BJ Camera Manager (Commercial)
1235»
  • bluejauntebluejaunte Posts: 2,237
    Great, I've let them know about wrong folder. Surely that has to be solved somehow as well.
  • jjoynerjjoyner Posts: 839
    After installing the DS4 update for Camera Manager plugin that appeared a week ago that @barbult warned everyone about on July 10, I was able to manually recover the plugin because I did not  overwrite the previous plugin in my product archive.  Two days ago, there was another update in DIM that corrected the update from removing it from DS4.  Today, there was another plugin update in DIM and, thinking that it fixed all previous errors, I installed it via DIM.  Today’s update for DS4 deleted Camera Manager from DS4!  Again, I manually recovered the plugin using the download on July 14.
    935 x 618 - 147K
    738 x 267 - 60K
    Hmmm that sounds a little weird though. Have you tried maybe uninstalling/reinstalling the package? Maybe it got confused because it found the DLL that it thought wasn't there... or... something? Who knows anymore.
    Downloaded the DS4 zip from my account and it's in there at least. Could still be something wrong with the DIM package of course.
    edited July 16
    The install that I posted about earlier was on my Windows 10 laptop. Just a few minutes ago, I tried the two new BJ plugin updates on my Windows 11 desktop.  If first checked that the Camera Manager and Selection History plugins were available in DS4; they were.  I then used DIM to uninstall Camera Manager.  I then used DIM to install the updates for Camera Manage and Selection History.  The install for Selection History was OK; the plugin is still available in DS4.  The update for Camera Manager, however, deleted the Camera Manager plugin from DS4.
    Update: I think I solved the problem.  The update for Camera Manager did not install its plugin folder in the correct location.  Selection History installed its plugin folder at C:\Program Files\DAZ 3D\DAZStudio4\docs\Plugins on my computer.  Camera Manager, though, installed its plugin folder at C:\Program Files\plugins.  When I manually moved the Camera Manager’s plugin folder to C:\Program Files\DAZ 3D\DAZStudio4\docs\Plugins, the Camera Manager plugin appeared in Installed Plugins and in Windows/Panes (Tabs).
    940 x 572 - 136K
    617 x 942 - 116K
    617 x 402 - 51K
    Post edited by jjoyner on
    edited July 17
    Not docs I hope, probably typo right. Manual would be there.
    I will pass on the other info. Apologies again for the mess...
    Edit: oh but rereading that you mention the docs folder again and the plugin works inside of that? Huh... why would plugins be in the docs folder crying
    Post edited by bluejaunte on
  • jmucchiellojmucchiello Posts: 1,912
    I have these plugins. And only some of them seem to have installed although DIM says they are all installed. This is exported from DIM.
    Product Name Package Date Visible in DS DLL
    BJ Layers Plugin DS6 2026-07-16T09:42:23Z  yes dsp_BJ_Layers.dll
    BJ Selection History Plugin DS6 2026-07-16T09:57:44Z no ??
    BJ Shelf Plugin DS6 2026-07-16T10:00:54Z yes dsp_BJ_Shelf.dll
    BJ Camera Manager Plugin DS6 2026-07-16T09:37:47Z no ??
    BJ Selection History Plugin DS4 2026-07-14T12:52:00Z yes BJ_SelectionHistory.dll
    BJ Layers Plugin DS4 2026-07-14T12:46:04Z yes BJ_Layers.dll
    BJ Camera Manager Plugin DS4 2026-07-16T09:37:16Z no ??
    BJ Shelf Plugin 2025-12-01T08:46:34Z yes BJ_Shelf.dll
    And there's a dsp_BJ_PoseZone.DLL in my DS6 plugins directory.
    When I installed them, neither version of DS was running.
  • crosswindcrosswind Posts: 10,119
    What a mess ~ Some package file name used to be with -01_,  then changed to -02_, esp. for DS 6... is that the cause ? Have you deleted the old (wrong) packages ?
