Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
    • Creative Tools
    • AI Scene Enhancer
    • Generative Credits
    • Enterprise Tools
    • Synthetic Training Data
    • Physical AI
Download Studio
Notifications
Loading...
    • Categories
    • Recent Discussions
{Diffeomorphic} HD Import Results in Blender Not Responding, More Often Than Not
evilded777evilded777 Posts: 2,559
July 31 in Blender Discussion
I don't know why. It's probably me. Maybe I'm doing something I shouldn't, or there are steps I am supposed to do that I am missing. But probably 7 times out of 10, Blender hangs somewhere during the process (Not Responding, never comes back).
Any tips or anything I can look at (I've read over the documentation available a couple times, but maybe I missed something)?
  • PadonePadone Posts: 4,405
    August 1 edited August 1
    To give advice we have to start somewhere, try to make a case as simple as possible which doesn't work for you, so we can look at it. Or you can also check if there's some evident difference between the cases that work and those that don't.
    Post edited by Padone on August 1
  • evilded777evilded777 Posts: 2,559
    I was thinking about this.
    What usually does not work: dForce hair. I don't know if I have ever gotten an import to complete when dForce hair (and to be clear, we're talking about stand based hair, not sheet hair with dForce applied).
    What did work: character with a full outfit of Luthbel armor, no dForce hair or geocrafts.
    /edit, of course as soon as I posted this I was able to import the character I most wanted in HD with all his body hair intact.
    Post edited by evilded777 on August 1
    August 1
    Well dForce and SBH hair can be extremely cumbersome depending on the tessellation in daz studio, this may lead to very long loading times. To render in iray you need a good tessellation, but to export to blender you better set the tessellation to zero, as blender only needs polylines anyway, for curves conversion.
    https://github.com/Diffeomorphic/import_daz/wiki/Hair_Tools
    August 2
    I shall give that a try. As always, thank you!
    August 2
    Here's a question on HD export... I lose all my HD details: things like muscle definition and veins provided by various morph packs.  Is that because these are "proprietary" DAZ HD morphs?
    August 2 edited August 2
    In blender HD is disabled in the viewport for perfomance reasons, it works in rendering. When exporting you have to set the daz viewport to the desired HD level as HD is baked from the viewport. Other than that it should work.
    p.s. Anyway you don't want HD to go further than 3 as it would be too heavy in blender. Plus a high HD level of course also affects the import export time.
    p.s. When exporting geografts with a HD figure be sure to enter the geometry editor to separate geografts from the figure. This is not necessary for base resolution.
    https://github.com/Diffeomorphic/import_daz/wiki/HD_Tools
    p.s. If the figure provides displacement maps or normal maps they're usually a fair and fast substitute to HD.
    Post edited by Padone on August 2
    August 3
    Ok, so those level 4 subd morphs are too resource intensive for Blender?
    Have I mentioned how much I appreciate you and the tools you've given us? I am enjoying my hobby like I have not done in a good long while... all these new things to learn and play with!
    August 4 edited August 4
    Level 4 is extreme, consider that each level of subdivision takes four times the geometry. The addon is a python script so it has inherent speed limitations. That means it doesn't fit well with huge scenes or characters. Keep this in mind when exporting.
    p.s. Exporting a level 4 is same as 4*4*4*4 = 256 figures at base resolution.
    Post edited by Padone on August 4
    August 6
    I may be asking the wrong question. Allow me to go back to the documentation.
    August 6
    Ok. This may be the right question, that I can not figure out the answer to.
    Certain "HD" morphs do not seem to transfer. Or at least, they don't seem to effect the mesh the way I expect them to once it is in Blender.
    For instance: Auto Muscle Enhancer HD For Genesis 8 Male(s), Vascularity HD for Genesis 8 Female and Male. I use these a lot. I can't figure out why they are not showing up when I transfer a character that uses them.
    August 7
    If they don't show in the daz viewport when you export then they are not exported. Blender only supports HD shapes, not HD morphs. That means the character shape can be HD, but the morphs are always at base reolution. This is a limitation with the multires modifier.
    However, HD morphs can be converted to animated displacement maps using the Xin HD addon, which works together with diffeomorphic.
    https://xin888.gumroad.com/l/daz_hd_morphs
    August 7
    Thank you! There's still, after decades at it, so much I don't understand.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
