Adding to Cart…
The things that I'd like to add to that are:
UV set swapping. That way you can still use the old textures, but you could also switch to a new UV set that's laid out more like the Genesis figures. That would make creating textures in general and making higher resolution textures easier. I know how to UV map, but I've never done anything as complex as the generation 3 figure, though.
Geograft. I understand the basic concept of how it works, but don't know how to actually do it. Plus, I don't know if there's something about how the Generation 3 figures were created that might prevent them from working.
Like I previously stated, I was thinking about also adding HD Morphs, but there are a couple issues with that, so I don't know that it's necessary. I know this technology is proprietary and only PAs have access to it, so that's not something that the general public could do. Also, it is meant to be used with Sub-D on a lower-poly mesh.
One of the things that has confused me is the fact that over the years, on certain technologies when they came out, they would state, "this technology only works on single mesh figures". But what does single mesh even mean? Because if you take it literally, even Genesis isn't a single mesh figure, because the eyeballs, eyelashes, and teeth are all separate meshes, they're not actually connected to the main mesh of the figure.
UV swapping is something I had forgotten about. Which is silly, because I have done it [once] on a model of a fountain pen, and I've never done anything so complex either. Coping with the different areas from each generation for the material zones means it might be best to use a fit suit and hide the Gen3 character.
Geografting is something I have done twice, and vaguely understand. What would they be used for? That's the bit I'm not sure about. When TriAxed or General weight mapped the character is not a Generation 3 character, it just uses a Gen3 mesh, so there shouldn't be anything to prevent it working.
HD morphs are something we couldn't do.
As far as I know, Gen3 is welded on loading into DS into a single mesh. Don't think it's something we need to worry about.
Regards,
Richard.
Felicia got a new variation.
Sweet !
Thanks!
Apparently she wasn't finished though, and I posted her in haste. Because I've come up with a bunch of refinements I could do and ideas I could try out. So we'll see how that goes.
When DS4.0 pro became free I jumped in feet first, as I wanted to learn how all of the tools worked as well as what was going on internally, I practically dismantled Genesis figuring out how it all worked.
I realised I was going to have to rig my own figure to really learn how that side of things worked, so I used Aiko 3 as my guinea pig and like everyone else I used "convert to WM", back then I didn't know any better, took me over a month to realise what a mess I had, so I kept the mesh, the skeleton and the UVs and deleted everything else.
I then spent the rest of 4.0 and most of 4.5 rebuilding her as a full on Tri-Ax figure, that means "painting" custom weight maps, rebuilding her morphs and adding regions so they appear in the Shaping tab correctly, rebuilt most of her JCMs (Tri-Ax meant I didn't need some of them), added autofit clones for the rest of the Gen3s.
The attached image is from one of many backups i made, that is from early 2013, I was about 80%-85% happy with the WMs at this stage, had added the regions and started rebuilding her morphs.
I "mothballed" the project before DS4.6 for a few reasons.
I'd learned everything I could from doing it.
I'd never be able to distribute her.
I realised I now had ALL of her content to rebuild.
So while it can be done it's not advisable.
Rather Very reminiscent of a WW2 pinup. It's amazing how you do it.
Regards,
Richard
Interesting. I have weightmapped some of the simple poser figures using convert to weightmap and then finetuned them. I would be interested in knowing more about your process but don't want to take the thread off tangent. Is it ok to dm you?
Great work with the Aiko renders Ethin it's nice to see some people are still using the older figures.
Thanks!
Translation of Josh Crockett's Winter Fae from Genesis 8 Female to Aiko 3.
I guess you would call this an anatomy study. Hiro 3 is the real target for this but since I have a whole lot more experience working with Aiko (not to mention I just wanted to see if I could actually do it with A3) I used her. Now I can just copy-paste it over to Hiro and adjust it to fit him better.
wow
Thanks!
Yeah, she's not really my idea of appealing, but she's certainly impressive looking.
yup I like healthy fit ,thick or thin but not so much muscle bound .......
A question for the Aiko 3 experts. Was there ever a set of digitigrade morphs released for Aiko 3 OTHER than the JENelson Kasa set? I've been looking for a set for years and never found any, and the Kasa set has long disappeared from the net.
I don't remember any others.
I'd also be interested in some anthro foot and hand options for A3/H3. Sadly Kasa didn't work in DAZ Studio.
I've toyed with the idea of making some myself, but most of what's involved is still beyond my current technical abilities.
Here is another video!
very nice ,me likey !!
Thanks!
Them
2026
Me
2022
2025
Lol. Just saying.
A glow up of an OC I originally created in 2014.
