Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
Exactly WHERE is the tutorial stored? I can't find it.
Awesome! Thanks so much :)
Laurie
Um, click on DOWNLOAD HERE and the zip file is right in front of you?
Laurie
Very welcome. It all comes down to how well the G3F and G8F shapes match up to begin with, Some shapes are trickier than others. Here is an alternative file you can use with the tutorial which may give you straighter wrists, but I can't guarantee without having the character to test.
Alt Clone File Download
Yes the zip file is there, but where is the tutorial in DAZ? It's not in documents.
There's a PDF in the zip file with the instructions, to be opened and read outside of Daz Studio.
thx for the Tutorial Redz.
Here a fast Convert :)
To escape distortion of limbs, it's best to place Genesis 8 and Genesis 3 into the same pose (be it A on Gen3 or T on Gen8). In theory morphs *should* transfer either way, but I've found it best to play safe and just make both poses identical during transfer to escape unwanted results.
Don't forget to readjust the rigging and ERC freeze your morph after import that's very important for your future morphs on Gen8 as well.
Other than that I have succesfully done same as Redz, don't do direct tranasfer but rather transfer using gen8 as a static OBJ :)
Hope that helps.
Another thing: if you want to transfer a character that you have created using MORPHS packs for Genesis 3 - Gen3 and Gen8 morphs are named identically, you can just save as > shaping preset on genesis 3 and use that same injection on Genesis 8 without transferring anything, same morphs WILL apply. This goes only for morphs packs (head and body) and their combinations though :)
You...are AWESOME! Thanks so much for this. I was able to transfer my original G3F character, Katja, to GF8 with no problemo. I had no luck using the transfer utility in the past. But, your method is excellent. I also noticed that I didn't have to change the figure to "base" before export. Is that because you already did, or because G8F doesn't require it?
Here's Katja for G8F, wearing the Blood Red outfit and the Chandra Hair. I'm using her G3F skin, which also has NGS2 shaders.
This really is a huge help for moving to G8. It also means that I'll be able to continue to make new characters without worrying about them being obsolete. Thanks a MILLION!
Oh she's really lovely! I saved the scene subset with G8F already at base res and posed, just to reduce the number of steps in the tutorial
Unfortunatly it didn't help, it gave bigger distortions. But it's not so much distortion using your original clone, it can probably be hiden with posing and/or photoshop afterwards. Thank you so much for this!
I have successfully transfered several of my custom characters and some Daz originals too, like Aiko 7. I found that some extreme shapes works less well, like the Star 2, her hands vere wery distorted, but Aiko 7 has only some slitght problems with the fingertips.
Thought maybe that was it...good thinking. This is huge. For those of us that don't want to rebuy every morph and skin utility, we can still use what we have already purchased. Most of my body morphs are done from Measure Metrics / Figure Metrics with some shape tweaking from both free and Merchant Resources. My skins come from various sources and utilities as well. So, I'm really grateful not to have to rush to buy all new G8 specific morphs and such. I'm sure that I will get the new tools as they appear. But for now, I'm super stoked to be able to use the dozens of characters that I've already purchased or created with the new G8F.
Thanks again. Your system is about as simple as using GenX2. I'll probably go through one dull evening and just export morphs...LOL. Now if someone will just write a script so your utility can be automated to export everything at once to G8...(wishful thinking...).
I guess I will be buying that pose converter after all...
I was able to use ZBrush to transfer a character from G3 to G8. It took about 15min but you get good results. This works because the G3/G8 use the same mesh topology for the head, torso, & most of the leg.
The process goes something like:
1. Load G8 & your morphed G3 character.
2. Adjust the scale of one of the characters to more closely match the size of the other. I would say match the arms as closely as you can.
3. Adjust G8 arms & legs position to closely match the G3.
4. Send both of them to ZBrush and save each as its own OBJ.
5. Import the G3 OBJ back into ZBrush & set poly groups to = UV groups.
6. Hide all poly groups except for the Head and store as a morph target.
7. Import your G8 OBJ. Do the same as above set the poly groups as the UV groups. Hide all Polly groups except the head and apply the morph. You should see the morph take place.
