the way. i think you nailed what was giving me a problem.
  • Are there any NPR shaders that work with Iray?
  • HeadwaxHeadwax Posts: 10,495
    hya trees do the job better than before. Thos foreground large shapes look like leaves though, so they are making it confusing.
    my first thoughts for getting the sense of scale would be monocular clues to depth perception
    eg reducing size of texture, reducing contrast to get the feeling of atmospheric depth
    the other thing you could try is receding lines - eg a winding road that gets thinner in the distance - the road gives the sense of comparative scale - or perhaps a plane flying across the monolith - or very small birds
    head wax said:
    Image may contain: 1 person, outdoor
    Phantom: The Second Take -- Carrara render.
    The grain is from Carrara's sand filter plugin (free), I used a distant light first on 2000 lumens, then rendered it out at 400 lumens. combined in post with Toon Pro render and also coverage render.
    I took it into Corel Paint and ran a distress  filter over it then tinted it blue in PS by adding a layer, filling it with blue and changing parameter to 'Colour'
    I really love the Phantom (big fan of his Charlton Comics series, moreso than the comic strip, if I'm being honest), and this is a great tribute to him. I really love the finishes, and really appreciate the detail you provided on your technique. I've got to ask a really blunt question, though (and I hope you don't mind): Is the Sand Plugin prividing an effect that you couldn't get in Photoshop with a grain or noise filter? I do like the distress filter -- it adds a lot of nice variance to the background noise. I really appreciate that it's done in-camera during the render process (I think that is SUPER cool), but the final output looks like a noise filter. I do really like the way your color fits in perfectly with his traditional purple costume, by the way. GREAT choice there. Overall, really cool work.
    BTW: I was going to say that his "package" looked really impressive, but when I shrank it down for the quote, it actually doesn't look that... um... big. It looks pretty normal. I think it was just a matter of our line of sight falling right at his waist and the stripe drawing my attention to it. As I said, in the smaller image, it doesn't look as big. I also think your setting is really interesting. Something I haven't seen before. I like it. The whole thing has a nice pulp feel to it.
    thanks for that, no it's not a blunt question :) the sand filter, not really sure if it has advantage over photoshop - but there is a big push by some to do 'untouched renders' so that's why I used the plugin - just to show what carrara can do out of the box. Ah his 'package' I hadnt looked to be honest!! But it's always good to give that sense of manliness I guess.
    The setting is a local swimming pool here. Easily recognisable in my home town - so that's why IO chose it - to show the phantom in situ
    Carrara render.
    I like the atmosphere in this picture, really good at setting the mood. I like this style of art, and I think the color is just right to be subtle but effective. I've shown my preferences towards the bold, black and white style, and I like how this is a bit softer to help enhance that mood. Really cool work.
    thank you, that's very kind of you!! we had a big Phantom show here recently where many well known artists were hung (well their work was)  - I wasnt invited to show (Local regional art gallery) so this is my reaction :) !! Trying to prove myself I guess !!!
    Thanks!  I killed the trees -- they just looked weird (didn't see them as leaves, but can't argue with that interpretation; they look weird). I reconfigured the hills and terrain a bit more and think I'm ready to move forward.
    And you're right about a road being the perfect choice to show scale and depth, but it doesn't fit the story. No one builds a road TO a dragon's lair. Tiny birds, though, will definitely be added during the "inking/details" phase. I'm also try to use thinner lines for the distant terrain.
  • mmitchell_houstonmmitchell_houston Posts: 2,527
    edited October 2017
    You know, I fully respect the artistry of the unretouched photo or render, but the editor in my brain takes over and he wants the best photo/image he can get, and doesn't care how it got there. Still, I do think it's very cool that Carrara can do that. VERY cool, and if I were working on an animation, and the effect were mostly stable and not jumping around too much from frame-to-frame, it could be very cool.
    And sorry you didn't get in the exhibit. It sounds like it was a lot of fun.
    Post edited by mmitchell_houston on
    hi mmitchell_houston take a look at  this https://www.daz3d.com/forums/discussion/200861/gmic-new-plugin-announcement-teaser
    yep bummer I didnt get in the show, but I was shortlisted for a $10,000 prize last Friday night, didnt win,  but my small painting 70 by 50 cm was auctioned for $2500 (more than three times the reserve!) so I am happy with that :)
  • tkdroberttkdrobert Posts: 3,618
    Very cool. Congratulations.  I hope I get to a point where people would want to spend money on my art.
  • Northern WoodlanderNorthern Woodlander Posts: 138
    edited October 2017
    Two characters this time!
    1280 x 1656 - 614K
    1280 x 1656 - 266K
    Post edited by Northern Woodlander on
    Nice.  Did you use Topaz Clean?  I baught Simplicity, but not clean yet.
  • Two characters this time!
    GREAT work. If you did use a Topaz filter, could you please post the render of the woman before running the filters? I would love to compare how her hair looks before and after.
    And I really think you've really got a good-looking anime style going here.
    edited October 2017
    And I really think you've really got a good-looking anime style going.
    Hello gentlemen, thank you for the compliments. I don't use topaz clean but rather work on it through the basic render through daz3d. The rest is done with Clipgrab studios and Photoshop. Here is the render of the woman.
    1280 x 1656 - 2M
    975 x 895 - 483K
    thanks!, I;m lucky because I like to make images that people want to buy - as opposed to trying to get them to buy stuff they don't want !
    it's about matching the artist to the audience I guess
    edited October 2017
    In honor of the new movie out this weekend: Blade Runner.  The figure was done in IRAY but I used Topaz Simplicity to go in a more artsy direction.  Background is from online.  Used same technique.
