*CLOSED* RRRR "That went well" Render Contest
Totte
The RRRR is back for another round!
This time the theme is "That went well", somewhat inpired by the Serenity episode with that same name. So, anything goes this time, because whatever you did, it might have gone well in the end.
RRRR stands for Random Runtime Roulette Renders, and it's a contest that has been running for over seven years until it needed a well deserved break. We invite anyone to enter, specially all those new users who have shown up the past years. This is not the usual make a very nice render contest but more like tell a really great story, often fun, with your render!
How does it work?
Make your pull of 4 items, and if your any Lucky Bastards, you pull one extra item per LB.
Who can play?
Anyone can play!
How do you prepare yourself for play?
The rules are very simple, but first you need to have all your items in some kind of order in a text file, dumped from the itemized history into a text file or a spread sheet. Remove things like software, gift certs, and special plugins from the list and items that wil not work with the software you work with.
For example if you have items for Poser, Bryce or Carrara, and want to use DAZ Studio, remove those other items from your list. If you have loads of older figures, M3, M4, a ton of non Iray stuff and you only want to use Studio with Iray, remove all the junk from you list. (I personally will see much joy in dropping Camel, I don't know how many times it has been pulled over the years)
Then you use a randomizer to randomly pick items from your list (your Runtime/My Library) for your start pull . You can use items from any store. Now build a scene with those 4 items plus any other items you want to add to make a fun scene. For newcomers I heartly recommend looking at the previous contests below to get ideas how you can do this.
Working randomizer:: https://www.random.org/integers
There are some situations where you allowed to redraw, these are:
- You pulled something that doesn’t work, broken thing, only works in a version / software not used etc etc, or you forgot to remove that item from you list even though you knew it wont work, or figure that out later.
- You pulled a software or add-on to a software or anything you should have filtered out from the list.
- You pulled only huge environment props and will not be able to render a scene without crashing.
- You pulled an item you already have been using in two RRRR renders in this content and that was picked randomly. Three is a curse - rule!
Lucky Bastard Rule!
I say this again: If you have Lucky Bastards, you pull one extra item for each LB you have, simple as that.
Explaination of Lucky Bastards.
Lucky Bastards, or LBs, are a form of handicap system which makes the contest a little more difficult for those who have won. No lucky bastards are in play now, but will be for the next run.
Current Lucky Bastards Standings:
| Player | LB count |
| f.boschanski | 2 |
| Totte | 2 |
| Rafael | 2 |
| Bohemian3 | 1 |
| Luci45 | 1 |
| Gopherus | 1 |
How to play?
You pull, you compose and you Render. You post your images and pulls in this thread (Don't miss that, entries without pulls and posts in this thread will be disqualified!!).
Then the entry should also be posted in the Entries only thread
Bundles
If you pull a bundle, use two or three complete items from it, or more if you like, but you do not need to use all, but only picking a hairpin from Victoria 8 Pro Bundle is “too little”. Clarification: A bundle still counts as only one pulled item.
Poses, Expressions and textures/colors
If you pull a pose pack, an expression pack or a texture/color pack, you only need to use one of them, not all. For example if you pull 500 expressions for Genesis 8 Female, use one, if you pull 128 colors for Frappe Hair, use one.
Accidenty breaking the TOS
If your entry is removed by the forum mods because it accidentally, not deliberate, broke the TOS, you do not have to redo that entry but can move on and make a new pull.
The rules of madness!
Now you have successfully and randomly picked your items, make a scene, you can add other items as well but the one you picked should be prominent or cleverly used. Render it, post it and make us all laugh! Remember though that the renders must follow the TOS of the forum. As we have a theme on the contest, the render should in some way touch that theme.
The contest categories!
There are two categories Best and Funniest. Every image will compete in both categories.
Contest duration!
It starts now at Thursday November 23 2023, and will go on all over the holidays until Sunday January 28 2024 at 23:59:59 local DAZ time.
This months sponsors so far:
Totte (Code 66) is sponsoring with two items from his store
A $20 DAZ GC to the winner in each tier from an Anonymous Donor
A $10 DAZ GC to the second place in each tier from an Anonymous Donor
A $5 DAZ GC to the third place in each tier from an Anonymous Donor
We want more sponsors!
Do you want to sponsor the RRRR?
Please chip in a gift card sponsorship, sponsors can play, they should play, they are even extra encouraged to play, as sponsors always plays for keeps.
Maximum number of entries?
