• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
mcjTeleBlender:Daz Studio scenes/animations w/Blender's Cycles Engine
«1234567…49»
    October 2012 edited December 1969
    OK so there is no Toggle System Concole option in the help menu, but the command window is up in the background and it looks like the below:
    677 x 342 - 42K
  • mCasualmCasual Posts: 4,607
    October 2012 edited October 2012
    it may mean you forgot to dump the python scripts from mcjTeleBlender's kit in the modules folder of your newly installed Blender
    on my PC that's the
    C:\Program Files\Blender Foundation\Blender\2.63\scripts\modules
    Post edited by mCasual on October 2012
    Yep your right, they were in an old version directory, thanks!
  • rayerarayera Posts: 2
    Thanks for this tool :-)
    I have a problem, I'm using Daz Studio 4.5 and blender 2.64 as you can see texture cordinate node conect from Normal and not UV for all textures, this happend in Cycles renderer, Poser internal expert correctly
    927 x 611 - 41K
    Yep, you are right. I got similar results in 2.63. I upgraded to 2.64a and same thing.
    Found it! To fix this, modify mcjAddMappersToTexImgs.py, and change this line:
    links.new( texCoordNode.outputs[1], mappingNode.inputs[0] )
    to this:
    links.new( texCoordNode.outputs[2], mappingNode.inputs[0] )
    Then UV is used, and not Normal.
    Tanks a lot 3doutlaw!! great :-)
    to this:
    i will make a new version where the script identifies the UV output by name instead of by index-number
    it was a risky way of doing it anyway
    to this:
    2 interesting things:
    i'm not totally fluent in python, so i didn't know we could do things like
        ntree.links.new(input=texCoordNode.outputs['UV'], output=imgTexNode.inputs['Vector'])
    which i found on a forum post about a minecraft-generator script for Blender
    right over here
    http://blenderartists.org/forum/showthread.php?237105-Mineblend-Blender-importer-add-on-for-Minecraft-worlds/page5
    That sure makes it easier to understand, and more robust! :) Nice find!
    (I am not a good Python programmer either, but as a software manager, I have become OK at debugging code)
  • mattiascibienmattiascibien Posts: 140
    I was testing the plugin with the last DAZ studio 4.5 and I am getting the wrong UVs using Genesis.
    EDIT: Was the bug regarding the 1 for a 2
    Also.. How can I fix white eyes using Genesis
    Post edited by mattiascibien on October 2012
    ~ Update ~~ Update ~~ Update ~~ Update ~~ Update ~~ Update ~~ Update ~~ Update ~~ Update ~~ Update ~~ Update ~
    Thanks to rayera and 3doutlaw for pointing out an incompatibility that appeared with version 2.64 of Blender/Cycles
    i modified the mcjAddMappersToTexImgs.py module which is part of the mcjBlendbot package named mcjBlendBot_October_18_2012.zip
    so you simply have to download it from my site and unzip it in your ....\Blender\2.64\scripts\modules folder
    https://sites.google.com/site/mcasualsdazscripts/mcjteleblender-for-ds1-2-3-4
    1280 x 480 - 101K
    Working fine,... But still White iris and pupil. What am I doing Wrong?
    if you create a small entirely black image, and apply it as an Opacity map to the cornea of the eye,
    you will obtain a fully transparent cornea as seen in Daz Studio and as rendered in Blender/Cycles
    sometimes there's a transparency map for the cornea, but due to export issues, the image cannot be found
    or the transparency map is part of the color map, and that's not compatible with mcjTeleblender
    so replacing it with a simple black image , like the one below, does the trick
    256 x 256 - 668B
    Going to try after dinner :) Also, sometimes when using hair i got glowing ones since the texture was a emitting map. Do not know in new versions.
    i tested the basic Genesis, and for the transparency of the cornea, they set Opacity to 0%, but that's ignored during the export//import phases, so you can fix this by applying an all-black image to the opacity channel of the cornea and they will be transparent in Blender too.
    when an object in the scene has an image map applied to the Ambient Color, mcjTeleblender makes this object emissive. Usually you'd use that feature as area lights
    589 x 800 - 57K
    Sorry I am not an expert of Cycles, how can I add the black image as a opacity map?
    EDIT: Made from DAZ and everything worked.
    ~~ moderately important update ~~ ~~ moderately important update ~~ ~~ moderately important update ~~
    i modified the script mcjTeleblender,
    ---- the batch file created when you press the "Export/open current frame" button
    can now be used to (re) launch the render process of that one frame.
    ( i removed the -b option which made Blender run in UI-less mode )
    ---- when exporting animations, the surface smoothing options were not enforced,
    resulting in very faceted bodies, maybe this became an issue only in DS4
    or it goes to show that very few use mcjTeleblender for animations :)
    i mean the results were so scary one could lose his or her 3d permit!
    same download page https://sites.google.com/site/mcasualsdazscripts/mcjteleblender-for-ds1-2-3-4
    320 x 640 - 611K
    I made a 1-click Python script for Poser based on your framework. Still missing the Camera and Lights of course, but it makes it easier.
    I say "made", but its more of a hack.
