Daz Studio 2026 Beta - version 6.25.2026.14219! (Updated May 23, 2026)
1697071727375»
  • mnemonicmnemonic Posts: 7
    The latest beta no longer spins fans whenever I point at any object in a viewport, so I guess it's moving in the right direction, performance-wise :) I hope the focus on performance continues now that it's feature-complete.
  • TBorNotTBorNot Posts: 378
    edited May 21
    DoctorJellybean said:
    TBorNot said:
    Mac Bug:
    Add to scene a saved character Genesis 8 Male, with an attached Anatomy "Genesis 8 Genetilia".  The main image flickers around the shoulders pretty severely.  There is a progress bar on the lower right that goes crazy and the system is pretty much unresponsive as the %s rolls constantly.    To fix this, select the genetilia and then sort by "Currently Used", then look at "Render SubD Level (Minimum)" Mine is set to 3.  Move the slider to 0 and the recursive % progress bar stops and the image is responsive again.  Unfortunatley, while the interface is working, trying to use the camera icon to draw the image creates a crash.
     The figure and genitalia, both from DAZ?
    Yes on both.
    Post edited by TBorNot on
  • DoctorJellybeanDoctorJellybean Posts: 9,894
    TBorNot said:
    Mac Bug:
    Yes on both.
    Could you please state your hardware, and which viewport mode.
  • furiousstugfuriousstug Posts: 210
    inquire said:
    Think of how this seems to an Apple Macintosh user when scripts  don't work in DS 4 and the software runs in emulation, and Rosetta 2, the emulation tool, will soon be dropped by Apple.
    This may sound treasonous, but has anyone tried animating a Daz produced render with an AI app? In moments, you can have an animation.
    I've been doing extensive experimenting with animating Daz renders in AI and I can say that generating a sequence in "moments" is not a thing. Unless you have a GB200 under your desk. Please Powerball, please... You can burn through iterations with a 5090, RTX 6000, or HX200, at half rez pretty quick, but the intial pass will still take a couple of minutes. And bumping up to 1920x1080 will give a significant time increase.
  • barbultbarbult Posts: 26,852
    Nice new icon and splash screen. Now I can pin both DS4 and DS6 to my taskbar and tell them apart. That little thing is a big thing to me. Thanks
  • TugpsxTugpsx Posts: 874
    edited May 22
    I have been putting them apart so i could tell, which which is which wink
     This new icon helps a lot.
    Post edited by Tugpsx on
    I tried that once, but I still got confused. blush
  • bilyatboringbilyatboring Posts: 15
    There is still a quite a bit delay (5-20 sec) when minimizing the daz and maximizing it, just for an empty scene
  • deepred6502deepred6502 Posts: 417
    I've just updated DS2026, and the text now looks a bit smaller and blurrier, even with default colour schemes.
    606 x 486 - 62K