For this round it will be a maximum of 12 entries per player.
So, good luck and start your render engines!
List of some previous RRRR Contests
In the PC Members Only forum:
RRRR Summer Edition ( 13 June 2012 - 15 July 2012) http://www.daz3d.com/forums/discussion/2065/
Winners Thread: http://www.daz3d.com/forums/discussion/5053/
RRRR “Back to Reality / My Summer Memory (15 August 2012 - 23 September 2012) http://www.daz3d.com/forums/discussion/5759/
Winners Thread: http://www.daz3d.com/forums/discussion/9315/
In The Commons: RRRR Commons Premiere (9 October 2012 - 18 November 2012) http://www.daz3d.com/forums/discussion/9325/
Winners Thread: http://www.daz3d.com/forums/discussion/12867/
RRRR “Sayings” Contest (6 December 2012 - 31 December 2012) http://www.daz3d.com/forums/discussion/12867/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/12877/
Winners Thread: http://www.daz3d.com/forums/discussion/15094/
RRRR Contest (18 January 2013 - 24 February 2013) http://www.daz3d.com/forums/discussion/15285/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/15307/
Winners Thread: http://www.daz3d.com/forums/discussion/17908/
RRRR “April Fool” Contest (with “Mini” Contests) (21 March 2013 - 21 April 2013) http://www.daz3d.com/forums/discussion/19109/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/19108/
Winners Thread: http://www.daz3d.com/forums/discussion/21780/
RRRR Summer Contest (23 May 2013 - 4 August 2013) http://www.daz3d.com/forums/discussion/21780/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/22664/
Winners Thread: http://www.daz3d.com/forums/discussion/27864/
RRRR “Chain” Render Contest (15 September 2013 - 13 October 2013) https://www.daz3d.com/forums/discussion/29000/closed-rrrr-chain-render-contest/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/28997/
Winners Thread: http://www.daz3d.com/forums/discussion/31526/
RRRR “Chain” Render Contest - Round II (1 November 2013 - 1 December 2013) http://www.daz3d.com/forums/discussion/31615/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/31760/
Winners Thread: http://www.daz3d.com/forums/discussion/33417/
RRRR “Story” Contest (4 December 2013 - 12 January 2014) http://www.daz3d.com/forums/discussion/33479/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/33478/
Thread: http://www.daz3d.com/forums/discussion/36407/
RRRR - One day in XXXs life Render Contest: 13 February 2014 - 16 Mars 2014) http://www.daz3d.com/forums/discussion/37042/
Entries only thread: http://www.daz3d.com/forums/discussion/37041/
Winners thread: http://www.daz3d.com/forums/discussion/39504/
RRRR Classic (19 May 2014 - 22 June 2014) http://www.daz3d.com/forums/discussion/41451/
Entries only/Winners; http://www.daz3d.com/forums/discussion/9325/
RRRR Freak Accindents (15 July 2014 - 10 August 2014) http://www.daz3d.com/forums/discussion/43832/
Entries only/Winners: http://www.daz3d.com/forums/discussion/43830/
RRRR Back to renders ( 25 Aug 2014 - 28 September 2014) http://www.daz3d.com/forums/discussion/45619/
Entries only/Winners: http://www.daz3d.com/forums/discussion/45617/
RRRR Things to do before you die ( 13 October 2014 - November 9 2014) http://www.daz3d.com/forums/discussion/47518/
Entries only/Winners: http://www.daz3d.com/forums/discussion/47517/
RRRR Unleashed (3 December 2014 - 11 January 2015) http://www.daz3d.com/forums/discussion/49497/
Entries only/Winners: http://www.daz3d.com/forums/discussion/49496/
RRRR Not on the screen ( 29 January 2015 - 1 March 2015) http://www.daz3d.com/forums/discussion/52007/
Entries only: http://www.daz3d.com/forums/discussion/52006/
Voting & winners: http://www.daz3d.com/forums/discussion/53400/
RRRR Just Random (25 March 2015 - 3 May 2015) http://www.daz3d.com/forums/discussion/54371/
Entries only thread and Winners: http://www.daz3d.com/forums/discussion/54370/
RRRR Unlikely Occupations (20 Jun 2015 - 2 August 2015 ) http://www.daz3d.com/forums/discussion/56841/contest-rrrr-unlikely-occupations-with-prizes
Entries only thread:http://www.daz3d.com/forums/discussion/56835/
Winners thread:http://www.daz3d.com/forums/discussion/61494/rrrr-unlikely-occupations-winners-announced
