Apparently the DAZ Install Manager is about ready
1…2728303233…38
  • CymbidiumCymbidium Posts: 217
    I have been testing out the DIM for a few days now, just downloading and installing small batches at a time, such as F5 pro Bundle, Young Teens Pro Bundle, etc, by matching the files to be downloaded with my previously dloaded and sorted backups. I am impressed with the speed of both dloads and installs. Only had two failed downloads so far, out of nearly 400, so that can't be bad! :)
    I decided to go the 'uninstall existing files' route and to install to the new default directory (but bit by bit, as I identified what files I would use the DIM for next) and had to reinstall a lot of them first via the old method in order to get uninstallers, since I don't normally allow the installers to create them. This process worked okay physically, not really taking too much extra time, and meant I could check exactly what I was doing (still like to be somewhat in control!) I like to see what is happening in DS after installs and uninstalls, so regularly open up the program in between.
    The only thing I find (very) irritating is the fact that the Content Database process doesn't seem to automatically remove links in Smart Content when a product is uninstalled, so I get lots of yellow exclamation marks which link to deleted directories. Checking the box to clear orphaned links in the Content Database Management usually doesn't seem to work, even when repeated several times. Removing 'My Library' (where the majority of my newer DS content is installed) from mapped content and then adding it back works in a limited way for some things but not others, even after the products have been reinstalled by the DIM (to the new default directory). Sometimes, if I 're-categorize' a wrongly linked reinstalled item back to the original category it will appear properly in Smart Content, but not always.
    The only procedure that seems to be reliable is to reset the database and then re-import metadata (after exporting user data first), but obviously this is time-consuming if, like me, you like to do things gradually so you can check whether things have in fact installed correctly, and where they have been installed to. I had hoped that I would not have to follow this procedure every time I reinstall previously installed content (and with nearly 5000 items still available to dload that is a lot of irritation and frustration!)
    I am using DS 4.5 Pro, not the latest release, but 4.5.1.6, on WinVista 64bit. Is anyone else experiencing this problem? Has the Content Manager service become more reliable in the 4.5.1.56 version, by any chance? Can anyone suggest any other work-arounds (other than doing it in one big lump!)? I really like how the DIM works and would like to use it to manage at least most of my newer content, but I have several very large runtimes containing content from many sources which I have organized myself over the years. I realise that Smart Content can be much more convenient and means that you don't necessarily need to physically reorganize files, and I love it when it works properly - I would just like the process to be a bit more accurate for uninstalled files. ;)
    Hope I've explained things well enough and would be grateful for any helpful suggestions.
  • frank0314frank0314 Posts: 15,116
    edited February 2013
    There has been a bug report done on the clear orphan. Myself and another mod were testing something and came across it. You have to use the right click on it and select clear orphan. As far as the failed downloads. You just need to download again. Occasionally one will fail when your doing a bunch at once and as some as you try again it goes through normally. I just did 640 the other night all at once and didn't have a failure. I have however had failures before. DAZ had stated that you need to reset your database before adding the new location to your library.
    Post edited by frank0314 on
  • SertorialSertorial Posts: 962
    I admit I have only just heard of DIM, so forgive me if I have this wrong.
    As far as I understand it, instead of us just having all our old installer files kept somewhere, this DIM will connect up with the DAZ store, re-download all your purchased content, put it in the right places and keep track of it.
    But surely most (if not all of us) buy content from many sources. The DAZ shop is only one. So what will happen to all the content that isn't from DAZ?
    The DAZ Install Manager is only intended to download and install DAZ content.
    DAZ have already explained that it cannot be done for other stores.
    You have to install zips from other store the way you would normally install the zips. DIM does not support outside brokerage zips. There is different information included with and in the zips that make it work with DIM.
    It was explained somewhere why it will not work. DIM works from your itemised order History, can you see other stores giving DAZ 3D that sort of access to their customers order history ?
