• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeo: Problems with instances
DrGonzo62DrGonzo62 Posts: 412
July 5 in Blender Discussion
Hi,
I'm trying to import the DAZ Road to nowhere asset into Blender, but I'm getting artifacts after the import.
This assets uses instances and I've noticed problems with importing such assets before, like some of the instances don't line up correctly.
The other asset I'd noticed that with is Along the Prom. Some sections of the street don't line up and I had to move them into the right spots.
Is there a way to fix this? With Road to nowhere, I can't figure out how to get rid of the lighter rectangles.
Thanks!
  • PadonePadone Posts: 4,255
    July 5 edited July 5
    That is a viewport preview, that may have artifacts of various kinds due to the limited precision, especially for very large scenes as outdoor environments. Does that happen in rendering ?
    edit. Other than that, scenes are mainly intended to be imported as unmorphed, not dbz, unless there's specific reasons. May be that's your issue with instances.
    edit. Also I see the scene has presets for iray and 3delight, of course make sure to get the iray presets.
    Post edited by Padone on July 5
  • DrGonzo62DrGonzo62 Posts: 412
    Hi Padone,
    Yes, unfortunately so.
    Second image was rendered in DS.
    Third one is Along the prom before I repositioned some of the embankment segments.
    929 x 827 - 171K
    1356 x 929 - 441K
    1906 x 950 - 400K
    Post edited by DrGonzo62 on July 5
    July 5
    Nope, I don't get those white lines in the street, not in rendering nor in the viewport. Test scene provided. You can try my scene or share yours.
    my steps:
    1. import the test scene and render
    The issue with promenade is because it uses morphs, so can't work with unmorphed. For scene using morphs you can import as dbz, then it works fine.
    duf
    duf
    road.duf
    1M
    889 x 430 - 116K
    853 x 494 - 161K
    Wow! I'm still getting those squares using your test scene. Weird!
    I'll have to investigate this further. Thanks for checking!
    And yes, now that you mentioned Along The Prom - I do remember realizing that those segments where placed using morphs.
    I'll try dbz next time I run into something like that.
    1376 x 999 - 427K
    July 5
    Hi Padone,
    Does it look like the Road material from my import is missing the default UVs?
    I can't tell.
    1915 x 1018 - 193K
    July 6
    Yes it looks so, it is imported fine on my side. But this could be because we have different daz libraries. I use the standard "my library" for scenes to be portable. If you made custom libraries then make sure they're all mapped on the blender side. Look at the log for errors or missing files.
    window > tggle system console
    I do have a couple "remove default uvs" in mine, but then the scene loads fine.
    838 x 426 - 78K
    863 x 173 - 46K
    July 6
    update. Asked Thomas about "remove uv".
    https://github.com/Diffeomorphic/import_daz/issues/53
    July 6
    update. solution.
    Found the culprit. Apparently has nothing to do with the missing uv set, at least on my side as I don't have any. It happens to me when I use 8K textures, that I usually don't as I set simplify for 2K. The culprit is the bump distance in the "road-01" material that is different from "road-02" and "road-03". At 2K texture the bump is smoothed so it doesn't appear much, at 8K textures with full bump the white bands appear.
    fix. set the "road-01" bump same as "road-02" and "road-03".
    why is that. Unfortunately the bump in iray depends on the pixel density. The addon tries to compute that at best, and usually does a good job especially for figures, but in this case it fails. So we need to adjust the bump by hand.
    938 x 290 - 58K
    983 x 293 - 61K
    258 x 328 - 21K
    July 6 edited July 6
    Wow - that got complicated quickly!
    Thanks for looking into this, Padone.
    I'll try your suggestions.
    Update:
    I matched the Bump Distance for the 3 road materials as you suggested and that did fix the artifacts.
    And not merging the materials during import seems to have fixed the missing Default UVs issue.
    Do you usually leave that setting unchecked?
    Thank you very much Padone!
    Post edited by DrGonzo62 on July 6
    July 6
    Nope, I usually merge materials, the uv map doesn't go away here. I'm using the 5.2 dev version.
    July 6
    Got it - thanks!
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
Create An Account