RRRR Stupid is as stupid does (September 1 2015 - October 4 2015) http://www.daz3d.com/forums/discussion/61970/rrrr-stupid-is-as-stupid-does-render-contest-closed/
Entries thread: http://www.daz3d.com/forums/discussion/61969/rrrr-stupid-is-as-stupid-does-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/64971/rrrr-stupid-is-as-stupid-does-winners-announced
RRRR Murphy's Law (November 15 2015 - Sunday January 10 2016) http://www.daz3d.com/forums/discussion/66026/rrrr-murphy-s-law-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/66025/rrrr-murphy-s-law-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/70820/rrrr-murphy-winners-announced
RRRR The sequel ( February 11 2016 to Sunday March 20 2016) http://www.daz3d.com/forums/discussion/71563/rrrr-the-sequel-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/71562/rrrr-the-sequel-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/78321/rrrr-sequels-winners-announced
RRRR Story ( April 8 2016 to Sunday May 15 2016) http://www.daz3d.com/forums/discussion/78671/closed-rrrr-story-render-contest/p1
Entries Thread: http://www.daz3d.com/forums/discussion/78666/rrrr-story-contest-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/92406/rrrr-story-winners-announced
RRRR Twisted Lyrics (June 7 2016 to July 31 2016) http://www.daz3d.com/forums/discussion/92481/rrrr-twisted-lyrics-contest
Entries Thread: http://www.daz3d.com/forums/discussion/92471/rrrr-twisted-lyrics-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/108966/rrrr-twisted-lyrics-winners-announced
RRRR What does it mean (September 11 2016 to October 30 2016) http://www.daz3d.com/forums/discussion/112771/rrrr-what-does-it-mean-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/112766/rrrr-what-does-it-mean-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/127361/rrrr-what-does-it-mean-winners-announced
RRRR Alternative Holidays Render Contest (November 17 2016 to January 15 2017) http://www.daz3d.com/forums/discussion/127526/closed-rrrr-alternative-holidays-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/127521/rrrr-alternate-holidays-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/147326/rrrr-alternative-holidays-winners-announced
RRRR - It could be true - 5th anniversary contest (February 20 -2017 to Sunday April 2 2017): https://www.daz3d.com/forums/discussion/149891/rrrr-it-could-be-true-5th-anniversary-contest
Entries Thread: https://www.daz3d.com/forums/discussion/149886/rrrr-it-could-be-true-entries-only-thread
Winners Thread: https://www.daz3d.com/forums/discussion/167426/rrrr-it-could-be-true-winners-announced
RRRR A long time ago or Far far away Contest (June 22 2017 to Sunday August 20 2017): https://www.daz3d.com/forums/discussion/178416/closed-rrrr-a-long-time-ago-or-far-far-away-contest
Entries: https://www.daz3d.com/forums/discussion/178406/rrrr-a-long-time-ago-or-far-far-away-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/197491/rrrr-a-long-time-ago-or-far-far-away-content-winners
RRRR They're ba..ack ( September 16 2017 to Sunday October 29 2017) https://www.daz3d.com/forums/discussion/198056/rrrr-the-re-ba-ack-render-contest
Entries: https://www.daz3d.com/forums/discussion/198051/rrrr-they-re-baa-ack-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/214026/rrrr-they-re-ba-ack-winners-announced
RRRR - What can go wrong? (Monday November 27 2017 to Sunday January 14 2018) https://www.daz3d.com/forums/discussion/214591/rrrr-what-can-go-wrong-render-contest
Entries: https://www.daz3d.com/forums/discussion/214586/rrrr-what-can-go-wrong-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/232941/rrrr-what-can-go-wrong-winners-announced
RRRR Judged by the cover ( Saturday February 17 2018 to Sunday April 1st 2018) https://www.daz3d.com/forums/discussion/233496/closed-rrrr-judged-by-the-cover-render-contest
Entries: https://www.daz3d.com/forums/discussion/233491/rrrr-judged-by-the-cover-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/249461/rrrr-judged-by-the-cover-winners
RRRR - Error 404 Not Found! (Sunday May 6 2018 to Sunday July 22 2018) https://www.daz3d.com/forums/discussion/251026/rrrr-error-404-not-found-render-contest
Entries: https://www.daz3d.com/forums/discussion/251021/rrrr-error-404-not-found-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/277091/rrrr-404-not-found-winners
