Product Updated: UHT2: Ultimate Color [Commercial Product] with video links... Share your renders!
13468914
  • TaozTaoz Posts: 10,271
    edited June 2016
    Original plus new render using Cutout 4:
    1064 x 1041 - 800K
    Post edited by Taoz on
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,559
    well I'm liking all the variations you've done Taozen
  • Gerardo AlvinoGerardo Alvino Posts: 28
    edited June 2016
    Jan19 said:
    After watching the video tutorials, I have focused my attempt on the colors blending, so the rendering is not at 100%.
    On Kara Hair I used Deep Red Base, Four layers in the Color Mixer: Black layer in the middle zone, Red brown layer on tips, Mask025 Ginger for strands, then the dark roots layer.
    That's a nice effect! :-)  Is that "reverse ombre?"  I saw a picture with light chunked roots and dark tips and tried to mimic that.
    I didn't know ombre was dark roots and light tips.  Shows how much I know about coloring hair.
    Thanks @Khory blush
    Thanks @Jan19 wink
    Yes Its all in reverse mode! I used the "reverse" method I tried to think like a hairdresser laugh, but i'm not, thinking about how he would do that color transition work, called balayage or ombres. Also my sister is an hairdresser and hair stylist, and recently she has brought three of hair shade levels (her blonde base, pale pink, lilac-pointed) and fake dark roots, so I had the basic idea and tried to recreate it with other shades.
    Kara hair model is divided into several parts so I thought about doing the same color transition for all parts, then I used a bright color, that started from the roots, only for the thin part.
    I think I'll enjoy forever.
    1254 x 765 - 595K
    1254 x 765 - 581K
    Post edited by Gerardo Alvino on
  • SloshSlosh Posts: 2,391
    Taozen... I used Shandi Hair, just as you did, and applied two of the new Shine presets (one is a Max Shine for light hair, the other a Max Shine for dark hair) just to show how I addressed the concerns about adding more shine to the hair.  I added four new presets altogether, and they are in testing at Daz as we speak so hopefully they will be in everyones updates soon.
    1300 x 803 - 862K
    Thanks, I'm just clicking some buttons though, it's Slosh that's doing all the hard work lol
    Looks good, I'm looking forward to try out the new options!
  • Jan19Jan19 Posts: 1,109
    edited June 2016
    This is sort of addictive.
    Goldtassel did ombre better than I ever could, but this is a long hair that I thought might work better.  Getting the idea.  Layer after layer after layer, and so on and so forth. :-)  I think I should've scooted the masks up some.
    750 x 750 - 268K
    Post edited by Jan19 on
    That looks wonderful, Jan19!  That is definitely the way I hoped it would work for people :)  And yes, Goldtassel did a great job with her ombres.  She saw the green ombre I did on the promo with the fairy (before she knew about UHT2) and asked me how I did that.  I sent her a copy :P
  • SimonJMSimonJM Posts: 6,071
    Another go, in the same sort of vein ...
    1200 x 1200 - 879K
  • fastbike1fastbike1 Posts: 4,079
    edited June 2016
    Not wanting to miss the party, here's my first go with UHT2. Willow from Mihrelle w/ OOT's Sapphire Hair. Six or seven masks with reasonably compatible shades.
    No postwork. Stopped at 72% conversion before I ran out of time (2 hours).
    2000 x 3000 - 767K
    Post edited by fastbike1 on
    Yikes!  2 Hours?  I'm guessing you are rendering on CPU, then?  At any rate, it looks good.  And it kind of makes me giggle that you used it on OOT hair, considering he/she has a similar product to UHT(1) at another marketplace.  Not trying to be mean, it just does :P
    Thanks @Khory blush
    Thanks @Jan19 wink
    Thanks for the reply and explanation. :-)  Balayage.  I like that word.  Working with UHT2 has give me a whole new respect for hair dressers.
