Show Us Your Bryce Renders! Part 2
1…3738404243…50
  • David BrinnenDavid Brinnen Posts: 3,136
    _ PJF _ said:
    Don't know much about history...
    but I do know that I can't figure out where I've gone wrong with setting up the tutorial scene. Whilst this is low noise for boost light use, it's way higher than appears in David's scenes. There's aliasing too.
    Actual size at 256 AD - sorry, rpp.
    My scenes are mostly lit with a large fairly even TA light-sources and that helps a lot with the noise. Also... I often add one or two normal radial lights here and there, because this also reduces noise.
    In your example, your predominant light source is relatively speaking small. And the smaller it gets the worse the noise gets I've found. So what I would do is put a few ordinary radial lights inside the lit sphere that don't include the lit sphere as a target and supplement the TA effect. It won't be as nice and pure as your original example, but it should help with the noise.
  • Roland4Roland4 Posts: 0
    The bridge
    750 x 500 - 349K
  • eireann.sgeireann.sg Posts: 0
    Roland4 said:
    The bridge
    Any more light?
    It looks so dark and in the dark all details get lost.
  • RarethRareth Posts: 1,462
    Roland4 said:
    @Rareth
    better now ?
    it looks great, although I'm not the one that commented on the DOF in the first render.
    ok screen grabs of the specular halo setting I've been playing with, I'm sure the guru's could come up with a better way to do this.. or even make what I've done work alot better than what I have done so far..
    also attached a wire showing how the dome lights are set in the scene.
    661 x 505 - 152K
    1676 x 800 - 327K
    @eireann.sg
    better now ?
    750 x 500 - 411K
  • HoroHoro Posts: 11,775
    This is a beautiful scene, Roland. If you contemplated it that way, than everything is fine. My suggestion would be to add a stronger light from a direction, e.g. sunlight, to give it more contrast. The lit part are only a bit brighter than the shadows. This would also give the scene a better 3D feeling.
    Thanks Horo. Over the scene in the middle is a blue Radial Light with 0 specular and 4 diffuse and no shadow. Behind the camera is the same but the color is a dark red.
    and now i have add a additional Radial Light from the direction of the sun.
    750 x 500 - 414K
    As I said, the artist is the final judge of his/her artwork. Personally, I think it improved.
  • cjreynoldscjreynolds Posts: 155
    Do you, by any chance, use a Mac? Just curious..
  • JamahoneyJamahoney Posts: 1,791
    Brrrrr...cold tonight in the observatory. Still, that galaxy in the ‘scope’s eyepiece would warm the coldest of astronomer hearts.
    Title: “Moments in the eye”.
    Jay
    1200 x 599 - 539K
    1200 x 650 - 490K
    No, win 7 PC.
  • Electro-ElvisElectro-Elvis Posts: 952
    I am not the fastest, I know. That's why I was still working on a knife (David and Dave inspired me to it). It is a pure Bryce model. All materials are from the library. An ordinary sky.
    640 x 480 - 29K
  • GeroblueJimGeroblueJim Posts: 0
    Trying something that looks better. Two rocks, and two terrains. Basically, water level, with a ground plane and the 4 objects. I tried to change the water level, but it doesn't look like I thought it would. Rocks Beneath, turbulent. I have downloaded Bryce Pro, but not had a chance to install it yet. The orignal is larger, but I cropped it as the rest is open ocean.
    Any suggestions on how to improve this ?
    Thanks.
    Thanks.
    Try to change the angle of your camera. This way it looks dull. Show us a bit of your heaven. Further it depends of your intention. Realistic isalnds? Stones in the water?
  • pumecopumeco Posts: 0
    I might not have much time to post, but I still intend to read for now, and bloody hell, Armageddon thread or what.
    It's even less Bryce-related than the Bryce post-work!
    You wouldn't catch me going off topic like that!
    @dwsel_
    Liking the post-work.
    @Roland
    Liking the Bridge render, I actually prefer the dark one, I like the overall feel of it better.
    edited December 2012
    Thanks.
    More realistic islands, with a beach along one side, flat areas. Maybe some buildings later on. As for the rocks, birds could live out there, or some ruins with birds.
    More of a side view showing the sky. I can change the sky, I just clicked sky view and took the one it gave. I think a bluer ocean and a night sky with moonlight would look better. What do you think ?
    (Signing off for sleep, I get up about 2 hours after midnight and head for work.)