RRRR RRRR Muddled Maxims ( Sunday September 16, 2018 to Sunday November 18 ) https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest/
Entries: https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest
Winners: https://www.daz3d.com/forums/discussion/302491/rrrr-muddled-maxims-winners-announced
RRRR Build it and they will come ( Sunday October 20 2019 to Sunday December 15 2019 ) https://www.daz3d.com/forums/discussion/360136/rrrr-built-it-and-they-will-come-render-contest/
Entries: Entries only thread
RRRR - But you promised entries thread (this one was the last and we never got enough votes, thats why no winners were selected) (Wednesday December 25 2019 to Sunday February 16 2020 ) https://www.daz3d.com/forums/discussion/374106/rrrr-but-you-promised-render-contest-closed
RRRRR - Coming Late Excuses (another one where we tried a new voting system, that worked, but then wanted a shitload of money to actually get the vote results (as it was past the 10 day free trial time) (May 3 2021 to Sunday June 13 2021 : https://www.daz3d.com/forums/discussion/497476/rrrrr-coming-late-excuses-voting-thread-closed
RRRR - Back From the dead: (Monday April 3 2023 to Sunday May 28 2023) https://www.daz3d.com/forums/discussion/627661/closed-rrrr-back-from-the-dead-render-contest
Entries thread: https://www.daz3d.com/forums/discussion/627656/rrrr-back-from-the-dead-entries-only-thread/
Winners: https://www.daz3d.com/forums/discussion/642826/winners-rrrr-back-from-the-dead-contest
RRRR "Behind the scenes": (WednesDay September 14 2023 to Sunday October 29 2023) https://www.daz3d.com/forums/discussion/650126/rrrr-behind-the-scenes-render-contest-closed
Entries thread: https://www.daz3d.com/forums/discussion/650121/rrrr-behind-the-scenes-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/660276/rrrr-behind-the-scenes-winners-announced#latest
Pull #1
#466 FWSA Adaline HD for Victoria 7 (#22175)
#2998 Aniyah for Darcy 8 (#65283)
#1938 Building Site DS (#47215)
#4362 M3D Curious Expressions for Genesis 9 (#88353)
LB1: #170 My Camel Camelia HD (#21424)
LB2: #2444 Various Faces for Mabel 8 (#54091)
Timestamp: 2023-11-23 13:41:35 UTC
A Camel, Always a camel, but at least not the old DAZ Camel this time, such a typical LB!
I'm ready (I think)!
Pull #1:
187 CB Willa dForce Coat for Genesis 8 and 8.1 Females
1388 Everyday Poses and Expressions for Genesis 8 Female and Gia 8
477 Ekialys' Ny for Genesis 8 Females
152 Bounty Huntsman Outfit for Genesis 8 Male(s)
Random numbers generated Nov 23 2023 at 13:22:51 by psychicscience.org
Free educational resources for parapsychology and psychical research.
those textures asf., from DAZ freebies, for decade old objects that i don`t even own, keep popping up even more with 6 pulls.
4 times in a row. therefore this was my 5th pull. (rerolling entirely once an item is unusable)
1640 Drago Hair and Beard with dForce for Genesis 3 and Genesis 8 Male(s)
2261 Pirate Hook and Leg for Genesis 8 Male(s)
256 Muelsfell Modular Murky Swamplands
123 Iray Winter Light Kit
1356 Sci-Fi Battle Outfit for Genesis 8 Female(s)
1321 Morphing Python
Would it matter, if i was using the female version of the pirate hook and leg, instead of the male one?
Probably could make use of the male version on a female figure too. However, just for convenience?
Yes, useless stuff you need to remove, or they keep coming up, lol. and for the leg, you pulled male so male it is. I don't know how many times I've pulled 3 felame chars plus a male beard/hair so I needed to add a male to the scene as well.
Yeah, its just that my library constantly increases. Filter useless things once.. might be ok. Doing it everytime i pull new numbers... thats not going to happen.
Thanks for the rule clarification. Its not that one could not use these props without adding a male figure. i.e., I have used female clothes on a male character in my "pigs in space" render last month.
Therefore i am not too worried about it. It was a general question without even knowing where i would go to.
I think i got an idea about this one. Just need to try, find a rope-bridge freebie.
(in case there is none to be found in my library. i am not sure at all.)