    Well, good, I was beginning to feel like a complete failure. laugh​  Just kidding, thank you very much.  The ombre video does show things that I wasn't doing before.
    Yes, Goldtassel does great hair, I I really like the Mada ombre colors.  Nice of you to send her UHT2!
    Rendering on a GTX780. Render quality 2 @ 2000x3000. Loads the 780 to 2234 MB. While I have a fair bit of, and like OOT's products, I haven't used the OOT Iray Hair shaders since UHT1 was available. Don't giggle too much though, until UHT2, I alternated between UHT1 and IDG's Iray Hair essentials depending on the hair I used and the looks I wanted smiley.
    edited June 2016
    There are shine presets in the utilities folder. There are 4 levels as I recall. Also, Saiyaness suggested lowering the bump or normal values to get more shine. Lighting also makes a *huge* difference.
    EDIT:
    OK, lights corrected now and this time I set Normal Map to 0. It actually does make quite a difference, the questions is at what cost, if any? I also changed Cutout from default to 4, not sure how much that has influenced on the result.
    1064 x 1041 - 668K
    edited June 2016
    Hm, now I look at them it looks like the light settings on the new one are different. I haven't changed them, just loaded the saved scene, so I wonder what happened here. Are the iRay settings not saved with the scene?
    edited June 2016
    Argh, forgot to turn off the headlamp. Redo...
    EDIT: OK, picture above updated...
  • 3Diva3Diva Posts: 11,981
    I actually came here to ask if this product was compatable with the "HDRI Optimized Skin and Hair Shaders", but see that you have it listed. Did you use the shaders from the HDRI product on the hair or just the skin? I was wondering if it's compatable with the hair textures and colors with this product.
    didn't use the hair shaders in that product this time around just Slosh's but I'll give it a try but used the skin and teeth shaders yes
    I don't have the HDRI Optimized Skin and Hair Shader, myself, so I'm afraid I can't answer that.  By what I read in the description, however, I think it might be.  If it is simply a shader that adjust the shine on hair, then maybe it will work with UHT2, but if it involves replacing textures it might now work "with" UHT2 so much as "instead of" UHT2.  If anyone who has both is willing to share your thoughts and impressions of using them together, please do so here.  I'm curious, myself.
    Hm, I could rock that look. smiley​  Just kidding, but I do like it.
  • grinch2901grinch2901 Posts: 1,247
    I noticed some real render time impacts when playing with this in an empty scene with just G3F and a hair.  Should render reasonable fast even on my meager system with low render quality settings but it was taking a long time to converge.  I think it was the backscatter, I turned that off and it improved the time but it did change the look of the hair.  A tradeoff I guess.
    hmm... I didn't use back scatter settings in UHT2... or were you referring to UHT1 or the HDRI hair product?
    Oops, it was UHT2 Scatter On/Off, not backscatter.  I guess thats driving transluscency scatter / transmit? I don't know.  I was experimenting with the settings and that seemed to help me.
  • DustRiderDustRider Posts: 2,893
    edited June 2016
    I played around with the color mixer a bit and re-rendered the image I posted earlier. I added just a touch of brunette to break up the black a bit and add more definition to the hair, I also turned down the shine a notch, and added a touch of sss. The differences are very very very subtle, but they are different. I like this "new" hair better than the first one.
    1333 x 2000 - 387K
    Post edited by DustRider on
  • IceDragonArtIceDragonArt Posts: 12,841
    I actually want to reach out and touch her hair and see if its as soft and smooth as it looks.
    Thanks! Of course 90% of the credit goes to Slosh for the great plugin. Except for the addition of the sss, I just used to tools provided by the pligin.
  • BlueIreneBlueIrene Posts: 1,318
    edited June 2016
    Is nobody safe?
    640 x 640 - 619K
    Post edited by BlueIrene on
    Is it bad I read that as 'added a touch of ass' ..? blush
    Ugh I did the same thing lol.