    Click here for the post over at the other site
    reading those scripts is a great introduction to poser-python
    I am working on the camera part now. I've got the camera parameters from Poser for the Current camera, now I just need to translate them to Blender, so I can put the camera part into the python for your framework. Workin' on it now.
    when i made mcjTeleblender and the script for VooDoo camera tracking
    i had to really understand well how focal lengths, filmback size and aspect ratios worked in poser/Studio/Carrara
    if you want to read it, it's here http://forumarchive.daz3d.com/viewtopic.php?t=175284
    Tempest! said:
    If you want to export an object from Blender in Poser scale you have to scale it down to 0,41 times (rounded) its Blender size.
    In reverse that means to if you export an obj from Poser into Blender, you'll have to scale it up to 2,439 times it's original size.
    For example, this way Vicky4 will be 1,73 Blender units (equivalent of 173 cm) tall, which seems about right.
    So after you import your scene as an OBJ, make sure it's selected and type S (for "scale") and 2,439 for the ratio.
    In DS there are presets for OBJ export scaling.
    DS: 1 unit = 1cm
    Blender: 1 unit = 50cm
    Poser: 1 unit = 8ft
    So if you export on the Blender preset, and the Poser preset (or export from Poser), you need to scale the Poser export around 4.878, to get a similar OBJ size as the DS to Blender preset.
    ...but in Blender, if you consider every Unit to be 1M, then this makes V4 around 11.5ft tall.
    Is the DS to Blender preset just off? Shouldn't the Blender preset be 1 unit = 100cm, thus making it more like the 2.439, thus making V4 around 5ft 9in (which is still a pretty tall lady, but at least realistic?)
    about scaling factors
    the bizarre scaling factors in Poser are derived from
    1 unit = 8ft
    so, 1 unit = 8 * 12 * 2.54 = 243.84 cm
    and 1 / 243.84 = 0.00410104986
    so, a 2 meter tall character exported from Poser with a scale factor of 1, will be
    200/243.84 = 0.82020997375 units tall in the obj file
    Blender uses 1 unit in the obj file = 50 cm in the Blender world
    the character which was 2 meters tall in Poser is now
    0.82020997375 * 50cm = 41.0104986877 cm in the Blender world
    so the export scale or the import scale factor to use, to obtain a 2 meters tall character in Blender's world is
    200/41.01= 4.8768
    the more direct way to obtain this factor is
    ( 8 * 12 * 2.54 cm ) / 50 cm = 4.8768
    unless i goofed somewhere :)
  • Tempest!Tempest! Posts: 0
    I reckon the scale of the DS to Blender preset is just off. You might as well use the 3DSMax presets when exporting to Blender, I guess.
    In Blender, if you switch the the units from "None" (the Blender default) to metrics or imperial you get 1 unit = 100cm or 1 unit = 3.281ft respectively.
    Post edited by Tempest! on October 2012
    Nah, it was right. I keep thinking the Unit in Blender is 1M cause it starts with a 1M cube, but if you look at the units scale, there is 2 units for each side of the cube (i.e. 50cm), so the 4.878 (or 4.8768) was/is correct.
    I wonder where I got the 1.73 units though... that's not right at all. I probably must have mistyped the scale factor in Blender because otherwise the calculations make sense.
    ~ minor Update ~~ minor Update ~~ minor Update ~~ minor Update ~~ minor Update ~~ minor Update ~
    i used mcjTeleblender for months before encountering this issue but ....
    if you loaded a daz scene into a pre-existing .blend scene
    and this scene contained non-applied modifiers ( for example, a subdivision modifier )
    mcjBlendBot failed ( while applying smoothing )
    this resulted in a scene with no textures.
    so i posted on my site a new version of mcjBlendbot which corrects this
    same bat channel : https://sites.google.com/site/mcasualsdazscripts/mcjteleblender-for-ds1-2-3-4[
    see the wall with round holes, it had a non-applied subdivision modifier
    1280 x 800 - 130K
    Ah, we're crossposting.
    The default cube is 2 meters across, not 1m. So, no, 4.878 is not correct.
    If you switch to metric system in Blender (under Units in the Scene tab), you will clearly see that 1 unit equals 1 meter when using 1.0 scale.
    units
    here i made a 1 unit by 1 unit plane in an obj file and imported it in Blender
    Aiko was added to the scene using mcjTeleblender
    so it was exported with Daz Studio's scale for Blender which is stated to be 2% or 1 unit = 50cm
    in Daz studio Aiko3 is about 170cm
    in the screen capture you can see the cube is said to be of dimension 2 x 2 x 2
    and is 2 times the width of the 1-unit plane
    indeed as Tempest was saying, if we go in the Scene Panel and set the units to Metric, we see the cube is 2 meters x 2m x 2m
    so when we export from Daz Studio we should use
    Scale = 1% ( 1 unit = 100cm ) instead of 2% ( 1 unit = 50 cm )
    and the Poser scale to use would be
    ( 8 * 12 * 2.54 cm ) / 100 cm = 2.4384
    second picture
    i scaled Aiko with a factor of 0.5,
    and she is now less tall than the 2meters cube, which makes sense !
    then i exported Aiko from Poser 7 and she's too tiny
    third picture i scaled up the Poser7 Aiko using the factor 2.4384
    and she now is her real size
    600 x 600 - 32K
    1280 x 720 - 116K
    1198 x 590 - 77K
«1234567…49»
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
