BJ Rapid Pose - Faster posing better IK in/out of Daz Studio
2»
  • bluejauntebluejaunte Posts: 2,272
    Try it for yourself. It's the exact same software but you can't send the poses to Daz Studio. Your customized settings will carry over to the full version.
    BJ_RapidPose-Trial-0.4.0-2026-08-win64
  • crosswindcrosswind Posts: 10,312
    Thank you for having deployed the new features as well as fixed the bugs !
    Then do I have to uninstall the 0.3.2 first of all ? The installer tells me tiral version cannot be installed ~
    Yeah I'm preventing overwriting a full version with a trial. Did you wanna try the new features or something? You could uninstall the full version first, that should probably work.
    Yep, I uninstalled the full version and I'm playing with the trial one. So far so good, thanks !  BTW,
    1) The plugin doesn't mean to work in Public Build of DS 4/6, correct ?
    2) When sending a figure, better send the figure's current status as well as without the hidden nodes... (pls see the table in screenshot 1... )
    3) Better be able to send Props with which Genesis figure can interact when being posed.
    2560 x 1392 - 935K
  • RandWulfRandWulf Posts: 239
    edited August 4
    Hi.  Tried the beta test in Daz Studio 4.24, and got this:
    2550 x 3300 - 2M
    2550 x 3300 - 2M
    Post edited by RandWulf on
    edited August 4
    Props aren't even supported yet. How did you manage that? laugh Is that that table a figure or something? I just tried with some random furntiure and couldn't get it transfer over.
    It should work, but you need to change the folders in the installer to point to those instead. Or copy the BJ_RapidPose.dll and dsp_BJ_RapidPose.dll afterwards.
    Edit: ah yes, I see it in the outliner. The tables and chairs are set up like a figure. Cool. Proper props support is something that I'll be working on fairly soon. It's often needed for posing. Chairs to sit on, swords to hold etc.
    2) ...without the hidden nodes...
    Agreed, or transfer them but make them invisible by default with a proper visibility toggle. There's already a list of figures (later props) where each could have such a toggle.
    Post edited by bluejaunte on
    edited August 4
    That could be any number of hardware/driver related things. Would need to know your hardware specs and GPU driver version. Best to come to the Discord for that, I'll be happy to help you resolve it.
    https://discord.gg/XrZfNCRbn
    Edit: bit of a long shot but maybe something weird with the figure. I can't find anything called Toon Vixen. Is this just a Genesis 9 Toon or something?
    edited August 4
    Yes, I copied the plugins (0.3.2) to the same folders under DS 4 / DS 6 Public Build, then I got the error message when pressing Send... button, in both DS 4 and 6 Public Build. Pls check the attached ss.
    Yea, that'll be great ! Thanks for the consideration !
    2560 x 1392 - 325K
    Post edited by crosswind on
    Uninstall and install again, set the installer to the actual folders you want.
    This looks great. I would like to see funtional:
    a) When I place an object/prop in a hand, under the feet, and so forth in DAZ, it's so painstaking and awkward, and I frequently get it wrong, for 1st order of business is this gets it right, and it adjusts the entire pose/prop/character when the character is morphed into another character/prop as their size can be quite dfferent.
    b) Extending that a) to automagically adjust all the AniMate loop clips available in the DAZ Store to the modern characters.
    c) I would be nice to see a drag & drop utility - 1) Input a circa 2009 Animate Clip for M4/V4 2) Output that Animate Clip for the more modern Genisis 9/Geneis 8.1/Genesis 8/Genesis 3 character as morphed in the UI, eg Generic G9 Male morph/Generic G9 Female/One of Raw Art's more extreme morphs as proof of concept & robustness of purpose.
    Keep up the great work!
    a) Not sure I'm quite following but I am working on props support right now. b) and c) I don't feel this has anything to do with this. Sounds more like some scripts for very specific things.
    Forgot to post this here. In 0.5.0 I added translation-only pinning (Ctrl-Space). So the pinned hand is allowed to rotate but not move. Detail selection based on zoom levels, so single toes become selectable at a certain zoom level. Gizmo thickness and size are now configurable. Improved gizmo readability and an auto pin feet checkbox.
    0.6.0 just landed and brings support for static props, parented props/figures, changing pivots including sending them back to Daz Studio, a Scale tool, better scrollable hierachrical sidebar with visibility toggles.