Pull#1:
Sf Corridor SKU#61013
Rynne 8 SKU#64221
Fantasy Deer Fawn Kit With Dforce For Genesis 8.1 Females SKU#84792
Xi Alien Dinosaur For Daz Dragon 3 SKU#86558
(2023-11-24 15:56:21)
Pull #1
#145 Classic Canines Combo (#1892) This no longer has a product page, but it seems to have the same things as Millennium Dog Starter Pack, which I also have.
#614 Dragon Mortar (#6508)
#2559 GeneriCorp: Coffee Mug (#27326)
#3336 M.O.A.B Missile Silo (#83911)
Timestamp: 2023-11-24 19:59:41 UTC
Okay then... This should be fun. lol
Pull #1
Random Integer Generator
Here are your random numbers:
3473 The Strange Man Characters and Hair Set for Genesis 8 Male #73765
2941 Tudor Living 2 DS #48731
4850 Health Care Waiting Room #66341
5755 Ready for Bed Pajama Set for Genesis 8 Female(s) #46713
Timestamp: 2023-11-25 05:42:55 UTC
updated to add skus
Pull #01
Demon Soul.
Stinger.
All That Glitters PBR Merchant Resource.
Uniforms for Michael 6.
Shape Shift Bundle.
Pull #2
5336 Hood Huntress Collection for Genesis 3 Female(s)
658 Frozen Path
6527 Yamaki GTX-R DS
1880 Fulcia Mertail for Genesis 81 Female
Timestamp: 2023-11-26 02:09:00 UTC
@daventaki: You need to post the entry here too with the "pull list" so you anyone can "verify" the items ;-)
Rex Just Wanted to Play
Rex is a good dog. Sgt. Jones is his best friend. Rex wanted to play. The strange little object had a ball in it, kind of like Rex's Doggie Ball Toss machine. Now Sgt. Jones is lying down making "bad dog" sounds. Rex is sad. That went well...
Other products used: Radioactive Soldier Outfit for Genesis 8 Male(s), David for Genesis 8 Male, Ron's Steam and Smoke
Tag: Totte#01
Also used:
Improvised Benches (cinder block)
Casual Style For Genesis 3 Females + Summer Hip + Buzzed Hair + Fashion model poses
darcy 8 Hair + dForce Exes & Bows Outfit + Modern dance Poses
Mable 8 HD + dForce Hula Outfit + Capsences vanity Poses
Timothy HD for Genesis 2 Male + Desert Pathfinders
M3DCS Baxter + M3D Semi Bald hair + M3D Facial Hair + Summer Bikini + BW Beach Glasses Set for G9F + Combat Uniform Boots + Classic Rock Poses
The Deck Collection
Platinum HDRI Pack
Guitar and Props + Christmas Amp Freebee
Scripts and Tools used:
Code66 Toolbox Volume 2
RSSY 3Delight to Iray
Dress rehearsal
The first dress rehearsal of the outdoor performance of the Lawrence of Arabia Rock Opera went well, even though the stands and the rest of the stage still was just a construction site.
Pul #2
#1938 Blade Weapons (#47311)
#290 Arctic Fox LAMH (#21744)
#1471 British Street Furniture DS (#33021)
#3588 Brooke 8.1 (#80365)
LB1: #2061 Small Chair (#48743)
LB2: #5092 Spaceship Segments Vol3 (Rendo)
Edit:1
Lol - just realized that "LB1: #2061 Small Chair (#48743)" is my own Xmas freebee from 2017 ;-)
And that LAMH Artic Fox will be some challenges to render....
Edit:2
Will try to replace the hair of the artic fox as DS crashes everytime I save with it in the scene.....
Omg, those characters... This is great! I almost spit coffee all over the place! I'm sure their performance will be perfect... Nice use of your pulls!
Tag: bohemian3 #01
The D&D Club of West Park High
Lee: I told you you couldn't do it. It's a Level 4 spell.
Chance: You're only Level 1.
Dezzi: I gave it my best shot. Hey, where's Michael?
Chance: Gee, dunno. Sure hope nuttin' bad happened to him.
Lee: Aww - don't worry. They'll always be another Michael.
Pull:
DAZ Crow
Retro Apartment Props 2
West Park Lobby Iray Add-on
Lee 8 (Used Growing Up Morphs on him)
Axel Hair
Hey Bohemian3, this one is right up my sleeve, wonderful!
@Zethara "Rex Just Wanted to Play": Love this, Rex is such a confused dog now...
Tag: acb#01
New Record!
