Star Trek Builders Unite 3 “Runtime Amok”
18911131450
  • blutobluto Posts: 915
    edited January 2013
    this just up . space chicks for v4.2
    http://www.sharecg.com/v/67101/browse/11/Poser/space-chicks-for-v4.2
    cool thing is that the morphs work on m4 as well !!
    let me know if there is a problem with them and please post some renders
    823 x 506 - 35K
    Post edited by bluto on
    PDSmith said:
    the problem I'm finding is I can subdivide the mesh once in zbrush if I'm useing genesis but not at all if v4. In V4's case as you saw the ridges are soft as you said. for genesis the problem is I'm extremely limited with outfits. auto fit and the smoothing modifier as ineffective for armour and outfit selections.
    The era is post-TNG and cross breeding klingon's and humans in the Empire is pretty much the same as saying you're a Vulcan...death sentence.
    ideas anyone?
    -Paul
    Can you paint a displacement map or normal map in ZBrush instead? Or even do a combination of Inj Morph + Displacement (or normal map)
  • DemonslayerDemonslayer Posts: 125
    edited January 2013
    Thalek said:
    Redfern said:
    Okay, I'll do that soon. Right now, I have the male suit in the T position. Helmet, attachments, hose connectors, etc. are on there, and colored correctly. It's still in 3ds Max right now.
    Don't leave us "hanging" like this. At least post a "clay" render of the native .MAX data.
    Thalek is probably our best expert on the Tholian EVA suits. I'm sure he's bursting at the seams to view it as well. I know I am!
    Sincerely,
    Bill
    I won't call myself an expert, but I did own a lovely replica made by Andy Monsen and Roberta Brubaker. I can't recall if I've posted that image here or not.
    Yeah, "bursting at the seams" is how I feel right now, and let me tell you, it's not something you want to have happen while wearing an environmental suit! [grin]
    Okay, here's a sneak peek: http://i463.photobucket.com/albums/qq353/Raymar3d/tempTOSSpacesuit/SpaceSuit_Revised.jpg
    The suit is the M3 Bodysuit, the boots and gloves are modified versions of the Apollo Spacesuit for M3. I exported the V4 catsuit and the M3 suit again with wrinkles added so the suit would look more realistic. But the actual parts are going to be separate so that they can be used on any suit you want to use them on. The big problem with this is the hoses on the outfit as they cross joint lines. In 3ds Max, I'm just going to add a biped to it and animate it there, but I want to make this available to the community so we can all use it. -- Ken :)
    Post edited by Demonslayer on
  • ThalekThalek Posts: 318
    edited January 2013
    That's pretty damned good!
    I was thinking of putting the hoses on the chest plate and making them posable, myself, like an octopus's tentacles, if making them part of the suit didn't work.
    I don't think you'll be able to distribute it if it contains parts of other costumes, though.
    Post edited by Thalek on
    Yeah, I will only distribute the original stuff, not the stuff I'm using for reference. But if it can be posed/linked/fitted to the figure, it should work. I'm able to do it with my eyes closed (almost) in 3ds Max, but Poser/Daz... not sure yet. I have the utility to fit/conform but haven't tried it out yet. -- Ken
    What utility is that? I know that Phil Cooke's Obj2Cr2 can make conforming clothing from object files.
  • RedfernRedfern Posts: 1,648
    :bug: :bug: :bug:
    What we need is the emoticon that drops its jaw several times the height if its head as that one more appropriately describes my reaction at this moment.
    That is %^&* cool!!! That really captures the essence of the Minor/Theiss design! I certainly wish you well on the rigging issues, but if it doesn't pan out, I'd gladly accept a static prop of the helmet and shoulder yoke elements without the extended hose pieces. One can always explain it as a variant design.
    Sincerely,
    Bill
    Redfern said:
    :bug: :bug: :bug:
    Sincerely,
    Bill
    Another alternative might be textures and displacement maps. That was what I had been considering for a long time.