8. Export the morphed G8 and over write the G8 OBJ file.
9. Import the G3 OBJ do the process again except this time do the torso.
The Legs are a bit different.
1. Import the G3 and do the process again leaving only the legs visible. Now hide the foot starting at just above the ankle where the first complete edge loop goes around the leg.
2.Store this as your morph target.
3. Import the G8 OBJ and perform the same visible masking as before and apply the morph.
4. Select the feet and move them into place.
The arms cannot be morphed at all but you can use ZProject to re-shape them to a sub tool aka the G3 mesh.
The eyes and mouth will need to be moved into position manually but this is easy to do. The mouth may be morphable but I have not tried it yet.
Next send back to DAZ and update your G8 figure as a morph. Dial in the morph and set the rig to match the new shape.
Dont worry about the eye lashes if you save the morph as a morph asset then they will conform on load.
@Redz Thank you so much for the tutorial! I used it to get Anneka over to G8F, without the horns (I like her better without them.)
For some reason, the shoulders look weird if I dial in too much of it, so here it is with just 25% dialed in, which looks fine because the skin is so good. I noticed this happens when trying to bring over long, creepy nail morphs too. Something is different in the arms and affecting the shoulders. Not a biggie, as I dug around and found some nail morphs for V8 in the Pro pack and went with those.
On my next try, I may just bring over the head morphs since those are the most crucial.
And wow, I am loving the new expression and posing abilities on G8. Makes a HUGE difference!
*Squeal!* Really? Thanks so much. I've been using DS for two years but there's still so much I don't know how to do ;). Thank you.
Laurie
Wow...I never really like Anneka that much before. But, you've really brought her to life. I'm getting really excited about G8 now that I know I can use my G3F characters with her new capabilities.
I'm attempting this right now. First thing I got was this error message:
The following files can not be found: data/daz 3d/genesis 3/female/morphs/3d universe/toongenerations2/base/ctrl3dutoongenerations2_adjustage.dsf
Is that a file I need to be able to do it? Or will it be ok without it?
I think you can ignore that. For some reason it's not set to zero by default, but I don't think it affects G3F unless the toon generations morph is applied.
I had that error, but the final morph turned out to be perfect, so I say you can safely ignore that warning.
OH MY GOODNESS! This came out so good! I just transfered Callie 6 to G8F!
AMAZING! You're my hero, Redz!
Yay! Glad it worked out for you. :)
I had the error message too, but pressed ahead since I went into it convinced it wasn't going to work anyway (Redz, forgive my lack of faith!). It worked, and I'm chuffed to little mint-balls. It wasn't even that difficult either, and once the technique becomes familiar enough to be practically automatic, it should be a doddle to transfer another morph in the odd spare ten minutes available here and there.
Anyway, here's the head shape of Zarina for G3F - on G8F :) I never thought I'd be seeing something like that in my runtime so soon. She's wearing a Skin Builder 3 texture instead of Zarina's original and will be getting plenty of use. Thank you so much for sharing, Redz. I'm so pleased with how this came out and am looking forward to getting a few more transferred over.
Totally awesome!
Fantastic! She came out beautifully!
Callie 6 dialed in at 40% to G8F - I think she's adorable! :) Thank you again Redz! You've made my year!
Thanks, guys, and good to see you back again Diva. I've loved all of those I've seen on the thread. I feel like Redz has given us a lifetime of Christmases all at once here :)
Did you convert Callie 6 from Gen2 straight to Gen8. Or did you convert from Gen2 via Gen3, then onto Gen8?
Thanks, Astracadia, it's good to be back. :) And I argree with the lifetime of Christmases from Redz. lol This is awesome!
Here's Josh Crockett's Hag for G3F....turned out great....er, awful. Beautifully awful. LOL Even the more extreme morphs come over nice. Thank you again Redz! :D
Laurie
Hehe oh my she's scary!! If only the Hd morphs were transferable, but hey, I'm thrilled with the HD expressions
