Deregistered Plugins
dijidave_a64850a362
It seems that a selection of Plugins have deregistered themselves in my Daz Premier, they are,
AutoSave
dForce Manager
Geometry Sculptor
Pose Converter
Render Que
& Shape Transfer
I also seem to have lost Serial numbers from my account page.
Not feeling so Premier at the moment!!!
did you pay your subscription fee?
I'm only partly joking aboutt that, but make sure your payments are current first.
If that's ok, then it's possibly a server side error, and you may need to wait and see if it clears. if not, you'll probably need to submit a support ticket Here.
My subscription isn't due untill October, thanks for the link
Did you log in from inside DS recently? You need to do so from time to time so that DS can check that your subscription is still current and keep the plugins activated.
Sometimes you have to restart the program to make it realize you're supposed to have the Premier plugins. Mine were greyed out the other day for absolutely no reason. Restarting the program fixed it.
Restarted Daz, Logged in, Restarted PC, & submitted ticket. It would seem I must be patient & make do with Original Daz
Did you get any errors with it?
No errors, just dissabled plugins & no ''Premier'' on splash screen.
Restarted a few times, no difference
(Post edited by mod to fix quote)
Next time it happens, please download the log into a txt file and post it here so we can see why it's happening.
As per my experience of validating Premier membership:
1) Login to Daz Connect from Smart Content pane with Update Metadata unchecked. You may be asked to restart DS but DO NOT do that immediately. Wait for a while, appr. 1 ~ 2 minutes till you see Premier logo via DS > Help > About Daz Studio...(screenshot 1)
2) Now Exit and relaunch DS. You should be able to see Premier on the splash screen. Then check DS > About Installed Plugins... see if Premier plugins are shown as green plugs. (screenshot 2)
3) If you cannot find them via DS menu items. Save your DS Layout by pressing F4 firstly, then: DS > Window > Workspace > Update and Merge Menus.
Edit: You also can check DS log to see if you can find a string : Roles: Premier If you cannot find it, it means your Premier validation is failed ~~
Thanx Crosswind, starting the CMS made me realize that while away on holiday I'd changed my password& after inserting the new password & restarting Daz, Premier & all it's plugins are restored
Edited by mod to fix quote)
I didn't, no. The little plugs were just greyed out. The date in the dialog box said it was good until July something. IDK what the deal was.
Changing activation (by adding a serial, or logging in if your mPremier activation had times out, or by unchecking in Help>About Installed Plug-ins) always requires a reset. I think plug-ins can deactivate if their trial/activation period runs out but I am pretty sure that activating always requires a restart.