The new Transporter Chief beamed her Captain on board - already with the third attempt. That went well.
It's been a while,
Pull #1
- Underwear for M5
- Krayon Hair for Genesis 3 Female(s)
- Camouflage for Basil
- Axes of Power
Ideas: None... yet.
(Who's Basil ?)
Pull #1
- Underwear for M5
- Axes of Power
Ideas: None... yet - although I have an image forming in my head of Basil wearing underpants over his camouflage, with brightly coloured crayons on his head (confusion tactics I think), but still getting spotted by axe-wielding guards.
Anyway, who's Basil ?
Tag: bohemian3 #02
OMD !
Famed internet influencer Emma Legend, to prove just how influential she is (even in hell) summons a Demon live on her YouTube Channel. The World Wide Web literally becomes an intricate system of spider webs, and a worm is taking over all digital devices, changing all instances of OMG to OMD.
On a brighter note, she did get 4,711,480 likes.
Tag; Totte#02
Also Used:
Irandiance LightProbes
Ready Room (Table)
Space Jump Suit For Genesis 8 Females
HS CF Hair
Gengis Khan 9 HD + Gengis Hair + Recon Outfit + VDB Explosions
Kola 8.1 + Flight Suit + Iron Wasp (Dagger)
Tools Used:
Code66 Toolbox Vol 2
Code66 Toolbox Vol 4
Legacy Set Converter
Advanced Material Converter
London West End theatre sets up famous Sci-Fi movie
All the critics were sure that the West End version of a famous Sci-Fi movie would fall flat, but the first show got decent reviews so it all went well in the end.
Gopherus #01
Demon Soul.
Stinger.
Shape Shift Bundle.
Oh! Mickey! You’re So Fine
You’re so fine, you blow my mind. Hey Mickey! Hey Mickey! Mickey the Flygirl took her Kat and saucer and went cruising for men. She thought that if she buzzed the Eiffel Tower she could pick up on a handsome gendarme. Unfortunately for her the gendarme turned out to be a cat person. Next time she will buzz the airport. More Flyboys there.
Daventaki #01. He must have known how long the wait times were. Might as well be comfortable. Good one!
Totte #01. Excellent! Lawrence, you rock me! But I want to know for sure!
#02. Who could ever doubt that a sci fi theatrical could not be received well? Well done!
Zethara #01. ROFL! Who wouldn’t t want a game of catch…fetch!
Bohemain3 #01. Always go with the fireball! Very explosive!
#02. Good one! 3D internet! It s time has come!
Acb #01. Before she materializes him might be a good time to renegotiate her contract. Excellent!
Pull #02
Decisive Encounter Poses for Genesis 2.
Westbound Glamour.
Keeper of the Feathers Outfit Bundle for Genesis 8 and 8.1 Females.
Lorenzo Lorez.
CB Willa Accessories for Genesis 8 and 8.1 Females.
Pull#02:
Hd Violin And Poses For Genesis 3 And 8 SKU#49087
Baked Desserts SKU#59611
Modern Duckie For Genesis 8 Male SKU#82183
Ardamir Hair For Genesis 9 SKU#87403
(2023-11-29 08:28:28)
Thanks to Zethara, Gopherus for your comments.
acb#01 Teleporting wrong can be ugly in so many ways, well done!
bohemian3 #02 Next up is smell-internet, but 3D internet seems scary enough! Great idea!
Gopherus #01 Now you got that tune ear wormed! We have a Swedish cover of it too, great use of that draw!
Pull #3
3499 Lil Gnome (#77115)
3332 Scar 8 HD Add-On (#70877)
4133 dForce Paladin and Paragon HD Armor for Genesis 8 and 8.1 Male (#86538)
4957 MORE Textures & Styles for Gear Punk (Rendo)
LB1:200 School Bathroom DS (#21512)
LB2: 1768 Armory of Five Realms - Orcs (#43661)
OK, pulls are getting weirder and weirder..... Some V3 or V4 stuff (Gear Punk), yummy.
Tag: acb#02
Playing for Cake
Duckie had a strategy: While standing right next to the café / bakery, he would wait for someone with a cake in their hands and then play as terrible he could manage - until his target has droped the cake and ran away. That went pretty well.
edit: improved the background separation and the SCREAK.
LOL, I just ran across this thread. I wasn't expecting another RRRR so soon. I have to get my runtime caught up.
Great theme, Totte! The renders so far are hilarious.