    Thanks for the praise! :)
    As for the utility I have and haven't figured out yet, this is it: Content Creator Toolkit (CCT) http://www.daz3d.com/software/plugins-utilities/content-creator-toolkit-cct Anyone any good with it yet? -- Ken
  • PtropePtrope Posts: 696
    Looking GREAT, Demonslayer! I sure hope you plan to share these - I'll come up with SOMETHING just so I can use them :D.
    Thalek said:
    I speculate that parenting one prop to another will drag both into the setup room, but I haven't tried it yet.
    Good tip, sir. I'll try that tomorrow, if time permits.
    Yup, group the objects. Although, honestly, I tried it as a test yesterday and didn't get the same sort of results as I got with the Medusan, so I think I'm missing a step somewhere, or went somewhere I shouldn't.
    The other alternative is to simply make the circlet in two parts, the same way I described, parent the opening part to the stationary part, parent the stationary part to the figure's neck, and then save the grouped parts as a single prop after setting the origin of the moving part where you want it to hinge (this is how I originally created the Medusan for distribution). You can edit the PP2 file so that all of the translation settings are hidden for the opening part, so the user doesn't accidentally dial it away from its position - just leave the one rotation dial (probably "Y Rotate") as "hidden 0" in the PP2, and rename the dial to "Open."
    I'll try to do a couple more tests on the other technique - I know I've done it, but clearly I didn't write down the steps ;).
  • Wolle1962Wolle1962 Posts: 0
    Thanks for the morps, but there is a little problem:
    The andorian files are missing
    Here is a render for you
    860 x 592 - 315K
  • TheCastellanTheCastellan Posts: 711
    The crew, well, main ones, anyhow, of the new refurbished Stargazer of my planned comic.
    1030 x 870 - 208K
    1030 x 870 - 218K
    1030 x 870 - 203K
    1030 x 870 - 178K
    1258 x 870 - 193K
    Two more. :)
    1030 x 870 - 213K
    1030 x 870 - 198K
  • mdbruffymdbruffy Posts: 2,345
    wolfgang this is great! Where'd you get that hall?
    Two more. :)
    Finally got it out of the spacedock, huh? :-)
    Looks good.
    mdbruffy said:
    Wolfgang this is great! Where'd you get that hall?
    I'm betting it's a screen capture from Star Trek Online.
    Sincerely,
    Bill
    Just a backgroundpicture found in the web. I think its from Startrek online
    Just wondered. Looked like it would have been a good match for Rduda's Great Hall and Bluto's city buildings.
    yea i seem to have gotten a little ahead of my self . working on the fix for them now . if all goes well the fix will include founders jem'hadar vorta and tellerites as well as the andorians
  • MotoTsumeMotoTsume Posts: 520
    That is the Klingon Training Hall from Star Trek Online
    Couple of images of the suit replica that Andy and Roberta made for me so many years ago.
    http://www.costume.org/gallery2/main.php?g2_itemId=72105
    http://users.keyway.net/~thalek/Tholian.html
    edited January 2013
    mdbruffy said:
    Two more. :)
    Looks good.
    The Stargazer or Vanda?
    Post edited by TheCastellan on
    mdbruffy said:
    Two more. :)
    Looks good.
    LOL!!! :lol:
  • rdudarduda Posts: 586
    If you haven't been by my project room , you may not have known I've started a voyager sick bay, so here is the latest so far:
    1140 x 711 - 242K
    1135 x 729 - 162K
    1125 x 745 - 110K
    1124 x 753 - 111K
    You've been a busy boy! Looks good!!
  • PDSmithPDSmith Posts: 715
    edited January 2013
    All renders are done and now to start the word balloons.
    i should have it done by next weekend.
    Next issue will take some work. I put my foot in my mouth. The entire book will be rendered in Lux via the Reality plugin fof DAZ.
    For you Poser users. Reality3 will be coming out in the near future for Poser 9 and Poser Pro 2012 .
    858 x 1200 - 644K
    Post edited by PDSmith on
    Dude that looks fantastic!
    Show off! :)
    I've still got 77 pages plus the credits....
    My keycard stopped working, so I can't get in.
    Man, that is beautiful!
    As a guy who spent more than seven years playing a doctor, I have a certain affinity for Sickbay aboard any ship.