    Oh yeah, and it comes in color smiley
  • Have you thought about adding a modern timeline? It's the other obvious deficiency in DAZ, the neglected, painful to use timeline.
    bluejaunte said:
    ...0.6.0 just landed and brings support for static props, parented props/figures, changing pivots including sending them back to Daz Studio, a Scale tool, better scrollable hierachrical sidebar with visibility toggles.
    Wow, that looks great ! I'm gonna give it a try ~
  • garrett_3dgarrett_3d Posts: 959
    What's wrong with timeline? It works fine for me, does what it needs to do.
    edited August 17
    @bluejaunte
    1st milestone of sending Props can well meet my need at current stage, thank you !
    Some issues and requests:
    0) Send changes, back to DS, Ctrl + Z.  Back to RP window, Send changes again, nothing happens ~ It's by design, correct ?  i.e. at least I have to make a pose change before the next Send changes ?  Not sure but maybe better use a way: Send Current Pose rather than send a delta ?
    1) I gave left arm a full pin, then dragged left index 3 (to appr. offset Y -0.32 ), it turned into Luffy's arm ~ (screenshot 1)  I'm not sure if there's any constraints
    2) Can options like Keep window on top memorized / saved in registry or somewhere else... like memorizing window state ?  so that I don't have to click the options again next time after RP window pops up...
    3) Better add an option: Minimize window after sending pose...
    4) Better add a Zero Pose button or action so that we don't have to repeat Undo or resend the figure ...
    5) Show which bone is currently selected in RP window...
    6) Is it possible to make Send Selected Items... as an Action so that I can place it on a toolbar rather than having to always open BJ RP pane (... to save space in a pane group ) ?  (screenshot 2)
    Thank you again !
    1917 x 1332 - 510K
    595 x 1293 - 62K
    crosswind said:
    @bluejaunte
    Thank you again !
    0) No I would call that a bug. If something is different than in Daz Studio it should be sent. Will fix.
    1) I'm unable to reproduce this. I'll keep trying (or send me some reproduction steps if you're doing anything special).
    2) Absolutely this should be saved like all the other options. Will fix.
    3) Hmmmm... I'll think about it. If so then I'll probably put both options into the config UI only. It's kind of the odd one out for the bottom checkboxes anyway, having nothing to do with posing.
    4) Is this related to 0)
    5) Selected bone is highlighted, right? Not sure what you mean here.
    6) Would have to look into it. But you don't have to give it that much space? Just resize it to be minimal. Or don't dock it, let it float around somewhere in a corner. Also an option.
    Possibly somewhere down the line. If it's just a timeline with keyframes we might as well just pose in app, send to keyframe 1 in Daz Studio, pose again, send to keyframe 30. That alone wouldn't warrant a timeline. If anything it would be part of a larger animation effort. At the moment that's a distant dream at most.
    edited August 17
    Pls check this short video: https://mega.nz/file/yXAHkQia#FCw07uIcicQImvYrQcW54zKb5IJD6VKthoTuZDR9TKg
    Yup, good idea !
    Not really ~ I mean a case: I give the figure a couple of drags but I want to start it over from its A-Pose, now I have to repeat undo for times. If there's a button that can Zero Pose !, it'll be much faster.
    Show what the highlighted Bone is, pls check the sample screen as attached.
    Right ~ not a must-to-have option, but just an idea from me ~~
    2019 x 1216 - 418K
    edited August 17
    Yup, good idea !
    Oh I see, I just have to drag like a madman :)
    Yeah this shouldn't happen. I'll look into it. On the other hand (ha), what is it you're trying to accomplish here? Obviously the finger cannot go to where you are dragging it. The IK is begging you to stop and at some point it just goes "oh whatever let's break an arm then".
    Also just an observation (this doesn't change the result though). You don't really need to pin all the way to the shoulder, just the forearm is enough.
    Zero pose in general, yes that would be a good feature to have. Probably in a right click context menu along with symmetry stuff later.
    A label showing the bone name is what I had at first actually. In the original video you can see it top center. It was mostly for debugging though, figured nobody needs to see this. I guess I was wrong! May I ask why do you want to see the bone name?
    Edit: spoke too soon. The same pin breakage does not happen on G9 actually. So this might be something specific to earier figures. Needs investigating. Thanks for the video!
    edited August 17
    Yea, at the first place I just pinned the forearm before dragging the finger. Actually I wanted to make a unique hand + finger poses for a dancing figure, then I accidentally gave it kinda yank then found the forearm bent lol.  Pls further check the issue anyway. Thanks !
    That'll be great !