    1039 x 465 - 664K
    Post edited by GeroblueJim on
    Roland4 said:
    @eireann.sg
    better now ?
    Yes, better now.
    Its nice to see some details and some more colours.
    You dont want to burn your colours with too much light but there should be enough light to show everything you want to show and the lights and / or sun should create the right amount of shadow so the picture doesnt look flat.
    If that was a photo of mine I would colour correct it towards blue to get rid of all the red.
    Post edited by eireann.sg on
  • Dave SavageDave Savage Posts: 2,435
    Welcome GeroblueJim.
    It's a good starting point, but the first thing I would do would be to create a viewpoint and composition that showed off the depth of the scene.
    Think about foreground, mid ground and background and try to get the elements to overlap each other, this will further increase the illusion of depth.
    In the render below, I've tried to keep the elements the same as the ones you've used, but you'll notice I've got the camera much lower so that the islands are overlapping the horizon line breaking it up and that the foreground island is most definitely in front of the background island.
    I've then further added to the depth and illusion of distance by increasing the thickness and density of the haze (in the sky lab).
    Other things I've done to tweak the basic materials are to try and make sure that the geology matches, so both islands are covered in the same basic material and the two rocks are a similar colour to the rock showing through on the islands.
    Don't be fooled into thinking Clam Waters are actually calm, usually I have found they produce much better reflections and tweaking the frequency will allow you to lose the almost grid-like uniform appearance of the waves. In my render I've used Calm Water; Deep Sea.
    Finally, to make the beach, I duplicated the terrain and flattened it out, dropped it down to ground level and gave it the standard 'Bright Beach Sand' material which you'll find in Terrains in the Plains sub category in the material library.
    Hope this helps as a starting point for you to produce a landscape you will then be ready to start populating with buildings, birds and maybe some ships. :)
    PS: You really should take advantage of the free Bryce Pro 7 download though as it's capabilities are much better and the extra content supplied by our very own David Brinnen will help you to achieve more realistic materials in your islands.
    1000 x 500 - 202K
  • GussNemoGussNemo Posts: 1,855
    @Roland: The last image is, IMHO, much better. If only because we now can see the good detail you created. I too would lean away from as much red as you've applied. But that's me. As Horo said, you have the final say so.
    @electro: That's a mighty fine looking knife. Nice job.
    @Geroblue: That's a nice start. Besides what The Savage told you, also keep in mind to keep adjacent object in perspective. If you have an island, like you have, then the surrounding rocks would be much smaller than the island itself. Looking at your last image, the rock behind the green island is almost as large as the green island. To combat this either make the island larger or the rock smaller. Same goes for the other rock. You could move the other island back a bit and, with its current size, use it to portray a distant island like The Savage has shown.
    Thanks.
    this is a great start, I will also suggest you get the Bryce 7.1 pro (its free) and the included Pro content files that come with it, should be 3 downloads in all, some of the materials included are fantastic, also might I suggest the bryce tutorials site, it is an excellent resource for Bryce users .
    http://www.bryce-tutorials.info/index.html
    A few more Peter The Polar Bear pics.
    690 x 975 - 226K
    690 x 975 - 227K
  • tpstigerstpstigers Posts: 4
    "December"
    1520 x 851 - 2M
    I have 7Pro installed. Moved the second island further away. Changed the ocean. Added a sand ground plane... I think I lost in the ocean somewhere... I shrunk the rocks and changed the sky. Looks like i'm too far away from the front island. When I find the sand ground pane and get it to render, I'll post both pictures.
    Sand... I thought I had grabbed the small ground plane under the front island... but got the sea instead.
    I tried the 'layer cake' method by looking in from the side, and moving each layer up until well separate. Got the ocean back to ocean, and lost the sand somewhere.
    Second picture is without sand.
    877 x 458 - 331K
    877 x 458 - 455K
  • bighbigh Posts: 8,147
    use the TAB key to move from obj to obj - it will have red outline
    I keep expecting to see a bottle fo coke or a can of pepsi in these Polar bear pictures they remind me so much of the holiday commericals.
    I keep expecting to see a bottle fo coke or a can of pepsi in these Polar bear pictures they remind me so much of the holiday commercials.
    Exactly what I was thinking, LOL!
    Has anyone done the little santa riding on the Norelco razor? That ad's been running every year since I can remember!