    I deleted nothing. I had DIM do it all. I don't have any -01_ or -02_ files. I didn't look in packages.... Only some slight weirdness. The BJShelf for DS4 isn't named consistently and it hasn't been updated:
    ​07/17/2026  12:20 AM               477 IM00092616-01_BJCameraManagerPluginDS4.dsx
    07/17/2026  12:20 AM           937,593 IM00092616-01_BJCameraManagerPluginDS4.zip
    07/17/2026  12:23 AM               477 IM00092616-02_BJCameraManagerPluginDS6.dsx
    07/17/2026  12:23 AM           983,356 IM00092616-02_BJCameraManagerPluginDS6.zip
    07/17/2026  12:20 AM               466 IM00110779-01_BJLayersPluginDS4.dsx
    07/17/2026  12:20 AM           962,708 IM00110779-01_BJLayersPluginDS4.zip
    07/17/2026  12:23 AM               466 IM00110779-02_BJLayersPluginDS6.dsx
    07/17/2026  12:23 AM           993,829 IM00110779-02_BJLayersPluginDS6.zip
    07/17/2026  12:20 AM               477 IM00111675-01_BJSelectionHistoryPluginDS4.dsx
    07/17/2026  12:20 AM           327,075 IM00111675-01_BJSelectionHistoryPluginDS4.zip
    07/17/2026  12:23 AM               477 IM00111675-02_BJSelectionHistoryPluginDS6.dsx
    07/17/2026  12:23 AM           631,122 IM00111675-02_BJSelectionHistoryPluginDS6.zip
    12/02/2025  12:32 AM               461 IM00112555-01_BJShelfPlugin.dsx
    12/02/2025  12:32 AM         2,092,640 IM00112555-01_BJShelfPlugin.zip
    07/17/2026  12:23 AM               465 IM00112555-02_BJShelfPluginDS6.dsx
    07/17/2026  12:23 AM         2,164,133 IM00112555-02_BJShelfPluginDS6.zip
    I mean the "-01_" in the file name of IM00092616-01_BJCameraManagerPluginDS4 and "-02_" in the file name of IM00092616-02_BJCameraManagerPluginDS6 ... but the package name of DS6 version used to be IM00092616-01_BJCameraManagerPlugin in which there was DS6 plugin enclosed but with a wrong installation path defined for DS4 rather than DS6...
    Now it seems the issue on your side didn't come from that error ~~ I have no idea by now.
    Re: 01/02: Oh. Didn't even see those. It seems I don't have 01s and 02s for the same plugin, which is what I think you were implying.
    I tried uninstall, reinstall on the camera. Not fixed.
  • LeanaLeana Posts: 13,473
    Ghosty12 said:
    All fixed now, two separate files showing in DiM one for DS4 and one for DS6, and both working great thank you for the update. laugh The only thing because DiM does not see DS6 properly, when it comes to installing plugins, unless I have DiM setup wrong. You will have to move the DS6 version of the plugin dsp_BJ_CameraManager.dll file from the DS4 plugin folder to the DS6 plugin folder.
    DIM should use the paths configured for DS6 and DS6 beta in the "Applications" tab of DIM settings for install (at least if the manifest included in the DS6 package has been setup properly), so maybe check the value you have for those.
    As noted in an earlier post, I solved the problem on my computer by moving the BJ_CameraManager.dll file.  Since Camera Manager became available after I moved the file, that indicated to me that the problem was not in the DLL file but in where it was installed by DIM.
    A new update for Camera Manager appeared in DIM today.  I manually downloaded the new update and compared the Manifest files from yesterday’s update and today’s update.  Both Manifest files state that BJ_CameraManager.dll is to be installed in the same wrong location on my computer - C:\Program Files\plugins - and not at C:\Program Files\DAZ 3D\DAZStudio4\docs\Plugins.
    1852 x 177 - 130K
    1899 x 192 - 130K
    I installed DS6 yesterday and decided to give the DS6 updates for Camera Manager and Selection History a try.  I installed them both with DIM and, just like the DS4 updates, Selection History installed fine and was available in DS6 but Camera Manager was not.  I tracked down where the Camera Manager had installed its files and found the same issue that the DS4 updates had.  Camera Manager had installed dsp_BJ_CameraManager.dll at C:\Program Files\plugins.  When I manually moved the file to C:\Program Files\DAZ 3D\DAZStudio6\plugins, the Camera Manager plugin appeared in Installed Plugins and in Windows/Panes (Tabs) in DS6.
    Should be fixed now from what I hear. Fingers crossed.
    For me personally, I have fixed the issues on my computers.  I hope others have not had the same issues.  Thanks much for the dedication that you give to supporting users of your products.
    Will there be another release of Camera Manager after July 17? I got both DS4 and DS6 updates for that last night and it still put the camera DLLs in the wrong place. At this moment, BJ Shelf for DS4 and both BJ Selection Helpers are waiting to be downloaded in DIM.
    No idea, I'll ask.
  • barbultbarbult Posts: 27,343
    Yes, the DIM packages are stil bad. DIM puts the DS4 dll in C:\Program Files\plugins and the docs in C:\Program Files\docs\Plugins\BJ Camera Manager instead of the proper DazStudio4 subdirectories. The DS6 dll doesn't seem to get installed any place.
  • airjoeairjoe Posts: 26
    I got rid of my DS6 beta, deleted any leftovers, then reinstalled all my BJ plugins. After that I copied the DLL files meant for DS6 from the DS4 plugin directory to that of DS6. That was a couple of days ago, so it might be fixed by now. It all works fine now for me.
    Cool. Yeah I think all the plugins should be good now.
