Deregistered Plugins
It seems that a selection of Plugins have deregistered themselves in my Daz Premier, they are,
   AutoSave
   dForce Manager
   Geometry Sculptor
    Pose Converter
    Render Que
 & Shape Transfer
I also seem to have lost Serial numbers from my account page.
 Not feeling so Premier at the moment!!!
frown
  • did you pay your subscription fee?
    I'm only partly joking aboutt that, but make sure your payments are current first.
    If that's ok, then it's possibly a server side error, and you may need to wait and see if it clears. if not, you'll probably need to submit a support ticket Here.
  • edited June 25
    My subscription isn't due untill October, thanks for the link   cool
  • LeanaLeana Posts: 13,765
    Did you log in from inside DS recently? You need to do so from time to time so that DS can check that your subscription is still current and keep the plugins activated.
  • butterflyfishbutterflyfish Posts: 1,859
    Sometimes you have to restart the program to make it realize you're supposed to have the Premier plugins. Mine were greyed out the other day for absolutely no reason. Restarting the program fixed it.
  • edited June 28
    Restarted Daz, Logged in, Restarted PC, & submitted ticket. It would seem I must be patient & make do with Original Daz
    Post edited by dijidave_a64850a362 on
  • frank0314frank0314 Posts: 15,120
    Did you get any errors with it?
  • edited June 28
    No errors, just dissabled plugins & no ''Premier'' on splash screen.
    Restarted a few times, no difference
    (Post edited by mod to fix quote)
    Post edited by frank0314 on
    Next time it happens, please download the log into a txt file and post it here so we can see why it's happening.
  • crosswindcrosswind Posts: 10,363
    edited June 28
    As per my experience of validating Premier membership:
    1) Login to Daz Connect from Smart Content pane with Update Metadata unchecked. You may be asked to restart DS but DO NOT do that immediately. Wait for a while, appr. 1 ~ 2 minutes till you see Premier logo via DS > Help > About Daz Studio...(screenshot 1)
    2) Now Exit and relaunch DS. You should be able to see Premier on the splash screen. Then check DS > About Installed Plugins... see if Premier plugins are shown as green plugs. (screenshot 2)
    3) If you cannot find them via DS menu items. Save your DS Layout by pressing F4 firstly, then: DS > Window > Workspace > Update and Merge Menus.
    Edit: You also can check DS log to see if you can find a string : Roles: Premier  If you cannot find it, it means your Premier validation is failed ~~
    640 x 480 - 405K
    814 x 1040 - 81K
    Post edited by crosswind on
  • edited June 28
    Thanx Crosswind, starting the CMS made me realize that while away on holiday I'd changed my password& after inserting the new password & restarting Daz, Premier & all it's plugins are restored
    Edited by mod to fix quote)
    I didn't, no. The little plugs were just greyed out. The date in the dialog box said it was good until July something. IDK what the deal was.
  • Richard HaseltineRichard Haseltine Posts: 112,268
    Changing activation (by adding a serial, or logging in if your mPremier activation had times out, or by unchecking in Help>About Installed Plug-ins) always requires a reset. I think plug-ins can deactivate if their trial/activation period runs out but I am pretty sure that activating always requires a restart.
