What to choose for Iray renders? Nvidia GeForce GTX 1050Ti/1060 or 1070
124»
  • Ongoing MomentOngoing Moment Posts: 78
    edited June 2017
    you guys are scaring me ..
    the GPU consumes around 60% of its TDP while rendering. idke state its around 10%.
    I used CPU Z as Kyoto suggested, but I couldn't find anything that explins my power consumption.
    Further, I haave this i5 processor 65W TDP(whatever)
    GTX 1060 120W TDP
    8 GB RAM
    500 GB HDD
    a CPU cooling fan from Cooler Master plugged into MB, no extra power supply needed.
    no cd/dvd writer or anything else. yeah double checked.
    PSU is Cooler MAster Thunder 450W rated at..um...at....dont know. Check this for your understanding: http://www.coolermaster.com/powersupply/office-home-thunder/thunder-450w/
    you recommend me to get new PSU?
    If yes.. then I will have to look for commissions :(
    I ran a 1060 on a 450w psu with a cpu that drew more power with no problems for over 2 months. My power supply was a cheap one too. It was starting to wear out but the system was 8 years old. Don't fix it if it ain't broke. My 2 cents.
    you can go to pcpartpicker and choose all the parts you have in the computer and see what the suggested power recommendation is for the whole system. It is a nice feature of that website. Just pick your cpu, mobo (or equivalent), cooler, a hard drive and the 1060 gpu to see what the power consumption is. I am guessing it is around 320-375 watts.
    Post edited by Ongoing Moment on
  • kyoto kidkyoto kid Posts: 42,411
    kyoto kid said:
    ...CPU-Z will show you how much power the CPU, HDD, and GPU are drawing as well as CPU core temps. As you are cutting it close to the recommended PSU output it is good to keep an eye on this.
    Kyoto, where in CPU Z?
    ...not at home right now. When I get back I'll opn it up.
    ...OK home now, opwned up CPU-Z amd notice that it only monitors CPU and CPU cooler power consumption.
    Checked around for other utilities however there really are no software tools to monitor load at the PSU, which I find odd. Seems everything else can be monitored except.  The only other solution would be a wall meter but those cost (minimum 20$ at Newegg)
    Apologies for the confusion.
  • EtheralEtheral Posts: 91
    GTX 1060 120W TDP
    8 GB RAM
    500 GB HDD
    Nice PSU. You've got 360w on your 12v rails. Absolute overkill. The CPU + GPU are gonna use 65 + 120 = 185w. You are using barely more than half your available power. Don't bother getting a new PSU. You can even run a GTX1080 on your PSU.
    ..memory, HDDs, and case fans  also add to the power load though not significantly so (particularly with only 8 GB and a single drive). The CPU cooler I have on my i7 is pretty beefy and it only takes a little over 5W at peak.
  • SPadhi89SPadhi89 Posts: 170
    edited June 2017
    Cool, so I'm not getting any type of new hardware for the coming 1 year... Perhaps Ryzen may lure me to buy it sooner though.
    But the problem with AMD processors is the heating issue. Am I right?
    Post edited by SPadhi89 on
    edited June 2017
    My Ryzen 1600 is cool as a cucumber on a stock cooler. Right now the biggest issue with Ryzen is RAM. Waitng on MOBO companies to drop a new bios update.
    I was running 2 sticks of DDR4 2400, 16gb all total and everything ran smooth. I added 2 more 8gb sticks exactly the same and the computer wouldn't post or was unstable. I had to loosen the timings and up the voltage a little just to get the RAM to run at a downgraded speed. 2400 isn't nearly fast either. People have bought 3200 and can't get decent speeds. The last bios update helped. Just waiting and I am sure in the next few weeks everything will be fine. Love that I can overclock the CPU depending on what I am going to use it for. Just realize a basic Ryzen setup cost 700+ dollars.
    Ryzen 5 1600, PC Mate B350 GTX 1070 Mini, 32GB Team Dark DDR4 2400 RAM
    ..I believe it was AMD GPU cards that ran hotter than the Nvidia ones.
    Man seriously? If Ryzen doesn't get heated up then it is definitely a plus for AMD. But I read reviews which say that temperature of Ryzen at idle condition lies/lays between 52 - 60 degrees.
    If that's the case, then how is it cool?
    edited June 2017
    :P
    1000 x 857 - 1M
    edited June 2017
    the 1st bios was reporting temps 20 degrees higher than actual usage. The most recent bios fixed that. My chip stays in the 40's even overclocked. 50-55 degree Celsius is actually not a bad temp as I understand. Not an expert just what I have read. I try to keep up on as much Ryzen news as possible since it is still new and being fixed/upgraded. Waiting on the next bios update to fix my RAM issue and more optimization.
    Cool, So I am looking forward to buy it in 2018
    Cheers!
    now I have a question.
    How do you make Iray to use multiple GPUs to render? And how do you connect those multiple GPUs?
    I have heard that even if there are multiple GPUs, Iray will still take/consider only one GPU while rendering. Strange things to learn each day :(
  • now I have a question.
    You don't have to connect them. In the advanced render settings tab you just select the cards you want to render with. The main issue is both cards should have the same RAM amount. Say you have a 4gb card and an 8gb card. If you go over 4gb of assets for rendering, IRAY won't use that cards CUDA cores. At least that is how I understand it. If you don't go over the 4gb of RAM then both cards will be used. If you want both cards to always be rendering then it is probably best to have equal amounts of RAM in each.
