Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
I see Connecting to CMS and then a bunch of stuff flashes by too fast to see. I haven't noticed Ugrading CMS. Is there any smoking gun in the log file?
Do you install content using DIM?
I install with Daz Connect and a few things like Daz Studio itself and plugins with DIM.
Ahh, I think I may have found to problem... Thanks for the REMINDER to look at the log file... I should have looked there first!
[Log file snipit]
2016-19-13 17:19:49.356 WARNING: cloud\dzcloudtasknotifier.cpp(178): Upgrading database from version: 39
2016-20-13 17:20:16.310 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in upgradeDb: ERROR: duplicate key value violates unique constraint "category_content_content_id_category_id_key"
DETAIL: Key (content_id, category_id)=(444344, 209) already exists.
[End snipit]
A couple of simply queries and all of now well with my DB. :-)
App loads much better now!
Hello All,
I installed the Beta-Version and when I try to load Genesis 2 (male and female) I get en error message. I updated everything in the program, my lybrary is there but I still get this error. Genesis and Genesis 3 are fine. Can anybody help me with this, please?
I'm getting duplicate error quite a lot now.
Could it relate at all to using a product that has since been updated?
Not sure if there are different kind of duplicate errors that are triggered by different causes.
What I know about is products that cause duplicate id errors whenever you place any actor of the same figure line into the scene:
Example:
If you have installed Victoria 7 Attitude Expressions - SKU:22162 then whenever you place any figure based on Genesis 3 Female in the scene a duplicate error is triggered.
http://www.daz3d.com/victoria-7-attitude-expressions
What makes duplicate id errors difficult to track down is that the product you place in the scene is most likely not the one that is causing the duplicate error.
Basically a little line of code in one product is adding conflicting information to all other products of the same figure line.
-> Check the forum for other posts which point out products causing duplicate errors and do not install them on your system.
It has started occuring in the last two beta releases; it used to happen if I loaded the default G3F figure; now it happens when I load an existing figure, which didn't previously trigger the error.
Is this the first time you've installed a beta? Note that the beta is installed alongside, not replacing, whichever full release version you were already using. It does not use the same settings (interface setup, content folder locations, etc.) that the full release uses, so you must check both versions to make sure the beta is set up the same as the full version. If you don't do this, the beta will only look in the default locations for content, no matter what your full version settings are.
thank you very much SpottedKitty :-)
Thnks to you I found out what was wrong. Had the wrong path there for Daz Connect and two pathes for the content;-)
Now it works. But strange that it only did not work with Genesis 2.
Have a nice weekend, Ulrike
If you're using Connect, remember that's one more content location that must be checked and, if necessary, changed. And this must be done before you do anything else in a new installation, whether full release or beta, and whether you're adding new content, re-installing things you've already bought, or creating new scenes. Anything else runs the risk of having orphaned files that were created or installed using the wrong content locations, but now can't be seen by D|S because it's now looking in the proper locations.
Also, Connect is a little bit weird; it behaves for some people, but not for others who set up their systems in exactly the same way.
yes, thank you SpottedKitty. I did not use connect till now with the beta. Everything seems to work now as far as I could see.
Had some problems with connect with the General Release version but probably because I did something wrong ;-)
Well I just installed 4.9.2.60 damn and it did not want to install using Connect on my system other than some parking folder
so used Install manager and I really love it , the increased speed in rendering by 20% more with multiple cards , the resolution pixels in draw mode , less msec needed for camera rotation in iray viewport even when set on Normal and color overlay is cool just played with it under Shader mixer the other day when building custom shaders plus no more interactive crash with display driver ...
you can read my mind .. all my prayers was answered
now back to install the newest beta build as I spotted something new I wanted for the photometric lights
public build 4.9.1 + was a nightmare, you should replace it asap .. especially as interactive mode is crashing on GPU so draw mode not usable
Yep! It's really much better than previous beta. Finally something to call "stable".
loving it .. no more boxes and planes or guessing , I am very content about this build so far the best for me
at@rbtwhiz or @Daz_Vince
I tested the Light Portals but there is no difference in rendering time or less noises
are we talking about Light portals that show iray where the light come into the room reducing the calculation time and the level of noises or we talk about Daylight portals but for those I am missing some settings
I would like to know
thanks
-Rob
Request #219367
Iray Uber shader, volume transmission color not work without setting transmission texture as white.
when set non texture, with set color as white, it show transmission volume effect correclty.
but set color "non white" eg, 245 255 253, it not set volume color (transmission) correctly.
it treat the each R,G,B value, if It is not 1.0 (255). set as zero. then
when I set color (0.71, 1.00, 0.96) , without texture (default), the transimission color seems set as (0,1.0,0). then transmission volume color
is perfect GREEN.
And the Volume transmission texture seems not work at all, even though I set clear one Color texture,
it never change ,emission color.
so that,, at current the Volume transmission color only work, when I use white texture, and set color. I think.
Add color texture map have no meaning, I think.