    At the beginning, I just wanted to make sure if I selected the correct Bone before dragging... because when I do these in DS with IK, with different Bones pinned,  dragging different Bones gives me different result. For example: in DS, pin both feet of G8F firstly, dragging down Abdomen Upper and Abdomen Lower brings me different posing results. But when I did the test in RP window, it brought me pretty different results (with some balance of course which is nice I think), so I thought maybe I selected the wrong Bones... then I realized I didn't know what the selected Bone was.... In DS, the selected bone is shown in Scene pane and I'm very used to the way of getting it by a glimpse... while in RP window I was lost even though I know well about the figure's skeleton haha ~
    Sorry for having told you a long story... English is not my native language lol ~
    BJ Rapid Pose 0.6.1 - Weekly Build
    Various bug fixes and improvements. A fix for a reported bug on G8 or lower where yanking a finger with a pinned forearm resulted in the forearm deforming at some point.
    Improved as a result of further testing of the above: the figure is no longer vibrating/jerking when a descendant of a pinned ancestor is moved. The hand with the pinned forearm should no longer affect upper arm or above when moved at all.
    A pinned part now does not allow containing details to move on their own. Specifically a pinned hand does not allow metacarpals to move as they are visually contained in the pin.
    Fixed an issue where moving bones of the scaled down Dog 8 to hand size would mostly just move the whole dog. IK is now more scale independent.
    Some other stuff.
    edited September 12
    @bluejaunte
    Thanks for having updated the plugin as well as had the requested features added !!
    Some new issues and requests in here, pls see the screenshot.
    Besides, it'll be great to add a button / command that can instantly Reset the figure's / Prop's  Pose to the memorized Poses when doing Send Selected Items to RP window... instead of having to Undo for times ~~
    2561 x 1392 - 706K
    crosswind said:
    @bluejaunte
    Sounds great as a right click command on the sidebar. Although needs some thinking. What happens if the figure pose also moved the cigarette?
    bluejaunte said:
    crosswind said:
    @bluejaunte
    Sometimes it's just a minor change e.g. finetuning the rotations of a smart prop... or move a bathtube a bit.... but I just want to send back the pose of the Props. Then if I need to tweak the character's pose, I still can send the character's pose separately or finalize the pose in DS... something like that ~
    crosswind said:
    bluejaunte said:
    crosswind said:
    @bluejaunte
    Yeah but what if the hand moved that holds the cigarette? Or the finger that the cigarette is parented to? Should I also send the pose of the finger, the hand, or just the cigarette? Presumably the cigarette should move only in relation to what it's parented to? But if the finger also moved... things like that can get confusing quickly. Technically I need to handle all these cases.
    It's an interesting idea for sure, just that the headache and bug potential might be quite a high for such an edge case. Could make more sense to just move the head back to where you wanted it? Or send changes back more often so you end up with more granular undo steps?
    Haven't updated here in a while.
    0.7.0 brought geograft support. Drop to first surface with Shift+G (i.e. hand onto thigh or table). Various added config settings and improvments/ bug fixes.
    0.7.1 more fixes.
    0.7.2 more fixes.
    0.7.3 more fixes.
    0.8.0 better skinning and honoring correctives bring it close to what you see in Daz Studio. Also frame rate related settings. Vertical sync, max fps.
    0.8.1 overhauled navigation. panning now drags exactly as much as mouse cursor moves the object under cursor (Blender style). plugin now has a Daz Studio top menu with configurable shortcuts. Ctrl+Enter sends to app by default as per request. New optional setting to have frame F toggle between selected and whole figure/object. Shift+F always frames selection. Setting for zoom slow down factor relative to distance. Various fixes.
    0.9.0
    Just dropped and brings clothing/follower support with some pretty cool features.Unpoke your clothes.
    Change layering order.
    Expand/Average/Tighten per layer allows for these shorts to tighten what's underneath.
    Tightened socks over wide pants.
    Jacket normally over shirt can be turned into this.
    Send it all to Daz Studio.Morphs on all garments created on the fly.
  • Damn you're going in stong. Keep up the good work.
    bluejaunte said:
    crosswind said:
    bluejaunte said:
    crosswind said:
    @bluejaunte
    Right ~ that makes sense from technical perspective esp. for the cases with Smart Props.  So if "Send changes" always sends the pose change of everything in RP window, I'm also fine with it.  For any finetuning, I can simply do it in DS while I can just utilize the strong features of RP !
    Anyway, it was just a thought rather than a must-to-have function, we just let go ~ :)
    edited September 13
    Thanks for the idea / effort and nice work you've been making for the plugin ! The latest ver. of 0.9 seems very interesting, downloading ~~ !
