Daz 6 problem
When the curser is on the viewport there is a weird green all over the screen.
  • dennisgray41dennisgray41 Posts: 976
    edited July 28
    It doesn't work. Boooo crying
    Post edited by dennisgray41 on
  • exastrisexastris Posts: 14
    part of the environment is selectable in the viewport, most likely the ground piece, and it's highlighting that when your cursor moves over it. if you go into the scene tab and figure out what piece it is, then click the symbol of a little cursor with a checkmark next to it, the checkmark will change to an x and that item will no longer be selectable in the viewport and won't highlight when your cursor moves over it.
  • barbultbarbult Posts: 27,631
    edited July 28
    A more generic and broader impact solution?:
    Open the Draw Settings pane. Select the Node Highlighting section in the General Settings. Change the Highlight Style to Bounding Box Only.
    656 x 414 - 35K
    Post edited by barbult on
  • Richard HaseltineRichard Haseltine Posts: 111,859
    Threads merged. As you have beena sked before, please don't post the same topic in multiple places. Also, Please put your question in the post body and the title - Daz 3D Forums
    Thanks. That did it.
    No One answered the otjher post.
    No bumping, either.