And please add option, to set SSS Amount value , more reasonable way..
eg set value 0.00001 or 0.00005 can not adjust by slider . . may better add multiple option to adjust easy.
It is not about light source cast by Enviroment map. all lighs source are default photometric light.
with cylinder volume. (it cover the Actor , in the room) I did not test with Env image light source.
And thank you DAZ,, iray uver shader seems not option to set Volume density by texture.
Maybe I need to use Shader Mixer, just to add volume density, or is there hidden option, which I have not found?
(maybe DAZ really hope user to learn shader mixer MDL blocks.or User buy product shader,
just to apply texture for volumetric density. )
Thanks Rob , that exactly what I was thinking , the same way as in Blender
just want to be sure since very older iray version had Day light Portals before as well
Carh
Love the ligh portals, it's like Cycles in Blender.
The rendering speed increased with when you cover small window with the light Portal but works only when there is very little light from the sky , no direct sun
so if you render 40 min you will save 10 min with it , not visual difference just little faster calculation , the effect is better in Blender as blender cycles calculations are much slower than iray so you profit from that a lot
but if someone have slower card in iray it will help for dark indoor scenes with little windows .
I am excited about 4.9.2.67 build in general , so much improvements .
According to nVidia's Iray page, there are some new features in the latest Iray.....
A third rendering mode....Iray Realtime. OpenGL 3.3 based, but approximates Iray shading/lighting. Looks like we'll have Iray Realtime for the viewport, Iray interactive for the mini-view, and Iray Photoreal for final renders.
Screen Space Ambient Occlusion in Iray Interactive. Nice boost to the realism in interactive mode!
Interactive mode also got Path Space Filtering, to reduce grain/fireflies on the final frame.
( sample images and info at http://www.nvidia-arc.com/products/iray/rendering.html )
How long before we see these in DS? Iray has had Motion Blur for a LONG time....why hasn't DS implemented it yet?
*sits and waits impatiently for more Iray updates news*
Ah,, I now understand the correct setting value for volume .
I needed to set more high value for Transmitted Measurement distance. eg 500 (cm) etc,, to see gradually change trasmisison color ,
from white to the color, I set,, in volume smoke or dust.
So that, transmitted measurement decide, the thickness (cm) of volume, white lay change to the Tramsmission color?
Sorry, i know daz document,, but I could not understand, what actually DAZ document said about the value.
then,, why when I apply white texture,, it lost all color then, change to white? the transmission color value is not multiple with texture color?
the texture of transmission color is for controll density , not to adjust color ?
Some bugs that may or may not be related to the UI scaling options introduced or changed with the last versions.
- The Shader mixer pane does not snap to the lower UI borders at all.
- Whenever the Shader Mixer pane is placed next to the viewport pane the viewport pane seems to inherit the failing snap functionality of the Shader Mixer pane and now the viewport pane does not snap to the lower UI borders.
-> The aspect ratio frame extends below the visible area of the viewport pane.
If the Shader Mixer pane is removed the Viewport pane will now properly snap to the lower UI border again.
Reproducability:
The Shader Mixer pane not snapping to the lower UI borders can always be observed.
The Viewport Pane not snapping to the lower UI borders seems to behave a bit randomly.
Sometimes you can reproduce this error the momemt you add a Shader Mixer pane next to the viewport pane.
In some cases the error can only be observed when you restart DAZ Studio again after placing the Viewport Pane next to the Shader Mixer pane.
First Detected:
I noticed this the first time when I put together a new UI for Daz Studio Pro BETA - version 4.9.2.60.
System Information:
Display Resolution 1920x1080
Windows 10 64 bit
Nvidia Driver 365.19
Update / Edit:
Thank you Richard, seems this was allready covered. Will recheck with next build.
In the change log, for the version after the current Public beta, there's an entry:
Now It happen for me to check uber iray shader volume blicks,, then I try to separate shader builder pane, as window mode, (usually I use the option)
ds suddenly shut down.
I feel no excitement this version beta. . but the morph loader improvement is good (the mirroer option is useful and I could understand how it work)
but another option can not find how to use it.
maybe DAZ will offer document about these new option usage after I died.
Real time is for a while already together with motion blur , It would be nice if we have OpenGL real time as an option under Draw mode so you can switch , low card users could better navigate the scene as regular OpenGL is not usable with iray shaders or photometric emitters .The screen space AO looks good too, who knows maybe private beta build have it already .. fingers crossed for the upcoming updates but beside this funky stuff I would love to see better work on the IES profile so it load correctly and not at 90 degrees on the X , if you use with point light no big deal but with shader emitters it is , as you don't want to rotate the geometry -90 X 'to correct the orientation of the light profile , thinking here about sky lights with material representing light , you can't use IES profile with that so ....big limitation
Have you reported it?
No need to report, it is not a bug , DS axis are different
BTW can someone help me with this issue , when I load Uberiray standard shaders or genesis from My Library or DAZ Connect Library , I get message like the one below
it ask me to close DS , only DAZ base products that are included with DS , no problem with other products
