• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
[Diffeomorphic] Massive deformations caused by poses and animations when using the MHX rig
bigoskar00bigoskar00 Posts: 31
June 6 edited June 6 in Blender Discussion
I was testing some poses with some of my characters and I realized that when I convert the rig into MHX and then I try to import a pose the character gets extremely distorted, here are some examples first with the base daz rig where there are no distortions when I use one of my poses
and here is how this same pose looks if I use MHX
the same happens with animations. If I import an action and the animation moves the character beyond its static position it completly breaks, here is one example again doing a comparison of the same animation using both the base daz rig and the MHX rig
is there any solution to this problem? Or am I out of luck and will have to just the basic Daz rig and forget about using any of the fancy rigs like MHX or rigify?
Post edited by bigoskar00 on June 6
  • PadonePadone Posts: 4,243
    June 6
    Can you upload the pose preset we can give a look.
  • bigoskar00bigoskar00 Posts: 31
    its some pose presets I buyed, the ones I used for the examples are the following ones
    https://www.renderosity.com/freestuff/items/97024/crp-fitness-poses-for-g8f-g9f
    https://www.daz3d.com/runway-low-heels-animations-for-genesis-8-and-81-female
    but any pose or animation that makes the character drop to the ground or move around breaks the rig the same way, like sitting down or walking around. This only happens if I try to export a pose or animation from Daz if I make an animation from scratch on blender there is no issues its only with exported animations
    here are some examples from other pose sets that I own to show that the issue is not those specific pose sets
    https://www.daz3d.com/regal-elegance-lie-makeup-for-genesis-9--poses-for-genesis-9-and-8-female
    https://www.daz3d.com/z-royal-handmaiden-poses-and-expressions-for-khemsit-8
    https://www.daz3d.com/blasphemy-poses-and-props-for-genesis-8-and-infernal-wings
    but the moment I use the basic daz rig it gets fixed
    June 6
    That doesn't happen here, I tried the basic pose set for G8F on Victoria 8.1 and everything works fine.
    my steps:
    1. import Victoria 8.1 with the G81 preset
    2. convert to MHX
    3. import poses (from daz runtime > poses > import pose)
    If this happens to you with any pose set then it could depend on the specific figure you use, or the import or MHX options. But we have to narrow it down to find the culprit. Please reply to these questions.
    1. Does it happen to you with the basic pose set for G8F. If not state a specific pose set and pose causing the issue.
    2. Does it happen to you with Vitoria 8.1 or G8F. If not state a specific figure causing the issue.
    3. Do you use the G8 or G81 preset for easy import. If not what are your import options.
    4. Do you use the default options for MHX. If not what are your options for MHX conversion.
    One thing that comes into mind is MHX and rigify are not compatible with body morphs, so if the pose is using body morphs it doesn't work and may produce artifacts similar to those you're experiencing. But this would depend both on the specific pose and wrong import options as the body morphs are not included in the import presets.
    https://github.com/Diffeomorphic/import_daz/wiki/Setup_Morphs_Import_Body_Morphs
    One thing you can do with body morphs is to bake them before exporting the pose preset in daz studio.
    edit > figure > bake to transforms
    430 x 497 - 49K
    p.s. Also state your blender and addon versions if you're not up to date. In any case before reporting bugs you have to update to the dev version. I mean if this is eventually a bug to report to Thomas.
    p.s. Also diffeomorphic is not actually tested with DS6, though we didn't receive any bug report yet specific to DS6. If this happens to you on DS6 then try DS4 and let us know.
    Post edited by Padone on June 6
    June 6
    alright after doing some experimentation I managed to isolate the source of the problem and is that when I created the MHX rig I selected spine IK which seems to be the source of all the problems because once I deselected it it worked without any issue, atleast thats good to know
    June 7
    Nope, works fine here. I tried Victoria 8.1 with your fitness pose, all the IK options enabled for MHX including spine. In your picture the character seems to have strange deformations for the legs, even with the daz rig, what specific character is that ?
    addon 5.2.0.2928, blender 5.1.2
    Another thing that comes to mind, it's better to disable locks and limits when working with IK, otherwise snapping may not work fine depending on the pose, but doesn't seem the case the specific pose works fine with and without locks and limits. Do you use any scaling on the bones for the specific character ? Because that may make the difference as scaling works different in blender, make sure "inherit scale" is disabled in the global settings and "apply transforms" is enabled ineasy import.
    https://github.com/Diffeomorphic/import_daz/wiki/Setup_Rigging
    723 x 343 - 54K
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
Create An Account
