Autofit G8F crowns on G9 doesn't work
dracorndracorn Posts: 2,384
Does anybody else have trouble fitting G8F crowns to G9?  I have a slew of G8F crowns and circlets, but autofit doesn't engage for most of them when I use them for G9.  They appear above the head of G9, and I can't force fit it by right-clicking on the crown and choosing Fit To, because there is no Fit To option.  All morphs for dangling pieces appear to be disabled as well.
Is there a solution to this?
  • Matt_CastleMatt_Castle Posts: 3,312
    Most crowns/circlets are probably not rigged props, but static ones. It should be entirely possible to manually parent them to the head and then adjust their translation into position.
  • Andrew_CAndrew_C Posts: 144
    edited September 28
    In my experience rigid stuff like crowns doesnt autofit well, its usually better to scale and translate it as well as you can & then parent without autofitting.
    ED Matt_Castle already said that
    Post edited by Andrew_C on
  • Oso3DOso3D Posts: 15,141
    And the fun thing is, particularly if the item has some basic adjustments, you can put the crown on horses, dogs, dragons...