    Blade Runner by tkdrobert
    Post edited by Chohole on
  • ArtiniArtini Posts: 10,624
    Nicely done, tkdrobert.
    Very nice!
    Quite fetching! The two pieces look well integrated. The muzzle flash is interesting, but I think you needed to use the smudge tool to drag a line out of it so we get the bullet escaping (I looked online for an example, but couldn't find one quickly... sorry). This is REALLY nice. It really captures the pulp-future look of Blade Runner. It reminds me of a game box design for an RPG from the 1980s (and that's a compliment).
    edited October 2017
    Hey guys, I seldom cross post, but I'm looking for a new baldric (the chest strap) for the hero in my comic story (the current one I have is slowing me down -- I need something that poses easily, especially when he's sitting). I was thinking something dynamic might work (I'm working in Poser). Here's the post: if you guys can think of anything (including a completely different look or design), please let me know. I'm quite willing to change the costume if it will get me a cool look that is easy to pose.
    https://www.daz3d.com/forums/discussion/202736/dynamic-baldric-or-warrior-outfit-for-poser-m4
    Trying the smudge thing, but I'm not liking it.  Probably not doing it right.
    Try selecting a region using the polygon select tool. Keep the edges hard (don't feather). You just want to draw a little "tube or stick" shape, and then set the smudge tool to a really strong intensity. Then give it a shot. You will probably have to draw the black lines along the top and bottom after you're done. If I get a chance tonight, I'll take a stab at it, but I'm on deadline today and need to get back to work.
    This is really nice, I really like the effect here! And the foreground and background elements blend well. I like the color pallet and the contrast you have here. Very good work.
  • AlmightyQUESTAlmightyQUEST Posts: 2,006
    edited October 2017
    Ok, something different from the last one, but similar principles and use of pwtoon. (A lot more work compositing the final image though than the last one) Still may work on the colors a bit, but I know I could keep adjusting the colors forever and need to make decisions at some point smiley .
    Coffee Date
    2000 x 1600 - 2M
    Post edited by AlmightyQUEST on
    I went a little buck wild on this one (experimentations), so don't be to hard on me.  This is basically a a comicbook version of a cyberpunk detective I've been playing with.  I have an IRAY version as well.  His one is a little younger and anime looking.
    Cyberpunk Detective by tkdrobert
  • Ok, something different from the last one, but similar principles and use of pwtoon. (A lot more work compositing the final image though than the last one) Still may work on the colors a bit, but I know I could keep adjusting the colors forever and need to make decisions at some point smiley .
    Coffee Date
    I like it (and completely understand the need to just move on and get something done -- I'm always struggling with that). My one suggestion would be to use black shadows on the figures and the foreground, as that would enhance the sense of depth (or flip it and go gray on them but black for the background). Right now it's a little too much gray on gray. And I really like the character designs.
  • wsterdanwsterdan Posts: 3,316
    Excellent concept piece, I especially like the background and the look of the left hand. Very nice!
    — Walt Sterdan
    Coffee Date
    oooh! I like this! :D
    edited October 2017
    I don't know if anyone is interested in following how I actually put the comic pages together for my fairy story project (because it is a little off topic for this group), but I thought I'd mention that I'm doing it a bit differently this time. Normally (in my do-it-by-hand days), I would go through and make rough thumbnails of my pages, then go back and do the following, in order for each page, one at a time:
    1. Draw Borders
    2. Pencil figures & backgrounds (very light backgrounds)
    3. Add Lettering (to make sure it fits)
    4. Adjust pencils if I need more room or the lettering doesn't fit right)
    5. Then ink each panel, one-by-one, until the page is finished.
    I would then go on to the next page.
    But this time, for my digital comic, I'm starting off with figures rendered in Poser 11, and they arrive with an "inked line" already on them, including a lot of the shadows and final details present. The difference is, those inked lines are set as material properties (that is to say, I use the Materials Room in Poser to define a thicker Geometric Edge line to clothing than skin (as an example)). This means that if I want to keep the thickness of the inked lines consistent from one panel to the next, I need to render each panel at the size it will be printed (otherwise, if I had to resize the artwork with the transform tool, Nirona the fairy could have thick lines in one panel and thin in the next).
    To achieve consistency, I'm actually going through the entire story and setting up my panel layouts and initial lettering FIRST. Now, keep in mind that I've already hand-drawn tight thumbnails, so I have a solid idea of what goes in each panel, and its size relative to the panel borders. In other words, I have a pretty solid idea of what goes where and how big it should be in each panel. If not for laying down the pre-work, I think I would be at a loss for how to approach this.
    Anyway, if anyone thinks this is off-topic, just say the word. But I know some of you are working on comics and graphic novels, so I thought this might be of interest to you.
    Here's a sample of the panels laid out. As you can see, I've even added some of the background and imported the one panel that's completely finished (I might need to reapply the line tones in that panel, as I think it uses a different line frequency than I chose for the entire story). Also, the "rough border" is going to get some more love soon. I want it a lot more jagged and splattery in the final version, but everything here is a quick "rough," so I drew it and now it's time to move on to the next page. AND, the black panel borders on that first page will be completely cut off -- they are in the trim zone for the page.
    5504 x 4200 - 4M
    edited October 2017
    Some more characters
    4000 x 5175 - 2M
    4000 x 5175 - 2M
    1280 x 1656 - 644K
