Show Us Your Bryce Renders Part 14
1…3738404243…49
  • HansmarHansmar Posts: 3,228
    Amazing city renders, Horo.
    Very nice terraced terrain, mermaid010.
  • HoroHoro Posts: 11,722
    mermaid - thank you. Very nicely done and presented asbestos-mountains under the clouds. The eagle is a nice addition.
    Hansmar - thank you.
  • mermaid010mermaid010 Posts: 6,290
    Thanks Hansmar and Horo
    edited June 28
    I made this scene before I went away, but forgot to post it. I contains a temple of sorts (from DAZ),  a girl in schooluniform and dragon (also from DAZ). Plants are partly part of the temple set and partly from the ecosystem by Horo and David B. The sky is also from Horo/David, from Fantastic skies, probably modified by me. I tend to forget what I used and how. The schoolgirl tells the dragon: "Down" and who would not obey her?
    1370 x 651 - 1M
    Post edited by Hansmar on
    edited June 28
    By the way, did you notice that the pictures do no longer scale with the size of your window, as they used to, when setting the width at 800? Anybody know what changed? Or is it something in my settings?
    Under the image it is now written: This image has been resized to fit in the page. Click to enlarge. I don't think the forums did that in the past, did they?
    edited June 28
    Hansmar - this is a very nicely done scene of the schoolgirls world. I have not notced that the uploaded image scale changed. I also set width always to 800 so the height adjustes correctly. Now let me try ...
    The back terrain is from Landscapes under Fantastic Skies, the near one as well as the waterfall and the foam are self made terrains. The terrains have a material from High Resolution Terrains 1, all waters have self made materials. The plants are BTOs (Bryce Tree Object), the material for the leaves were self made. Ambient light by the WhiteSphere HDRI and the key light by the sun. A pond in front of a cliff with a waterfall.
    Waterfall in Pond
    1200 x 800 - 372K
    Post edited by Horo on
  • ed3Ded3D Posts: 2,653
    Horo said:
    Thank you ed3D and mermaid.
    heart     you''re  more  than   welcome    /
    edited June 30
    Very nicely done image with the school girl  and the dragon Hansmar.
    From what I recall it has always been this way.
    Horo outstanding word, beautifully done.
    Post edited by mermaid010 on
    edited June 30
    Sorry double post
    edited June 30
    The terrain was cut-out from the complete LDEM_0128 of the Lunar Reconnaissance Orbiter, Lunar Orbiter Laser Altimeter (LRO-LOLA) and shows the canyon of the Vallis Alpes with parts of the Montes Alpes as viewed from the Mare Frigoris in south-western direction, its height is here superelevated. The material is from High Resolution Terrains 3, sky and ambient light by the SunSet HDRI from "HDRI Enhanced Skies and the key light by the sun. A surreal depicted real moonscape.
    Peaks and Craters
    1200 x 800 - 283K
    Horo, mermaid010, thank you. By the way, it was supposed to be school girls word, because her word makes the dragon bow. laugh
    Very good waterfall render, Horo! The other terrain is very outworldly.
    If you check your render and make the size of the window of your browser smaller (less wide), you will see that the height/width ratio of the picture changes. It did not use to do that, now with the browser I use (DuckDuckGo). And indeed, it used to correct the height with the width if you set the width at 800, as I also use to do.
    edited June 30
    Two abstracts from the same scene. I used four cylinders, with rotation, with a Bubble texture and inside a fully reflective cube (with the camera inside as well, of course). A simple backgrop is used, with a light red fill light in the cube and a sphere light inside the cylinders. Also two low negative spotlights at the side pointing towards the center.
    The first render is the full scene, while the second one is a close up more towards a corner. I call the scene 'sunburst'.
    651 x 651 - 314K
    651 x 651 - 222K
    Hansmar - thank you. Two very nicely done abstracts, I find sunburst quite a fitting name for it.
  • NGartplayNGartplay Posts: 3,420
    Horo, agree that the mountains look Mordor.  Beautiful lake and water.  Cool city..greeble?
    Lovely landscape, mermaid.
    Hansmar, your last two abstracts are fascinating.  They look like explosions in an ancient Chinese underground city.
    Thank you NGartplay.
    Awesome result with the surreal moonspace.Horo.
    Hansmar - Lovely sunburst abstracts
    NGartplay thanks
    edited July 2
    Three self made terrains with an adjusted material from Gritstone Hills and Terrain Stacking. Sky and ambient light by an HDRI from Terrain Stacking and the key light by the sun. The hot-air balloon is available at Daz 3D.
    Over Hillscape
    1200 x 800 - 153K
    very  nice
    Thank you ed3D.
    edited July 4
    The terrain was self made and given a material from High Resolution Terrains 3. The clouds are by the CloudSphere6 and the ambient light by the belonging SkySC6 HDRI from the Sky Toolbox. The key light by the sun. A steep valley with a floor covered by plants.
    Steep Green Vale
    1200 x 800 - 272K
    edited July 4
    Two outstanding landscapes, Horo; I like the addition of the hot-air balloon in the 1st and the valley floor with plants in the second.
    The terrain is from Hi Res 2, materials for the terrain and water from Gritstones Hills, the sky is a modified preset sky the tugboat is a freebie.
    900 x 600 - 437K
    Horo said:
    Thank you ed3D.
    you''re  welcome   +     Beautiful  Sky    heart
    mermaid - thank you. Beautiful moody landscape scene with the water and the ship.
    edited July 5
    Thanks Horo
  • Electro-ElvisElectro-Elvis Posts: 951
    edited July 5
    Horo: Outstanding landscapes (as usual wink)
    Hansmar: When looking at your abstract paintings, you can almost feel the heat
    mermaid010: Nice and moody scene. IMHO the tug boat in comparison with the mountains may be a tad too big?
    I am not that happy with the thunderbolt in my image. But I couldn't find a better one. Does someone here perhaps has a nice image of a thunderbolt with a transparent image, who would spare with me?
    A Storm Is Rising
    1080 x 900 - 262K
    Post edited by Electro-Elvis on
    Electro-Elvis - thank you. Nicely done thunderstorm with the flash from the clouds down.
    Attached FlashBolts.zip contains a Bryce Object file containing 5 flashes I once made from the two photographs I made from home on the 27. August 2016 at around 22:00. Unzip FlashBolt.zip and copy it to Bryce\Presets\Objects\your subfolder\. It contains 5 2D-Faces with a picture material in Ch-A and in Ch-B a colour that can be changed in the DTE.
    zip
    zip
    FlashBolts.zip
    97K
    800 x 220 - 13K
    Thanx  Horo  +   Nice  image  Electro-Elvis
    edited July 6
    Thanks Electro-Elvis for your comment. I still have problem with scaling. Lovely landscape, very nicely done, the thunderbolt is nice,
    Horo thanks for the file.
    Horo, ed3D, mermaid010: Thank you. and Horo for the thunderbolts pictures. very kind. I'll give them a try.
    edited July 6
    You are welcome ed3D, mermaid and Electro-Elvis. Below is  part of a render I made over 7 years ago using two of those flashes.
    Flashes
    800 x 640 - 121K