  • Scott LivingstonScott Livingston Posts: 4,352
    Sertorial, since DIM won't touch your third-party content, you can continue using it just as you have been up to now. Alternatively, as some people have chosen to do, if you're using DIM to reinstall your DAZ content, you can take the opportunity to (manually) reinstall third-party content too, and/or move it from its current location to the install location DIM is using.
    Ok, thanks. Sorry for the dual post there (I found this thread after I had posted there).
    To be honest, my runtime is a right mess. Much of the content doesn't work or is installed to the wrong directory, or both. never did figure out where stuff is meant to go. I know it's in My Library\Runtime.. but below that there seems to be a mass of directories some named after manufacturers, some called geometries, some called textures. I get loads of errors when I try to load content. Usually it doesn't work.
    Well then you should like DIM. It installs everything exactly where it's meant to go.
    Yeah, but only with content purchased from DAZ :(
    So IF you decide to use DIM, you have a choice:
    1. Set up separate runtimes for DAZ and non-DAZ content (not hard...in fact this is what would happen by default, since DIM installs stuff to a new location). You'll have a cleaned-up runtime for DAZ content, and a messy-but-familiar runtime for non-DAZ content. This is what I have chosen to do, at least for now.
    2. Let DIM do its thing, and then do some organizing of your other content, to get everything neatly structured within the same place.
    There is a third choice...have DIM install stuff to the content location you're already using--but it's not recommended.
  • Cliff BowmanCliff Bowman Posts: 1,677
    If the other stuff bought from othere store doesn't work, I'd be tempted to treat that as a lesson in itself ;)
    Cheers,
    Cliff
    Thanks, but I don't think I'll bother with DIM
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
  • DanaTADanaTA Posts: 13,416
    Kharma said:
    I left mine downloading allnight and still have 300+ files to go...does it make a difference if you are d/l to an external h/d?
    I think it could. Many external drives are not as fast as an internal drive. It would also depend on the transport method. For example, USB 3 is faster than USB 2. But this is normal computer stuff, nothing to do with DIM (I haven't touched it yet).
    Dana
    cridgit said:
    I've spent the past couple of hours investigating what DIM has done to my content library and I fear there is a dim light looming.
    3. Finally, I backed up my old My Library folder and CDB, reset the database and installed from scratch with DIM. I'm about to move my non-DAZ content and metadata into the My Library folder to see if I can restore my library and let DIM continue managing my DAZ content - I'll let you know how it goes.
    I wouldn't do that. I seem to remember even DAZ advises to keep the new DIM-installed content in its own folder structure for best results.
    Why give yourself more headaches?
    Dana
    edited May 2022
    Redacted
    edited May 2022
    Redacted
    Thanks for the quick reply, Frank! :)
    I'm sure I tried right clicking on a number of orphans in smart content tab, but there didn't seem to be a 'clear orphan' option, nor anything else relating to the database. Do you mean right click somewhere else? Yes, I did re-download them, the next day, since they didn't work several times in the first session. I have reset the database several times now, each time I've installed another batch of products with DIM - I was hoping that I wouldn't have to keep doing it (can't remember if I reset it before adding the new location). I don't like to download and install hundreds of files at one time, since I can't then easily check whether they've installed correctly. Also I like to keep the installers and organise them into their own folder categories, by content type, before archiving them for back-up, though I know you can just tell DIM to delete them now.
  • rbel_295e7c1d4crbel_295e7c1d4c Posts: 99
    As I indicated in an earlier post I am not able to login to DIM. The pop up says ‘unable to login to the specified account’. I have double checked the email address and the password (which does not include any any non alpha-numeric characters).
    I uninstalled DIM and reinstalled it but when I open the login screen the email address and the password now appears in the Account field. I imagine that this is the result of a registry entry not cleared during the uninstall process - does anyone know whereabouts in the registry (or User files) this info is liable to be lurking.
    In Win7: C:\Users\Public\Documents\DAZ 3D\InstallManager\UserAccounts
    Many thanks. Entry found and deleted and am now able to login without problems.
  • Acudia4151Acudia4151 Posts: 68
    Look at my Hair plugin is not showing up in my downloads for the dim.
    Are you trying to remove the orphan from within the smart content panel or the actual content library. It needs to be from the content library if I'm not mistaken.
  • fixmypcmikefixmypcmike Posts: 19,740
    1. Firstly, easily 75% of the products intalled with incorrect and incomplete metadata. @DAZ: you have some nerve expecting your users to uninstall their existing only to replace it with something completely broken. I have filed several dozen bug reports and gave up around "H". I am so annoyed about this I don't have any nice words to say.
    2. Hard to believe, but a bigger problem than defunct metadata is the fact that I seem to be missing assets. Although DIM got my purchase history almost perfect, I've only been installing the DS4.5 installers. Take Starship Stingray as an example: I have all the DS4.5 assets, but there are other assets missing e.g. M4's sitting pose (I discovered this because I happened to be fixing the DSX metadata file).
    So how do I get all the required assets for each product? Do I have to install ALL the installers (DS4, DS3, P12, P9 etc)? Or do I have to manually check the asset list in each DSX file to decide whether I should try install the DS4 or DS3 or P12 installer? Either of these would render DIM entirely useless to me.
    Wow 75%? I've found some bad metadata, but only about 4%.
    I've found a number of products (vehicles) that have the pilot poses only in the Poser version, which I've been reporting.
    I do the same, archiving the zips in separate folders after installing.
    "Remove Orphaned References" is in the Content Library options menu under "Content DB Maintenance".
    Most plugins aren't in the DIM downloads yet.
    edited May 2022
    Redacted
    cridgit said:
    Obviously this stuff wasn't tested before release.
    I suspect that we are beta testing the content as much as we're beta testing the program. If it all pulls together and DAZ don't drop the ball, then based on my (fairly minimal) experience with it so far, it should be wonderful when it's finished :D
    Cheers,
    Cliff
    I've been using the remove orphans option in the context menu for the actual content library. There are no product icons there for me to right-click on, since they have been uninstalled, so I was confused about what you were right-clicking on.....thought you might have meant the icons in the smart content panel. I'm still not sure what you are right-clicking, Frank, sorry for the confusion. Not very good at explaining myself. :)
    I hope user who want to use same folda which content have been installed for DIM,
    not see many trouble ^^;
    even though I unisntall one by one items by ds uninstaller
    after that install only 4.5 items by DIM on same directory,,(
    I find many duplciate product , and orphan files.
    it is because I made many original meta-data for items which daz have not offered yet.
    and DIM make some wrong meta-data , or only make catgory not meta-data.
    I know there must be more safety and simple way to keep meta-data ,
    and not merge new prodcut data by DIm, but I missed it.
    so that manually corrected each orphan files (need to use "remove orhpah files"
    on each product ) and about some product,
    remove meta-data,, then improt meta-data again,,,
    I know DAZ recommend to use new directory for DIM .
    so if use DIM with same HD (not daz recommend default location),,
    I recommend make another folda for DIM in HD (or volume)
    eg Mylibrary and newlibrary ,then install items newlibrary by DIM
    and change user default directory to newliblrary in ds.
    after that uninstall items which you need not any more by uninstaller
    one by one ^^;
    Thanks Mike. Yes, I know it is there and have been using that. Was just wondering if there was another way to do this, since Frank mentions right-clicking on something and choosing clear orphans - couldn't find where it was possible to do that. Didn't explain myself very well, lol! that remove orphaned references option doesn't seem to work very well most of the time, and that was the reason for my original query. Seems the only way to completely clear the orphans is to reset the database and re-import metadata - I've had to do this several times already, since I am uninstalling small batches of files at a time, then reinstalling with the DIM. Makes the whole process more time-consuming than it should be.
